Hi how can i get my Netgear GA302T ethernet adapter to work with windows 7 i have installed it but i can not get the drivers to work because it is a older adapter now and was not built for windows 7 and no matter what i do i can not get the yellow box in devise manager to go away pls help me so i can get this to work with windows 7
  • 3,606 Answers
Try to update the driver from here:
http://kb.netgear.com/app/answers/detail/a_id/506/related/1
And select compatible mode when you install the driver.
You can select almost all previous operating system.
Remember to run as admin.
Hope this will help you.
Posted on Mar 24, 2011
Stuck At Detecting Adapter
Disconnect it, remove any software that was installed and restart the computer. Do not connect the device until you finish installing the device's software or the software installation prompts you to connect the device.
If that doesn't work, here's Microsoft's solution:
http://windows.microsoft.com/en-us/windows-vista/update-a-driver-for-hardware-that-isnt-working-properly
If that doesn't work, go to Netgear's website for support and/or post the problems in the forums.
I hope this helps.
Dec 19, 2012 | NetGear WNA1100 Wireless-N 150 USB Adapter...
Hi! I'm using Windows 7 OS. Also i have NETGEAR Wireless-N 300 JWNR 2000 router, which has been setup and running fine. Now i'm trying to setup NETGEAR Wereless-N 300 USB adapter WN111 and i...
Hello antonhs2000,
I assume you went through the direct instructions located HERE. It does not suggest a restart anywhere on the page, so I would suggest doing that. I have always made it a habit to restart my computer after uninstalling drivers and installing drivers as well just to be safe.
May 29, 2011 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
I have Windows 2000 and my netgear wireless - n - usb adapter wna3100 will not install. I get an error each time.
Netgear does not have Windows 2000 drivers for this product. They are only showing drivers for Windows XP, Vista, and 7.
Mar 02, 2011 | NetGear WirelessN 300 USB Adapter WNA3100
F5d5050 Belkin USB 10/100 Ethernet Adaptor - Does it work with Windows 7 64 bit OS? I have spent hours trying to install a Swann and a Digitech product but none seem to work with the above OS. Any...
You cannot install this adapter in a Win 7 computer because the drivers are not compatible with Win 7.
So far Belkin haven't updated the drivers for win 7 OS. The latest drivers for this adapter is compatible only with
" Windows 98SE, Windows Me, Windows 2000, Windows XP 32-bit, Windows Vista 32-bit "
Click here to see the belkin compatible drivers in the website.
With Regards,
Prema.
Jan 06, 2011 | Belkin Ethernet Adapter F5D5050 Network...
Cannot connect to my wireless router
You can download driver for windows-7 compatible
(download and install in computer)
http://kb.netgear.com/app/answers/detail/a_id/12962
If your issue not resolve please revert back to us for further
Thanks for using Fixya
Apr 09, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
My gateway inside my desktop keeps disconnecting from my ethernet can you tell me what I need to do I have a Sony VAIO VGC 310 with window 7 upgrade
This computer's original OS was Windows XP. Check with the Intel Website (www.Intel.com) to see if there is an updated driver for the Ethernet Card and Chipset for the Intel Pro/100 Ethernet Driver for Windows 7. Intel has a utility you can run (follow the instructions) which will detect all your Intel Chipset hardware and provide you with updated driver information. If there is no Windows 7 driver, try using these steps to correct the issue: 1) download the most current ethernet driver from Intel and save to a folder. 2) Once the download is complete, locate the file and right click on it, click on "Properties" 3) select the Compatibility tab and set the options to run the program in Compatibility mode for Windows XP Service Pack 2. 4) A little farther down in the windows, check the box that says "Run as Administrator" 5) apply the settings and close the properties box. 6) double click the the driver file to activate its install. Follow directions and see if this helps your issue. You may need to remove the originial driver files first. To do this, Go to the Device Manager in the control panel from the start menu, Find your Ethernet adapter in the Network Adapters hardware list, right click and select "uninstall" and check the box to remove the driver files, then click okay - then reboot the machine, the run the new driver file you downloaded from Intel in compatibility mode per my previous instructions. If this doesn't solve your issue, I recommend installing a new network card that is compatible with Windows 7. Its an easy install and shouldn't cost you very much . . . less that $25.00 and should take only about 15 minutes to install. Here is a link to Netgear and their Windows 7 compatible hardware Ethernet card for about $19.00. http://www.netgear.com/Products/Adapters/WiredAdapters/FA311.aspx
Your local Wal-Mart or Target will probably have these and other brands in stock.
Hope this helps FixYa! If you find this information helpful, please leave feedback.
Apr 06, 2010 | Gateway GT4016 Desktop PC
Windows 7 will not download drivers for my netgear wireless, i have the disk, and router.
HI,
Please download the reaquired software from the below link:
http://www.ziddu.com/download/7080987/wg111v2_3_4_0.zip.html
Install the adapter using these drivers to resolve the issue.
Regards
Anand
Mar 07, 2010 | NetGear WG111V2 Wireless Adapter
Problems with WiFi netgear WNDA3100
the drivers should be installed in windows 7 by default, their so called "smart wizard" has some compatibility issues with windows 7, I get it to load up and it will shut down or glitch out. What I did was uninstall the downloaded driver and use the default windows drivers, flipped the switch off to my built in G wifi adapter and the netgear automatically kicked in and took over as the default wireless adapter.
Nov 06, 2009 | NetGear RangeMax Dual-Band Wireless-N USB...
Netgear fa311 fast enthernet adapter
If you've lost the driver disk, use the link below to download the driver of your network adapter.
http://kb.netgear.com/app/products/model/a_id/2357
hope it will help you
Oct 04, 2009 | NetGear FA311 - Network adapter - PCI -...
Need driver for airlink 802.11g ethernet controller.
1. Go here: http://www.airlinkplus.com/downloads.htm2. Click on the device you have3. Download and install the Windows XP drivers
Regards,AbdielPC repair fort lauderdale
Apr 12, 2009 | Belkin (F5D7010) 802.11a, 802.11g/b...
Computers & Internet Logo
131 people viewed this question
David Payne
David Payne
