Question about Fisher and Paykel GWL11 Top Load Washer
Has your problem been solved?
My gwl11 is doing the same thing. It started a week or so beeping like it had an unbalanced load. Today I spent the time with it while it was filling and noticed it was emptying as it was filling. So I think the beeping was more of a time out for the filling. At least now I can clean my clothes on the permanent press setting....which is still unacceptable. So much for the thoughts of owning a "better" washer.
Wondering if the diverter was the fix for you too? My drain is fine. This washer has been in the same place for several years without any drain issues. It's about 3' up.
Thanks.
  • 30 Answers
This is what is called in the trade as siphoning.
The drain pipe has to be a cetain height up on the wall.
if you ever hear it filling and draining at the same time,its siphoning.
check to see if your pump is on at the same time it is filling.
remember to always write which light s are flashing as this means a fault code.
Posted on Aug 05, 2008
Gw612 won't agitate
Fantastic that's great news you got it going.
Oct 04, 2013 | Fisher and Paykel GWL11 Top Load Washer
Washer beeps as if unbalanced when in rince cycle and water is leaking a bit from somewhere, clothes are still damp. fisher and paykel
if it's leaking, take it somewhere to get checked, water and electronics don't end up mixing in a cheap way! the leak could be the pump or main seal. the unbalanced thing can be due to spring failure.
Aug 15, 2013 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer starts but drum won't turn, it twitches and beeps then turns off with solid beeps
Hi ken
Can you turn the bowl & agitator by hand.
If it can't turn by hand, Your seal & bearings need replacing.
Feb 01, 2013 | Fisher and Paykel GWL11 Top Load Washer
The lights come on, but the machine doesn't start
do you hear a beep when the start button is pushed? if u do hear a beep then it could be your lid switch is faulty, if you dont hear a beep then your keypad is faulty. is the plastic covering the buttons cracked?the keypads fault sometimes because water goes thru the cracks into the electronics causing it to corrode. please reply with answers 4 more help.
May 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
During spin cycle it becomes unbalanced and it beeps and stops
It sounds like the sensing arm of the out of balance switch assembly is wrongly set. Get the guy back to do the job properly at no charge!
Oct 19, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Fisher and Paykel GWL11. When I start a cycle it stops
OK If you tell me which lights are flashing when it beeps I'll tell you the fault eg there are eight lights 00000000 1=on 0=Off cheers
May 14, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher pakel water saver washer stopped early in cycle and is non stop beeping
www.ths.gardenweb.com/forum/laundry
try this website. I found answers to my questions on it that i did not find here.
repairman who came to my house yesterday said manuals are only available on dvd, not in paper anymore.
saw on the other website that you can order FP parts through Sears. have not tried, so don't know if that is reliable. maybe you can order a FP manual through Sears to tell you how to fix your issue.
Oct 21, 2008 | Fisher and Paykel GWL11 Top Load Washer
My GWL11 won't fill correctly or wash!
Hi there you need a new cold valve in the washing machine. :)
Sep 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
Slow running washer
The beeping may be a code to tell you what the problem is, ie low water supply, overloaded, out of balance, etc. My user manual has a problem-solving page that explains the different beep sequences.
Jul 25, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
136 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
