Question about Carrier 38CKC042 Air Conditioner
Water coming from split ac - Carrier 38CKC042 Air Conditioner
  • 255 Answers
Check the filter for your split ac and clean it if it has dust stuck in the panel.
Posted on Mar 24, 2011
Why does my split ac unit leak inside the house?
This happens when the drain pipe is too high, or kinked. The pipe must be lower then the drain pan in order for the water to drain. This is a common problem.
Jul 27, 2014 | Sanyo Heating & Cooling
Split AC whole unit turnig off at each compressor start up!
Dirty coil wash outside unit with water and change indoor unit filter
Jun 08, 2017 | Heating & Cooling
Water coming out of lg ac
Your unit will have an external vented drain, check to make sure this is not blocked with fluff or dirt as this will cause your issue.
Mar 04, 2012 | LG LSC121PMA Split System Air Conditioner
Why does split ac throw water drops from indoor unit
Because it is removing humidity from inside the house and condensing it to water.
May 10, 2011 | LG LSC121PMA Split System Air Conditioner
There is water coming out of my indoor unit. So much water that I had to shut off the ac unit. It is a Mitsubishi Mr Slim split type air conditioner/heating unit
water coming out of an a/c is normal .its water outlet hose is wrongly installed or not installed at all.get it installed.also level the indoor unit towards the water outlet side when u install the hose .
Aug 10, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Hi I have 1.5 ton samsung split ac. The problem is to solve the water leakage in the indoor unit. Kindly advise
the water comes from the coil, start there make sure there is no obstruction coming out to your condensate line and make sure its properly pitched.
May 19, 2010 | Samsung AS1293L Air Conditioner
E4 Error in Hunday Split Ac
where are you located , like if your residing in noida UP then u would face the issue due to polluted air , and the dirty and harzadeous gasses comming out from back water river, next time when technicians come , kindly ask them for proper flushing and testing it by nitrogen pressure. there can be a minute leakgae.
Mar 19, 2010 | Heating & Cooling
When we turn on our split AC, outside unit is not turning ON
The blinking light is because the unit is waiting for the outdoor unit to come on. If in heating mode, the indoor fan will not run before enough pressure and therefore heat has built up. You should check that the indoor air return sensor is not faulty and therefore preventing the outdoor unit from coming on.
Nov 15, 2009 | Amcor NanoMax A12000E Portable Air...
Water leakage from internal unit of split AC
Draim pans do get dirty and partialy block drain pan. If possible take a shop vac and gently **** out the drain line. This will pull the restriction out of the line and help clean drain pan. Rusty
Jun 05, 2009 | Heating & Cooling
Split ac not cooling
cak split in door unit 1st watar lavel and in sait watar tra blok paip.
Apr 07, 2009 | LG Heating & Cooling
Carrier 38CKC042 Air Conditioner Logo
97 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
