Looking for repair center near Belmont,Mass. ?? in need of a 50K Ohm Potentiometer and knob, the 50K Ohm is a part # 31190335 it is for a Peavey XR-600B
  • 604 Answers
You might try Radio Shack for the pot, also a larger music store with or without repair dept, typically stock various pots like that, some with audio taper and some with linear taper Also if Radio Shack doesn't actually have it in stock they have an extensive parts suppy catalog in the store, also Allied Radio out of Chicago is another option, good luck
Posted on Mar 24, 2011
Can a Potentiometer RV4LAYSD503A 50K Ohm 19-8351 be replaced with RV4LAYSA503A Potentiometer 50KOHM
I don't know but the similarity in part number would suggest one is a revision of the other or originates from a different manufacturer.
If they are dimensionally similar it would be worth a try if the correct replacement isn't available. The main thing to watch out for could be differences between the tracks of the two types.
There are four types of carbon potentiometer tracks; linear, logarithmic and anti-clockwise versions of those two. Linear types tend to be used for adjusting voltage whereas log types are about sound. Used for volume controls they closely mimmick the logarithmic response of human hearing.
The difference is easily recognised using an analogue ohmmeter.
Fitting a linear in the place of a log type would likely mean most of the adjustment would be bunched at one end of the track.
Although manufacturers tend to give spare parts of their own products fancy part numbers, very few are specially made and most are sourced from catalogues of generic parts. It is often cheaper to take a look in constructor catalogues and those supplying parts to the repair trade before resorting to manufacturer's spare parts.
Jan 02, 2016 | Cars & Trucks
I have gps 900 peavey the problem is motorboating sounds,can you help me please
Usually, motorboating is caused by a bad capacitor, either in the input section OR in the power amp section (large capacitors) . If you do not know about amplifier repair, you can zap yourself easily if you do not properly discharge capacitors before repair. Do not take a risk of electrocution to save a couple of bucks and possibly do more damage to your unit. Call Peavey for a service center near you.
Dec 20, 2014 | Peavey Audio Players & Recorders
The loudness knob has suddenly stopped working. The knob just spins, won't turn on the receiver at all. Any ideas?
The knobs are usually connected to a potentiometer; basically a variable resistor circuit with a long shaft that the knob attaches to. The knob could be secured to the shaft with a plastic grommet, which can be stripped. It could be attached by a small screw on the knob, and tightening that would fix it. Or, it's possible that the potentiometer itself broke, and would need to be replaced.
If the "pot" is broken, a repair shop should be able to fix it for less than $50. If you're handy with tools, you can take the 7100A apart; hopefully read the specs from the potentiometer; and buy a new one. Replacing it shouldn't take more than a few screwdrivers, some pliers, and a soldering iron...
Feb 06, 2011 | Sherwood 7100A Receiver
Looking for replacement components for my peavey speakers 2 x 15 inch 2 x tweeters 2 x crossovers 2 x horns all above for 15 inch peavey eurosys 4 product 15005760 2 x 12 inch 2 x...
Fixya doesn't do prices or delivery. We only supply information. See the link for spares suppliers including Peavey themselves.
Peavey Replacement Repair Parts, Speakers, and Accessories
https://www.simplyspeakers.com/peavey-speaker-repair-parts.html
Factory replacement Peavey speaker parts, diaphragms, replacement baskets. ... Peavey 1208-8 SPS BWX Factory Speaker Basket, 12" Black Widow, 8 Ohm, 00560770. Peavey SP-15825 Factory Speaker Basket, 15" Scorpion, 8 Ohm, 00015040.
Peavey - Replacement Speakers, Raw Drivers ... - Parts Express
https://www.parts-express.com/brand/peavey/339 Results 1 - 16 of 323 - Welcome to the Peavey Store at Parts Express. Peavey was founded in 1965 and is now one of the best known names in professional audio. With innovative products such as their field replacement baskets, powerful amplifiers and PA speakers they have become a mainstay of musicians around the ...
Speaker Components - Peavey.com
https://peavey.com > Support From the Low Rider™ sub woofers, with incredible power handling capacity and impressive bass response to the steadfast Black Widow® and BWX™ speakers with replacement basket assemblies, the Peavey line of speaker components is consistent and innovative. Think it might be difficult to make up your mind what ...
peavey speaker spares Google Search
Dec 23, 2017 | Audio Players & Recorders
I'm missing the volume pot and dont know which one to buy. Its a champion 30 dsp fender guitar amp. Thanks
There are two volume controls. One is "drive volume" the other just "volume"
The plain volume control is a 50K ohm, linear taper.(A) old marking
The Drive volume is a 100K ohm Log taper.(C) old marking
Find suitablel parts at DigiKey.com or Mouser.com or find a Febder repair center to order the part.
From other than Fender, You may have to shorten the shaft with a hacksaw to match your needs.
Jan 10, 2010 | Fender Fm25dsp 1x10' Guitar Combo...
The volume knob has broken off at the base on chan 1 of my peavey KB100 keyboard amplifier. part needs replacing in NW London?
Was it the know or the pot? The pot is the metal(sometimes plastic) shaft with a nut securing it to the enclosure.
Here is your nearest registered Peavey service center. http://www.peavey-eu.com/support_2_detail.php?flag=GB&lan=UK&var=ser&key=SERVICE
This could also be repaired by someone with electronics knowledge. Just would need to know the pot taper and resistance. This would be on the front of the pot on the same side as the shaft. The enclosure would need to be taken apart.
Jun 21, 2009 | Peavey VTB1 1-Channel Amplifier
Looking for a schmatic for the 410 tvx 4 ohm and the 410 tvx 8ohm cabinets
Go to www.peavey.com/asstes/literature/specs/005584220_3.pdf. Apparently the 410 TVX can be used in 4ohm or ohm configurations just don't drop below 4 ohms and make sure your amp has the minimum required impedence. Hope this helps.
May 26, 2009 | Peavey Music
I have a 1983 popeye arcade machine. the circut board that controls the vert hold for the monitor has 4 knobs for vert., sound, horiz., and bright. thevert. hold knob is busted off and the screen has...
VR353 is a 200k pot that feeds directly in to the vertical oscillation input of the chip on the main board at connection B1. If this pot is broken, you must replace the pot in order to get any vertical oscillation at all.
Sep 10, 2008 | X-Gaming X-Arcade PC Joystick (XGMPC)
More info for you
The pot is a 50k ohm audio taper pot with an integrated switch. The shaft is called a "D" shaft and is used with knobs that have a set screw. The 3 pins are the for the resistance with the center pin being the wiper. The other two pins are for the on & off switch.
It's going to be hard to find the exact replacement without knowing the manufacturer of the pot. It looks like the one you have is soldered to a PC board and the pins have to be in the right spot on the new pot order to match up with the PC board.
What you can do is buy one with solder terminals. Rotate the pot so that the terminals are facing up and just solder wires from the terminals to the PC board. If the shaft is to long, you can cut it down with a hacksaw.
I am looking for sites for you to call. here's a few I found thus far:
http://www.farnsworthelectronics.com/potentiometers.htm
http://www.ctscorp.com/components/potentiometers.htm
Jul 14, 2008 | Boston Acoustics BA735 Computer Speakers
Guitar amp
You can order parts directly from Peavey. You'll have to call to place the order. You can use the followng email address to check price and availability.
parts@peavey.com
For more information, the third question/answer in the list of FAQs has the phone numbers.
http://www.peavey.com/support/faq/index.cfm
Oct 14, 2007 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
162 people viewed this question
 Grubhead
Grubhead
