Question about HP PSC 1610 All-In-One InkJet Printer
I have a 1610 series printer/scanner and my black cartridge needed replacing. I have bought 2 cartridges--I from HP and 1 from Currys (a replacement for the 338 cartridge) but both give me a error message reading the 338 cartridge is not intended for use in this printer. My old cartridge was a HP94 but that is no longer available. Any ideas,please?
  • 51 Answers
Hi Hp 49 is available in the UK I just looked it up on www.amazon.co.uk from about £10.00 for the small ink one and about 20 for the bigger ink capacity.
I repair printers for a living and I have not heard that the 49 was out (that said I the first person to be told) Hope this helps Ian
Posted on Mar 24, 2011
  • 54 Answers
You must buy one of the following:
http://h10010.www1.hp.com/wwpc/us/en/sm/WF06c/A10-12771-64199-69422-69422-397352-1130055-3218160.html
or
http://h10010.www1.hp.com/wwpc/us/en/sm/WF06c/A10-12771-64199-69422-69422-397352-397354-397358.html
Chsnge ink cartridge
Hi there!
Here's what you can do to change the Printer cartridges.
1. Make sure that the printer is turned on. Turn it on if it's not.
2. Open the printer cover, then wait until the carriage is idle.
3. You will see the Tri-color & the Black cartridge. The tri color cartridge is the green one which is on the left and the Black is the one on the right.
4. Press down the Cartridge you want to replace you will notice that it will be released from the cartridge holder. Once it's loose slide the cartridge out.
5. Make sure that the correct Genuine Hp Cartridge is what you have. For your printer HP PSC 1610, HP 94 will be for the black and HP 95 is for the tri color.
6. Open the cartridge package. Remove the protective tape. Make sure that you do not touck the copper colored contact and nozzles.
7. Hold the print cartridge with the sticker facing up and the copper colored contacts facing the printer and slide it into the cartridge.
8. Use your thumb to push the cartridge all the way in. You may need a little force to make sure that the cartridge has been installed securely.
9. Once installed close the cartridge cover. Make a copy to test.
Hope this helps!
Jun 17, 2011 | HP PSC 1610 All-In-One InkJet Printer
When I try printing from our printer it tells me to check colour ink cartridge, I take it out an re-insert it. Then the printer tells me to align the printer paper press start. I do that and then it starts...
I had the same problem on mu HP 1200 series all in one printer; I have two of the same printers.
I couldn't believe that the ink cartridge was the problem because BOTH cartridges, black and color were fairly new and giving good copy results;
Finally after taking the printer apart, checking transformer and gears, and cleaning up the cartridge faces... STILL the same problem;
I replaced the both black AND color cartridge with a brand new one, and it worked perfectly.
So now I am stuck with 2 cartridges, half-used, that the printer will not accept.
Jan 13, 2011 | HP PSC 1610 All-in-One Printer, Scanner,...
I don't know what kind of ink to get for my all in 1 hp psc 2355v
For h.p. 1610 all in one printer. Both cartridges : hp94/95Black/Color combo. If you want to buy them seperately hp 94 Black, Color is hp95 color. Most office stores (staples etc) sell them.
Nov 17, 2010 | HP PSC 1610 All-In-One Printer, Scanner...
My HP 1610 printer/scanner is giving me instructions to "remove and check right cartridge". This came after replacing the black ink cartridge.
yes this happens when you have seated your cartridge wrong, placed in the wrong type or even something as simple as forgetting to remove the thin layer of plastic after taking it out of the package try these options before assuming something is broken i hope this helps!
Dec 22, 2009 | HP 1610 OfficeJet All-In-One Printer
Can u use the scanner on a hp pcs 1610 all in one inkjet printer without the color ink cartridge?
Hi, the answer is no you cannot, the printer will only work if both cartridges (black and color) are installed, if you install just one the check print cartridge light will flash.
Hope this helps
Muzzi_123
Nov 14, 2009 | HP PSC 1610 All-In-One InkJet Printer
Black re-mfg for psc 1610 prints unreadable
your black print cartridges has been dried, these need to replace.
Aug 22, 2009 | HP PSC 1610 All-In-One InkJet Printer
HP 1610, Remove Cartridge message
also replace the colour cartridge as it is not showing but the printer is not able to detect that cartridge also.many a times it solves the problem.
Sep 30, 2008 | HP PSC 1610v All-in-One Printer
HP 1610 Won't Recognize the Color Cartridge?? Please Help!
i don't know who checks these messages, but I have the exact same problem, also with my mom's printer. it is no longer under warranty so HP wants to charge me thirty dollars for them to tell me how to fix it over the phone. no thanks.
Jun 04, 2008 | HP PSC 1610 All-In-One InkJet Printer
Test sheets will print, but nothng I try to print works
Remove the 1610 printer using add remove programs adn the reload it. Sound like software rather than hardware
Apr 21, 2008 | HP PSC 1610 All-In-One InkJet Printer
My Lexmark is X6100 Series - Cartridge Error 50C consult user guide
Cartridge Error 50C
Your print cartridge has shorted.
1. Power off your All-in-One and unplug it.
2. Plug in your All-in-One again and turn it on.
3. Uninstall and then reinstall your cartridges.
4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
1. Power off your All-in-One.
2. Use both hands to lift up the scanner unit until the scanner support holds it open.
3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
4. Remove the color print cartridge.
5. Lower the scanner unit until it is completely closed.
6. If the error message reappears, replace the black print cartridge with a new print cartridge.
If it does not repeat steps 1-3 and then go to step 7.
7. Reinstall the color cartridge and remove the black print cartridge.
8. Lower the scanner unit until it is completely closed.
9. If the error message occurs again, replace the color cartridge.
10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
11. Lower the scanner unit until it is completely closed.
12. If you receive the error message again, replace both cartridges.
Jan 14, 2008 | Lexmark X6170 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
258 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
