Question about Zanussi Washing Machines
How easy is it to change the main bearing on a fla1001w
  • 822 Answers
Only easy if you know what your doing..........
cheers
Posted on Mar 24, 2011
I need to change the main bearing and seals in the engine. Is this an easy job? Are there any special hints /tricks I should know about?
no tricks about it. get a crank kit with the bearings to do this right or your wasting your time and money
A shop manual sold at auto parts stores is a great investment to have also
Apr 17, 2011 | 1995 Suzuki Swift
What is the easy way to fit a drive belt to a zanussi washing machine fla1001w
Disconnect from the mains.
Remove the back, slacken the clamp bolts holding the tension on the old belt next to the motor.
Fit the new belt, tighten the tension on the belt and tighten the clamp bolts.
Feb 23, 2011 | Microwave Ovens
What is the easy way to fit a drive belt on to a zanussi fla1oo1w washing machine
Here are my general notes for broken or slipping belts and includes a comment on motors which you presumably can ignore. I hope they help you ;-0)
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If it turns out to be the motor, it is false economy to just have the brushes changed. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished.
Hope this is your problem solved.
Good luck,
John C
Feb 23, 2011 | Zanussi FLA1001W Front Load Washer
Zanussi zwf 1221w drum bearing replacement, is this an easy job to do
This is not an easy repair to carry out, it involves a complete strip down of washer, and removing the whole drum assy from the washer, and until it is stipped down, you will not know if the drum shaft is worn, if it is, then this puts it way beyond an economical repair.
Feb 02, 2011 | Zanussi FLA1001W Front Load Washer
My Zanussi FLA1001W will wash but will not sin or
Check the impeller on the pump free to move. if ok check electrical connections. if ok either pump is faulty or it could be main pcb (or both)
Oct 17, 2009 | Zanussi FLA1001W Front Load Washer
Torque specs.
connecting rod = first pass 18 ft lbs , second pass 75 degrees
main bearings = first pass 37 ft lbs , second pass 77 degrees
wow that wasn't easy to find for some reason .
Jan 01, 2009 | 2005 Chevrolet Impala
Noise
yer get a long bar stick in the hole large club hammer and simpley smash them out good stress release
Jan 26, 2007 | Zanussi FLA1001W Front Load Washer
Washing Machines Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
