I have a Galanz 12000BTU Air conditioner, when i switch it on it runs normally till it cuts and then the outside unity fails to restart after cutting.
bobotfel
  • 236 Answers
SOURCE: hisense air conditioner
-If both compressor and fan motor starts and stop, thermostat is the defect.
- If only the compressor check for your outlet no sign of discoloration, check the voltage if normal, check the defective overload protector of the compressor it its external, or compressor itself is defective
Posted on Jan 04, 2008
bobotfel
  • 236 Answers
SOURCE: air conditioner
Remote control units have diagnostic program in the
control, after 3 to 5 minutes of operating if the diagnostic
tools detect abnormal operation, then its shutdown the unit
to protect from damage. Thermistor sensor is one of the
parts that detect the operation of the unit. Out of range
or defective thermistor can shut the operation of the unit.
If your indoor and outdoor is clean start the unit in cool mode and monitor the outdoor pipes. If your suction pipe is icing or dry then your unit is under charge, but if your suction is cold and sweating then the system is ok and sure that the thermistor sensor is defective.
- Out of range thermistor sensor in both return air and freeze up sensor can cause the tripping “off “ the unit. The resistance of both thermistor is 8 to 10k ohms, so can test by using ohm meter
Posted on Jan 12, 2008
  • 230 Answers
SOURCE: blower motor in home air conditioner does not work
The most common failure for this problem is either the start/run capacitor or the fan motor. IF YOU ARE NOT experienced with electricity then I would strongly suggest hiring a technician. The volts are 220 with a potential of 50 amps in a common residential unit.
If you are knowledgeable in this area then make sure the motor has volts to it. If it does have volts and does not spin, it is bad. You can sometimes tell by feeling the motor it will probably be very hot. The compressor will eventually shut itself off when it over heats. It usually will restart after it cools down(sometimes many hours). The motor and capacitor are pretty generic and can be matched up at a local Grainger store or whatever Retail, specialty store that you have in your area.
I hope this helps:)
Posted on Jun 25, 2008
  • 234 Answers
SOURCE: Problem with Sharp Air conditioner
You proablly have freon leak and the unit cuts off on low psi.
Posted on Mar 19, 2009
  • 59 Answers
SOURCE: Outside Unit Air Conditioner fan not running
probably a bad fan motor. could be a capacitor
Posted on Apr 25, 2009
My air conditioner is not blowing cold air in the house
because the fan inside the house is working doesn't mean that the compressor outside is working
It may be a faulty start /run capacitor for the outside unit ,out of gas or failed power board
I suggest that you get an accredited technician to come and give you a proper diagnosis of the fault.
Jul 17, 2015 | Heating & Cooling
My 12000btu spliter air condition start and stop in 5 seconds
24
EN
TROUBLESHOOTING
CAUTION
If any of the following conditions occur, stop the air conditioner immediately, turn off the main power switch and contact the
dealer.
• The indicators flash at short intervals (5 Hz). Reset the circuit breaker 2 to 3 minutes after the power main switch is turned
off.
Despite the resetting operation, the indicators still continue turning on and off.
• The main power fuse often blows, or the circuit breaker is often activated.
• Foreign matter or water has fallen inside the air conditioner.
• Any other unusual conditions are observed.
Before asking for servicing or repairs, check the following points.
Recheck
Inoperative
• The power main switch is turned off.
• The circuit breaker is activated to cut off the power supply.
• The main power fuse has blown.
• The electric current has stopped.
• The batteries in the remote controller used up.
• The ON timer is set.
• As a protective mechanism for the air conditioner, it does not operate for 3 minutes
immediately after restarting operation or turning on the main power.
Poor cooling or heating performance
• The air inlet or outlet of the outdoor unit is blocked.
• Doors or windows are opened.
• The air filter is clogged with dust.
• The louver is not at the correct position.
• The fan speed is set to low.
• The air conditioner is set
to the DRY or SLEEP MODE.
• The temperature setting is too high (during cooling operation).
• The temperature setting is too low (during heating operation). (heat pump models)
Feb 01, 2015 | Samsung AS18A6RB Air Conditioner
I have a small frigadare a/c.a one room a/c.it comes on then right back off.what can i do about this.
Hello, here is what the problem may be. Every air conditioner has a motor called a compressor. The compressor provides the cooling capacity for the air conditioner. If the compressor or its electrical controls are defective the compressor may try to start, fail, and create an electrical overload. If the unit does create an overload, every compressor circuit is also equipped with an overload safety switch. The safety switch is designed to protect the compressor from burning out. The safety switch will cut the power to the compressor for a certain length of time and then reset itself. When it resets it will allow the electricity to flow to the compressor once again. If the compressor then starts, the unit should function normally. If the compressor doesn't start when the overload resets, the overload will again cut the electricity to the compressor. This cycle will continue indefinitely. (Always allow three to five minutes before restarting the compressor.) If this situation is occurring, unplug the air conditioner and get help from a qualified repair technician. This problem is often fatal to the air conditioner because the cost of repair often exceeds the price of a new air conditioner.
May 25, 2011 | Frigidaire Heating & Cooling
I have a split unit airconditioner 12000btu.It worked great for about almost 5months.till yesterday,when I turned on the air con,I didn't feel cold.I just felt normal wind blowing.then after 5min a...
E-4 ..........short of asor no gas
Please check amps with amps meter reading. If very less amps than specified, it's under gas leak. Even you can physically touch the discharge (small) pipe while running, if it's not warm, gas leak. Call repairman to check and arrest gas leak and then recharge gas.
Helpful?
Dec 25, 2010 | Heating & Cooling
I bought a brand new Duo Thermo rv ac unit and I am having a issue with the compressor. I have it running all day and it works fine, but when it is running at night the compressor shuts down frequently...
Yes, the Air conditioner system is a bit low in charge, so when the air cools outside it drops the gas pressure too low and then the lose of charge switch cuts out till the pressure raises then it comes on again..
The best thing would be to get a pro to add some charge to this A/C system.
Here isa tip that I wrote about how to add refrigerant to a air conditioner or coolingsystem
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
Sep 27, 2010 | Dometic Rooftop RV Air Conditioner
Wont blow out cold air anymore?
hi...
Every air conditioner has a motor called a compressor. The compressor provides the cooling capacity for the air conditioner. If the compressor or its electrical controls are defective the compressor may try to start, fail, and create an electrical overload. If the unit does create an overload, every compressor circuit is also equipped with an overload safety switch. The safety switch is designed to protect the compressor from burning out. The safety switch will cut the power to the compressor for a certain length of time and then reset itself. When it resets it will allow the electricity to flow to the compressor once again. If the compressor then starts, the unit should function normally. If the compressor doesn't start when the overload resets, the overload will again cut the electricity to the compressor. This cycle will continue indefinitely. (Always allow three to five minutes before restarting the compressor.) If this situation is occurring, unplug the air conditioner and get help from a qualified repair technician. This problem is often fatal to the air conditioner because the cost of repair often exceeds the price of a new air conditioner...
hope this will give u a clear idea..
thank u
rate me!!!!
Jul 19, 2009 | Pelonis Heating & Cooling
Air conditioner not working
This is simple , turn your thermostat to fan only and not auto fan and see if it runs, if does then run it like this till a service man arrive, the fan motor for cool is gone out!
Sep 08, 2008 | Heating & Cooling
Air conditioner keeps tripping breaker replaced the termostat do you think the compressor is gone its only 6 years old.
if this helps please vote me a fix ya
Jul 18, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
