Question about Whirlpool Accuwave Microwave Oven
Mu accuwaave makes a short noise intermittenly while trying to heat
  • 519 Answers
Is your microwave oven set to full power when the intermittent noise occurs?
If it's set to a lower power rating, then the noise you describe sounds perfectly normal.
At a lower power setting, the device which creates the heat or microwaves, called the magnetron, switches on and off intermittently so that the food etc. is not cooked too fast.
This is quite normal & you should only be concerned if the noise occurs while the microwave oven is set to full power.
In that case you will have to have it checked out to see what the cause is.
Best wishes,
Graemevm
Posted on Mar 24, 2011
Why microwave won't stop running unless door is open ?
Is it actually heating or just making noise and acting like it's heating? (put a cup of water inside and close the door.) IF it's actually heating, then you have a shorted relay on the main control board, and you will have to replace the board. IF it's just making noise like it's working, but it's not heating, then the problem is 1 of the door switches is not working right (it's either stuck open or stuck closed).
Aug 16, 2014 | Whirlpool Microwave Ovens
Microwave turns on when the door is open must un-plug to shut off
Is it actually heating or just making noise and acting like it's heating? (Put a cup of water inside and close the door.) IF it's actually heating, then you have a shorted relay on the main control board, and you will have to replace the board. IF it's just making noise like it's working, but it's not heating, then the problem is that one of the door switches is not working right (it's either stuck open or stuck closed).
Aug 15, 2014 | Kenmore Elite 1.5 Cu. Ft. Countertop...
Ge spacemaker microwave jvm1640cj03 stopped heating. interior always clean. light, timer etc working.
If it stops heating and the other parts of the oven still work, the problem is with the magnetron circuit. If it makes a loud buzzing noise when you try to heat the food, then the magnetron has shorted out. The replacement cost for the magnetron is almost as much as a new oven, so it does not make sense to have it fixed. Sorry.
Apr 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
We were using the microwave the other night and it started making a loud noise like the fan was running (although the fan was not). We let it sit for awhile and try to use it again but the noise came...
The loud noise and no heat means that the magnetron has failed. It the part that generates the microwaves that heat the food. When it fails it shorts out, causing the transformer to heat up. That is what was causing the burning smell. The cost of a replacement magnetron is around $130-150 range so it may not make sense to have it fixed.
Mar 24, 2011 | Maytag MMV4205 Microwave Oven
Does not heat-has a louder noise
most likely you have a bad magnetron on unit... if everything else is working just not heating the magnetron is bad and this is what heats the food... it is located behind the control panel /.....sometimes there is a thermal fuse on the magnetron that can go bad but if it is making a loud noise most likely it is trying to come on but has shorted out....good luck to you./
Jan 12, 2011 | Microwave Ovens
I have an over the range microwave, and it suddenly stopped heating. Also, makes a loud noise when you turn it on.
It sounds like the High Voltage diode (1) is shorted but it could be the magnetron (2) or the HV capacitor (3). - 1 side shorted to ground. A dead short will blow the fuse and kill the unit.
Sep 11, 2009 | Microwave Ovens
Microwave makes loud noise and does not heat. Smell of light burning
The noise is coming from the high-voltage transformer being overloaded by something shorting it out. Either the magnatron or the high-voltage capacitor and diode. Replace the capacitor and diode then if still not working, replace the magnatron. Its only affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Feb 06, 2008 | Whirlpool GH8155XJ Microwave Oven
Kenmore 721.63662300, 1200W
The magnatron is shorting and overloading the high voltage transformer which is complaining with a load noise. Worth fixing if you do it your self. Magnatrons cast about $40 wholesale. There are just a few varieties of them that fit almos all brands. Try www.partstap.com
Dec 07, 2007 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
205 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
