Question about Casio YW-3 - Network adapter - 802.11b, 802.11g, 802.11n
Casio YW-3 Wireless Adapter for XJ-Ax5U Series Green Slim Projectors I want to download above device's driver setup foldier. if you can help me I will be glad. sincerely.
When i install the drivers for TP-Link WN353GD adapter, I already get a warning that it may not be compatible with my system. Currently i am running Win XP SP 2. Is there sometime i can do to overcome...
Update your Wireless Adapter firmware @ http://www.tp-link.com/support/download.asp?a=1&m=TL%2DWR340GD
There are 3 versions for your product(TP-LINK TL-WN353GD, Important***select the correct firmware version to update. Then download the latest drivers(Setup Utility) & and install the drivers for your adapter from the TP Link site.
Link - How to look over the hardware version on a TP-Link device?
Hope it helps.
Apr 05, 2011 | TP-LINK TL-WN353GD 802.11g/b Wireless...
Casio green slim projector Sales and service address and phone number in hyderabad, a.p. india.
We are the authorized Sales & Service Providers for CASIO Green Slim Projectors in India...
Plz conatct us in HYD @ 099899 24730.
Aug 19, 2010 | Cameras
How to install wireless adapter?
Hello faiz
you can download driver for your adapter from here
Click here to Download
actually this device is plug and play hardware but if you still having problem to install this adapter download driver for your adapter then install run the setup.exe file then plug your adapter when prompt
Regards
Manish
Apr 08, 2010 | HP bt450 Bluetooth Wireless Adapter
Can't Get wireless to work
first: - goto the PC website and download the wireless driver
http://www.gd-itronix.com/index.cfm?page=Drivers:Selection&locale=en_US under XP it has this device GIGAWLAN V.5.2.0.117.07
HOW TO USE:
1. Download the .EXE file to a directory on your hard drive.
2. Execute the downloaded file, and follow the instructions.
3. After the files are unpacked, the folder containing the extracted setup files should open automatically. The setup program (utility\setup.exe) is located in the "utility" directory and must be run to install the software
I would remove the wireless adapter from the device manager - right click and uninstall Now reboot the PC - it will detect new hardware, and start to install the wireless adapter, it should now automatically find the driver from. if not when asked browse to the extraction files
Hopefully the switch and light will now work - and wireless will be enabled
Feb 18, 2010 | General Dynamics Itronix GoBook Notebook
I keep losing the connection to my Linksys N router...why??
1.Primarily, if you use a N standard wireless router, you must go in for the same N standard adapter, to get full efficiency. You didn't mention the model no.
2.If you have any other wireless computer in your house, check with that if it also has the same issues. Try checking with new and old wireless devices.
3.If finally, you conclude that its only this Belkin adapter that is responsible for intermittent connection, then:
3a. Uninstall the Belkin adapter's utility and drivers from control panel(Add/Remove programs)
3b.Go to http://en-us-belkin.com/support and download the latest drivers for your model.
3c. Unplug the adapter and run the downloaded setup file. (Setup will walk you through from here)
But i could have helped you better if you had mentioned the model or part number along with the version of it.
Anyway, this would certainly work.
Jan 24, 2010 | Belkin N150 (F6D4050) 802.11g/b Wireless...
Problem with Casio xj-s35 projector
You have to disconnect power to reset it.
Nov 08, 2008 | Casio XJ-S35 DLP Projector
Please help me
You need to download drivers, atherwise, network adapter and other devices will not work.
Download drivers from here: Acer - Service & Support, Drivers & Utilities, Downloads
After downloading drivers you will need to setup again your network providing the network key.
Check also that the network adapter is on , there is a switch on the laptop to turn it on and off.
Nov 06, 2008 | Computers & Internet
On my laptop, I cant connect with wireless connection.
1. were you ever able to do it before?
2. first.. check your wireless adapter is on and you have a light showing you adapter is on (blue or green).. on some compaq laptops if you get an amber light and the switch is on the on position the wireless adapter may be faulty and your motherboard may have to be replaced.
3. check also you are within range of your access point (router).. usually on the system tray (where you clock is ) you will see icons showing you are within range or not (ex. a computer flasing a little blue light with some waves to right).
4. find if your computer detects your wireless adapter (go into start>right click my computer>properties>hardware tab> device manager... and look under network adapters! if you see your wireless adapter make sure you don't have a ? or a ! sign next to it.. if you do you may need to update the driver or reinstall the driver of this device. check the cd that came with the adapter or using another computer download the setup file/driver from the hardware manufacturer of your device and using a flash drive move it to the system you're working on and install the appropiate driver for your operating system.
Sep 21, 2008 | Computers & Internet
Lost cd rom to download Linksys wireless G notebook adapter
Hello there.
You can download the drivers (that are usually on the CD) from here. Please select your 'Version' from the list. You can look at the back of the device to find out which one you have, as there are many called WPC54G. Then after choosing the version click GO then click on 'Driver' to start the download.
This will let your wireless device function on your laptop computer.
Hope this helps.
Jul 02, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Casio YW-3 - Network adapter - 802.11b, 802.11g, 802.11n Logo
100 people viewed this question
Top Casio Computers & Internet Experts
k24674
jackcity
jackcity
Level 1 Expert
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
