I have a Hartke HA3500 350w bass amp. When I play my bass guitars I get a slight fuzzy distorted sound from all four speakers. So I'm guessing it's not a problem with the speakers. Can you help?
  • bassplaya Mar 29, 2009
    When the Tube side vs solid state side is used I get distortion I believe it is the tube that went out The solid stae side is ok
  • 14 Answers
SOURCE: Fuzzy Speakers
Suggest that the speaker cone is damaged
Posted on May 08, 2007
zzedly
  • 300 Answers
SOURCE: Amp went into protect, but front speakers sound distorted too
If the amp still goes into protect mode, the easiest thing to do is disconnect the RCA cables from the amp and see if still goes into protect mode (after turning off/on). If it does, the issue lies in the amp or the wiring to/from the amp (most likely case). Check to make sure no speaker wires came loose and touched +12V or ground (car body). From the sound of it, my guess is something internal to the amp died and will need repair.
Posted on Mar 27, 2008
  • 151 Answers
SOURCE: Distortion
YOU SHOULD NOT PLAY CD,S IN SURROUND SOUND,SWITCH TO STEREO ONLY FOR CD,S AND OTHER MUSIC SOURCES.
HOPE THIS HELPS.
Posted on May 27, 2008
SOURCE: Bass amp for guitar?
not sure, i'm in the same boat tho and i'm gonna give it a shot.
Posted on Jun 08, 2008
marsrover
  • 682 Answers
SOURCE: The Surround Sound sub-woofer doesn't
check the setting of your sub and confirm that it is on-check cable of sub and confirm it is connected firmly.-disconnect power cord and reconnect it again.
Posted on Jun 26, 2008
Hartke vx115 lost significant volume
If you've tried different heads with the same result, the most likely problem is a blown speaker. Check it with an ohm meter, and if it's blown, you can either replace it or get it re-coned.
Apr 24, 2015 | Hartke VX115 - 1 x 15 Bass Guitar Cabinet...
Hi folks...I have a Behringer HA 400 Micro Amp. My question is: as I am a bass player/guitarist. Can I put my bass or guitar through this device. I understand that it will accommodate 1 instrument at a...
You can put just about any instrument through any amp. The difference in sound will be whether or not that amp was designed for the particular frequencies of that instrument. Also whether or not the speakers you are using are designed for those frequencies. When playing bass you need speakers designed to carry low frequencies (40 - 400 hz); mid-ranges and tweeters don't cut it. Set your instrument volume on the guitar at 70 - 90 % to get the most signal from the instrument. Set output volume on the amp at 50 - 70 %, then adjust gain on the amp to get required sound level. You're not likely to blow the amp, but you could blow the speakers if the amp delivers more power than the speakers can handle. With a micro amp check the output rating. It's possible you may not have enough power to get the sound you want and as you turn up the gain the sound will distort.
Nov 04, 2017 | Music
No sound coming out for my hartke amps?
Are the internal speakers properly connected via the rear-mounted 1/4 inch "Speaker Output" jack? If so and still no sound, try connecting a separate external speaker (floor monitor, pa cabinet) for a "low volume" test.
The OM says the internal speakers are 4 ohm so it's unlikely that a wiring problem with speaker connections would cause all four to stop working. With AC power disconnected from outlet check for an internal speaker protection fuse BUT be careful. Charged capacitors can hold a charge for weeks!!!
Oct 25, 2012 | Hartke VX3500 Bass Guitar Combo Amplifier
After playing a a few small gigs my husbands Hartke vx3500 bass amp cuts out with the sound BUT the head seems to stay lit up, dont have problems when a low volume but during a gig has randomly cut out for...
It has something loose on the board or where the speaker wires connect. Combo amps are really bad about doing this. The vibrations from the speakers loosen the components on the board.
Sep 03, 2011 | Hartke VX3500 Bass Guitar Combo Amplifier
Amplifier head is working but no sound from speakers. Head tested with external speakers and is OK.
A simple test is to connect internal speakers across an AA battery (for about half a second) & listen for a click as battery is connected & another as battery is disconnected.
If this does not happen, check the internal jack plug connection & its connection to the speakers.
If OK, then you can test each speaker individually using the same battery across each in turn.
If this advice is helpful, I would appreciate a rating.
Apr 10, 2011 | Hartke VX3500 Bass Guitar Combo Amplifier
I have Ibanez gsr200 bass guitar , yesterday and today I noticed that my bass's voice is irregular , please help me how to solve it , It's a new bass , Thanks
No question what to do... take it in under warranty since it is new !!!
You may find that there is a problem with your amp... the seller should be able to test the guitar and demonstrate normal sound for you.
Many users have TOO small of an amp and the distortions make it appear that the guitar is bad... I suspect you will want at least a 12 inch speaker and preferably a 15 inch for your bass.
When low frequency signals drive a speaker too hard it drives the voicecoil out of the linear range and the sound will be irregular..
Apr 01, 2010 | Dean Edge 4 Bass Guitar
GK 1001 rb speaker overload, is my guess
This problem is not likely to be a volume control problem. There is a transistor inside that is failing (getting noisy) when heated up. If you have no experience with amp repairs, do not attempt this as it is not simple to locate the defective part. Continued use in this condition can cause problems with the speakers. Please have this serviced by a repair shop with experience with GK gear.
Dan
Jul 29, 2009 | Crown CE1000 2-Channel Amplifier
Fuzzy sound when instrument being played
The 1/4" output on your bass needs to be resoldered in 1 or more places. It's very common.
Mar 28, 2009 | Audio Players & Recorders
Mar 22, 2008 | Car Audio & Video
i say it can! u would get a nice clean sound! acoustic guitar sounds nice through a bass amp!
you probably wouldnt get distortion out of bass amp though! depends on the bass amp! some bass amps have built in effects! e.g distortion
Oct 15, 2007 | 3Com SuperStack II advanced RPS...
140 people viewed this question
 Grubhead
Grubhead
