MM5458-ded - Audio Players & Recorders
Need driver for tdk external cd/dvd writer model ded+880N
external writers are plug and play , they do not need a driver. the disk i think your referring to will only contain writing programs but there are many free writing programs on google search. just plug the writer into any usb port and windows will find it and install the drivers automatically
Jan 24, 2013 | TDK (DED+880) DVD±RW Burner
Phon is ded and blututh ded tuch sreen phon no sper part in indiya
if you know exactly what kind or company is your phone of it might be help ful.
Jan 13, 2011 | Cell Phones
The Disk Tray will not open (TDK DED 440 DVD driver)
The lubrication inside your device may be insufficient or some mechanical problem has occurred inside preventing the device to open. Now, look at a very "small hole" near the Tray's front cover. If you see it, get a very small pin or even a needle to fit to that small hole. Now, press the "open" button in your device and then push that pin or needle in the hole at the same time to help the device to open.
Dec 29, 2009 | TDK (ded+440n) DVD±RW Burner
The clima control unit wont start after it was disconnected. Totally ded! All light, fan, etc. is ded. XC70-2001
I hate to state the obvious, but it sounds like it was not reconnected. There are 3 possibilities, no power, no ground, or bad fuse.
Dec 03, 2009 | 2001 Volvo V70
Hai sir nokia 6030 set ded problem
have you tried changing the battery? if not, change it first...
still not ok, open the housing and check the switch botton...use a multitester... there should be no continuity when not press.... there should be a continuity when pressed. still no luck... visit your local cellphone repair shop
Jan 22, 2009 | Nokia 6030 Cellular Phone
Ded
good day ! check the charger power suply, check the charging pin, check the fuse, if all is ok remove the two resistor on the side of battery terminal or remove the fuse and jump it ! thats my best and tested solusion!..
Sep 10, 2008 | Nokia 1600 Cellular Phone
Logitech z-5500
Try to click the EFFECT BUTTON a few times to change the effect settings (see also in display) from e.g. Stereo (which uses only two front speakers) to other settings (for which some will use the other (rear/center/sub)speakers as well). Success,
Jun 20, 2008 | Logitech Z-5500 Computer Speakers
Does not power on
hi friend
chk your power supply it has been ded or not working
chk your power cable
Apr 14, 2008 | IBM ThinkPad T23 2647 Notebook
22 people viewed this question
 Grubhead
Grubhead
