Question about Indesit IS70C Electric Dryer
Hi, I have Indesit IS70C Electric Dryer, and what happens is that when it starts drying , after a while I lose all the power in the house. Once I unplugged if from the wall, I can restore the power in the house. Any clue what is causing the problem?
Had same problem found a lot or water at the rear of the condensing element at bottom front of dryer because the float at the rear was blocked with fluff resulting in water being flicked up by the fan onto the heating element.Cleaned out float compartment and been fine up til now.
Posted on Aug 24, 2012
  • 822 Answers
If its blowing the trips................... mite be bad earth ...................check all cables.......
with power off................
cheers
Posted on Mar 24, 2011
Why does my indesit is70c rattle when spining
the front or back wheel has gone they are plastic
Jun 28, 2012 | Indesit IS70C Electric Dryer
Indesit IS70C tumble dryer not heating
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 10, 2012 | Indesit IS70C Electric Dryer
Dryer getting hot but not drying clothes
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Sep 06, 2011 | Indesit IS70C Electric Dryer
The light on the water drawer of my IS70C dryer is staying on and the dryer isnt drying.
Thank you for the direct question but unfortunately we don't work on Indesit units and have no documentation on them, so I am unable to help you.
Sep 03, 2011 | Indesit IS70C Electric Dryer
I have Indesit IS70C dryer and all of a sudden it's not getting hot when switched on and the water container is empty..water is not draining from the clothes to the container and machine is not getting...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101.//.';';]\\
Jul 25, 2011 | Indesit IS70C Electric Dryer
Hi I have an Indesit is70c dryer it seems to work fine for 10-15 mins but then trips the fues box in the house as it cuts out. I've had a look for at the fuse and have cleaned out all filters / condensers....
Do not overload the dryer as the motor can struggle and try to draw to much power.which could cause the trip to go to out, only load drum half full.....this applies to washing machines as well"NEVER OVERLOAD THEM" with washing machines it can affect the quality of your wash as well as putting extra strain on the motor.
Nov 08, 2017 | Indesit IS70C Electric Dryer
Indesit condensor tumble dryer does not heat up
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 08, 2011 | Indesit IS70C Electric Dryer
I have an indesit IS60V tumble dryer and it's no longer drying my clothes even though the dryer tumbles fine. I have checked the filters to ensure they are clean and the vent hose which all appear ok.
heatman101
Sep 24, 2010 | Indesit IS70C Electric Dryer
Hi,my indesit IS70C tumble drier works but does not heat up.\possible causes please.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | Indesit IS70C Electric Dryer
Not blowing hot not drying
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 07, 2010 | Indesit IS70C Electric Dryer
Indesit IS70C Electric Dryer Logo
524 people viewed this question
Top Indesit Dryers Experts
Tim Whalen
paul
paul
Are you an Indesit Dryer Expert? Answer questions, earn points and help others
