Question about Motorola Talkabout T5720 (7 Channels) 2-Way Radio
Just a question,approx what range dose T5720 have approx flat land. Thank you.
  • 255 Answers
It has a limited range.You might get a 3-5 mile range over flat land.
Posted on Mar 24, 2011
Where is fuel filter
Many possible causes of symptoms, but if it is a filter the Access door is left underbody approx 6 inches towards middle of car from posterior jacking point, Part Number WFL000021
Nov 18, 2012 | 2004 Land Rover Range Rover
Why is not possible to communicate from T5720 talkabout to T5422 talkabout?
The two radios share no frequencies in common. The T5720 has the US frequencies classified as FRS and GMRS, between 462-467 MHz. The T5422 has the UK frequencies classified as PMR and dPMR which are in the 446 MHz range.
A list of UK frequencies can be found in this forum: http://www.transmission1.co.uk/forum/viewtopic.php?f=4&t=23400
Best regards.
Oct 01, 2012 | Motorola Talkabout T5720 (7 Channels)...
Why is my 2002 land rover range rover overheating when i drive, but not at idle?
Hello, thuglordone and thank you for asking your question on Fixya!
Here is a simple process that will walk you through a few steps that will pinpoint the overheating problem on your
2002 Land Rover Range Rover, without even using any tools. It has helped millions of people, and I am certain that it will help you, because I wrote it for people in your exact situation.
How to diagnose your overheating
Get more great money saving tips and tricks about your vehicle from: twitter.com/acoates23234
Thanks for the vote, and good luck!
Nov 07, 2010 | 2002 Land Rover Range Rover
Hi range rover 2004 i think that mr brakes warning sign is come up on my dash borad dose any body no what the sign looks like ?
yes...it's as same as the Hand Brake Sign light. if it's NAS Spec's then no sign. only Hand Brake Light will remain on. but you still will be getting a message in the message center says Check Brake Pads
Jun 16, 2010 | 2004 Land Rover Range Rover
Frequency range
The T5720 has
- 7 GMRS/FRS 1 watt Channels
- 7 FRS 1/2 watt Channels
- 8 GMRS 1 watt Channels
All of these frequencies are between 462-467 MHz. There is a list of the specific frequencies assigned to each channel on page 19 of the user guide. Here is a link http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Best regards.
Jun 16, 2010 | Motorola Talkabout T5720 (7 Channels)...
I want to know talk range of Talkabout T5720
Handheld radios generally will talk "radio-to-radio", "line-of-sight" up to 2 miles. Once you start putting obstacles in between the radios you will shorten your range.
Advertising literature will sometimes give numbers such as "5 mile range". While this is possible in ideal conditions, it is not common in real-world situations. HEIGHT and PLACEMENT of the antenna determines the range of the radio. Example: Talking from a mountaintop you could talk far into a valley below, much further than the expected 2 miles. However, if you were to be in an congested city, you may only be able to talk a single city block due to obstacles.
To get the best range, use a well charged battery pack, wear your radio high on your body, and always hold the antenna perpendicular to the ground when using the radio.
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Apr 08, 2010 | Motorola Talkabout T5720 (7 Channels)...
RPL & TPL tones used in T-5720
The T5720 user manual does not list the TPL codes possible in the radio. However, they are the standard list, with zero being "open squelch" (no code). Here is a link to a Motorola manual which has a list of the PL codes in order on page 43. http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
On the T5720, another item to what for is the Qt noise filter. Be certain to set it to zero unless using the T5720 with others of the same model. It can also block transmissions. Here is a link to a user manual for the T5720 http://lib.store.yahoo.net/lib/starbattery/T56XXusersguide.pdf
Sep 22, 2008 | Motorola Talkabout T5720 (7 Channels)...
Motorola Talkabout T5720 user manual
Hello cataway43,
These type of low power handhelds are good for "line of sight" communications and their range is very dependant on local geography. Over level ground with no obstructions you can expect about a mile of effective communications range, on average. If you are operating in an area with decreased line of site due to obstructions such as tall buildings or heavy vegetation then the range will be decreased; likewise if you are in an area with increased line of site (such as on top of a tall hill or mountain) you can expect increased range.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 06, 2008 | Motorola Talkabout T5720 (7 Channels)...
Hello kenyond,
The range that you can expect to see when using two-way radios is very dependent on local conditions. These radios are very line-of-sight dependent. Obstructions like mountains, hills, tall buildings, thick vegetation, and using the radio in a shielded environment such as inside of an automobile can block your line of sight and limit your effective communications range.
That “maximum 5 mile” advertised range is probably only practical in a situation where the user of one of the radios has some significant elevation (such as being on top of a tall hill) and therefore has increased line of sight. When communicating over relatively level ground that is clear of obstructions, you can probably expect a reliable communications range of about a mile.
Best Regards,
Agent Ken
"Go Ahead. Use Us."
Jun 28, 2008 | Motorola Talkabout T5720 (7 Channels)...
Talkabout T5720 Frequencies
Hello Ruaal,
The frequencies in the TalkAbout T5720 are not adjustable. The radio operates on the designated Family Radio Service channels located at 462 and 467 MHz. There is no way to change these channels to be at 463 and 464 MHz.
Best regards,
Ken
Go Ahead. Use Us.
May 14, 2008 | Motorola Talkabout T5720 (7 Channels)...
Motorola Talkabout T5720 (7 Channels) 2-Way Radio Logo
105 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
