Question about Onkyo TX-SR803 Receiver
Zone 2 on Onkyo TX SR805 inoperable
Have selected active in set up menu; don't have back surround speakers hooked up; using analog analog input; have selected source for zone 2. Zone 2 indicator light illuminates on receiver, but no sound from speakers. Speakers/speaker wire have been troubleshot and are good.
Puzzled!
  • 151 Answers
HI pull down the flap on your amp and you will see buttons for zone 2 settings,press zone2 then level up this should work.
hope this helps .
CABLE GUY.
Posted on Aug 05, 2008
HOW TO CONNECT A ONKYO TX NR535 TO AN EQUALIZER
First this solution will be fraught with potential problems:
1. There is no simple monitor outputs and inputs on the NR535.
2. The NR535 analog inputs/outputs are unbalanced, where the Behringer EQ is completely balanced (TRS or XLR)
3. Insertion of the EQ is analogous with inserting an effects device in an audio loop which in the case of analog surround will cause de-correlation or the companding sidechain making for non-compliance/performance issues.
OK, now the solution can be as follows:
Since the NR535 has a Zone 2 channel, you can use these L/R RCA outputs to make an effects loop. To do this you will need to make or buy RCA to TRS (1/4" phone Tip Ring Sleeve jacks) that you will connect from the Zone 2 outputs to the CH1 and CH2 inputs of the EQ. You will need another pair of the RCA to TPS to connect the output of the EQ back to one of the RCA analog inputs on the back of the Receiver.
Now once this is done, you will be able to Map Zone 2 input to any of the inputs other than the one you are using for the output of the EQ. Let's say you have mapped Zone 1 to your gaming station. This will patch the audio from your gaming station into the EQ and back into your previously connected analog input. At this point, you can leave Zone 2 and select your analog input which is your EQ output, which is your Gaming station. If you don't have any output, you may need to go back into the Zone 2 setup and adjust the volume level.
When you don't want the EQ in the signal chain, just select the input source other than the input used for the EQ's Zone 2 output.
I am not sure if this will work for all situations as you may have technical conflicts between analog and digital audio on some inputs. In any case, this will work with analog signals and I don't see any other simple solution for your case.
I hope this solution can help.
Feb 26, 2015 | Onkyo TX-NR535 Receiver 5.2 Channels, 65...
My Onkyo TX-SR506 plays cable and CD inputs to zone 2, but DVD won't play. Everything is connected according to the manual and I assigned zone 2 output correctly. What gives?
How are your cable and cd inputs hooked up? Analog connections? Alot of receivers cannot send an audio signal from hdmi inputs to zone 2.
Feb 06, 2013 | Onkyo TX-SR506 Receiver
Message states the power to zone 2 is not activated when trying to listen to zone 2 speakers. Nothing in my manual about this message. How do I activate power to zone 2 on a tx-sr601
Page 77:
"Not available in Zone 2 mode" Setting not allowed because the Zone 2 mode is turned on.
"Zone 2 is not On" Will not work because the Zone 2 has not been turned on.
TURN ZONE 2 ON.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR601-Receivers-manual/id/365ag212/t/2/
Page 55 shows the prerequisite settings for using the surround back terminals for Zone 2.
Page 60 describes USING Zone 2 and points out that only analog sources can be used with Zone 2. Are you trying to use digital sources? Read the notes regarding REC OUT.
Jul 07, 2011 | Onkyo TX-SR601 Receiver
My ONKYO TX-SR601 receive will not let me play my zone 2 speakers. I get a message saying '' Powered Zone 2 is not activated. How do I activate Zone 2? Thanks. Tom
Have just got a 607 myself, but it may apply to your model too.
Press the RECEIVER button followed by SETUP. On the TV screen a menu should appear and select SPEAKER SETUP then SPEAKER SETTINGS and set the powered Zone speakers to ACT.
SETUP will then return you to normal. Note: some other surround speakers will be switched off when ACT is on and ACT won't come on if Bi-amp is used.
Jun 13, 2010 | Audio Players & Recorders
Outdoor speakers on Zone 2
Hello Fixya customer,
Thank you for your question.
Please verify that Zone II power is "Acitvated" from the Hardware menu.
Thank you for using Fixya, an let me know if you have any additional questions.
May 01, 2010 | Onkyo TX-SR605 Receiver
How do I connect my outside speakers to play?
The onkyo should still have a speaker A/B selector in the menu.
Check on the back panel for speaker A/B.
If it has or you decide to use Zone 2 you will need to set the sound programme to "stereo" so the rears and centre do not work.
You can still use a digital source.
You should be able to display the amp's menu on the screen.
Hook up "monitor out" (Yellow) via RCA connector to one of the "A/V inputs" (yellow) on the tv, this will show you a display of the menu and will make it eaiser to navigate.
Jun 16, 2009 | Onkyo TX-SR705 Receiver
I have the Onkyo HT-S5100, the 5 speaker are set
also, you might have to search through the menu of the receiver, and set the surround back speakers to be zone 2 instead of using the 7.1 configuration that is probably default.
i think zone 2 will only play sources that are hooked up with analog connects, ie. red/white cables. try using the radio to see if it works. you might have to hook up your cable/sat box, cd player, dvd player, whatever you have that you want to listen to with both digital and analog cables to get everything to work right.
Jun 12, 2009 | Onkyo TX-SR503 Receiver
No sound from rear speakers
Hello, the setting must be "Not Activated" That is for zone 2 setup. If you are setting up 5 speakers the rear speakers should be connected to surround not surround back. Thank you Onkyo USA.
Mar 25, 2017 | Onkyo TX-DS898 Receiver
Onkyo TX-SR805 - surround sound problem
The speaker impedance is not the problem.
Apr 09, 2017 | Onkyo TX-SR803 Receiver
Zone 2
I am sure this isn't it, but if all components are connected digitally Zone 2 won't work. It only allows analog connections, so anything attached via HDMI, etc. will not be able to be output to Zone 2.
Dec 08, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-SR803 Receiver Logo
724 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
