Printer is only printing part of requested document onto A4 paper
  • 17,130 Answers
Possible that there are errors in the drier software and so needs as reset. So remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
Posted on Mar 24, 2011
  • 54 Answers
Set the paper ( a4, portrait, corresponding tray etc) from printer setup, and, after , check ( clean and reintiliase the printers cartridge and printing heads ( from the printer maintenance software)
Load A4 paper in the multi-purpose tray again,and then press [paper] to print. error shown in LBP2900B
If you normally print on letter sized paper, then some program you are using is trying to print on A4 paper (PDF files often the culprit) and the default on most printers is that if they do not have the paper loaded it will ask for it from the MP tray. You can check your printer settings as you may be able to tell the printer to automatically sub letter paper when A4 is requested.
Sep 20, 2015 | Canon LBP2900
Special paper tray is empty error
Sounds like someone requested A4 size paper in a print job instead of the normal Letter size paper...
Try putting regular letter size paper in the bypass tray and then set it up as A4 size...the print job should then print out on that paper.
Apr 09, 2014 | Xerox WorkCentre C2424DN All-In-One Laser...
Load mp feader a4
Please determine what size you are trying to print (A4, Letter, Legal, etc.). The printer is requesting A4 sized paper in the maunal paper feeder becuase either you selected manual feed or the setting for the default try (usually tray 1) is not set to the correct paper size. In your case, make sure the green slide adjustment on tray 1 is set to A4.
Mar 22, 2014 | Lexmark T632 Laser Printer
I have a hp photosmart c4280 and whenever i print it says margins are incorrect. how do i set them correctly so i can print documents.
Check the paper size at the printer properties on control panel.
You may be trying to print an A4 document to a printer configured to print on Letter size paper.
The document paper size should match the printer's paper size deffinition.
Nov 10, 2010 | Computers & Internet
When printing paper jams after the second page.
Clean the pickup roller with a damp cloth, check whether transfer roller under toner cartrige rotates freely. Check if the size of the loaded paper is the same of the document in the application, i.e. if you print on A4, your document should be set to A4. Sometimes you may receive a document by email with different paper format from what you expect. Reformat the document as setting the page size to your loaded in the printer one.
Jun 14, 2010 | HP LaserJet 3330 All-In-One Printer
Load A4
A4 is for european size, if you are printing on a letter size this is a mismatched.
you need to change your files printer properties to A4 or letter size, or change your printer paper size.
better yet cancel this document and send it again , this time by checking the printer properties was set to your desired paper size
Jul 28, 2009 | HP LaserJet 2840 Printer
Will not print A4
Go through the paper settings on the front panel of the printer and ensure the paper trays are set to "Plain A4".
I usually set "override A4/Letter = Yes" too as many programs / documents / PDFs assume US Letter size.
Jan 27, 2009 | HP LaserJet 4 plus Printer
Printing from wrong tray
Go to printers and faxes and right click and properties on your printer!! Then select Advance, then Printing defaults!! In there select paper size A4 format. And in Word go to File, Page setup and select page size A4!
Jan 24, 2008 | Office Equipment & Supplies
Printing an A3 document on an A4 printer
Set your paper size to A3 - it should print out the docs on two seperate sheets of A4.
Oct 11, 2007 | Konica Minolta Magicolor 2450 Printer
Problems printing an A4 document in A3
Ensure that the desired paper is set in a paper tray of the printer and select [Auto] in the paper selection of the printer driver. You may need to configure the margins in the sofware you are using. hope this will help you Daniel
Feb 01, 2006 | OKI B8300 Laser Printer
29 people viewed this question
k24674
jasbo
jasbo
