Question about Microwave Ovens
Hi, I have bought a Lavazza coffee machine in November at Selfridges London, 2 months later the water was not going trough. I returned it to Selfridges to get fixed. And now the problem seems to occur again!!!!! I am very disappointed and would like some assistance. Could you help me please? Kind Regards, Caroline
  • 56 Answers
Hello, It sounds like the pump has gone. You can try cleaning the machine by running vinegar through it and cleaning any of the blockages with a bit of wire. Only use wire when it is switched off. Try running the vinegar first with hot water and then cold. And remember to rinse it out when you are finished. If that doesnt work Im afraid you will need a new pump. I hope that has helped you.
Posted on Mar 24, 2011
Not heating
Return the microwave oven to the place of purchase, this is a manufacture defect.
May 07, 2012 | Emerson Microwave Ovens
We have a 12 cup Mr. Coffee about a year old. We put 4 scoops of coffee in and the appropriate amount of water. Every day, the filter overflows and grains of coffee get into the pot. How do we keep this...
Because I own a espresso company,I believe I can help you. There is several things that can cause a coffee machine to over flow. 1, putting to much coffee in, where water can not drain through filter. 2. The grind of the coffee, if it is ground to fine, like ground for espresso, will not allow coffee to flow through filter , drip machine that are not under high pressure like espresso machines have to have ground more course. 3, wrong type of filters, not fine enough for water to flow, or made for high pump pressure machine such as espresso machine . 4, putting to much water in, is not an issue on a mr coffee, because even if you fill it to full cup line, it would have nothing to do with filter over flowing, besides the coffee grounds always absorb some of the water anyway. In conclusion, my positive professional diagnose is Grounds of coffee to course, and 4 scoops seem a bit to much for a filter of a mr coffee machine that holds only 12 cups. To test this is make a pot same way and use only two rounded scoops and see what happens, if does not over flow that solves that. But your saying I want it stronger, believe me I know. I too like my coffee strong and a flavorful . I have that solved too. Go to a good walk in espresso shop, like a star bucks, tell them you want some good strong blend and have it ( Ground for Drip) and then still only put two rounded scoops, it takes less do to the blend and kind of coffee. Please let me know if my advice worked, thanks mike. oh notice my screen name of mc1 bean, now you know, I know what I am talking about :)
Jun 07, 2011 | Microwave Ovens
Hi I have a Lavazza Modo Mio Type SIN 029. I find that after I have primed the machine and followed all of the instractuion that my espresso is cold to luck warm. If left for 10 seconds it would be...
Pod machines never make boiling hot coffee but this sounds like the heating unit isn't working. I am not aware of anyone that repairs this sort of thing other than the actual manufacturer. If it is new take it back to where you bought it. If not, it might be cheaper and easier just to buy a new one.
Jan 16, 2018 | Microwave Ovens
I can;t find manual and I want to clean my keurig coffee maker
You may be able to find the User Guide for your Keurig machine here:
http://www.keurig.com/customer-service/brewer-registration-and-support/user-guides-and-help
Your brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar. Full de-scaling insturctions can be found here:
http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/FD69E91A51CA41BEBF4CCAA138325BBF.ashx
Mar 26, 2011 | Microwave Ovens
How do you go about "descaleing" the coffee maker? The water does not flow through the coffee capsule very well.
I know that most grocery stores sell a "cleaner" or two next to their coffee filters/coffee makers/kitchen appliances section. These are usually heavily acidic, and will do a great job of cleaining your coffee maker. I've always been wary of acid in my coffee though, so I just use white vinegar. It'll do a decent job of cleaning out the coffee maker. Run a 1:1 mix of water and vinegar through your coffee maker, drain it, then run water through at least twice.
Scaleing/deposits building up in a coffee maker are signs of imperfections in the water. All tap water has it, but if you don't want to worry about it, use bottled or filtred water in your coffee pot. Plus, your coffee will taste better!
Mar 16, 2011 | Microwave Ovens
I have a keurig single cup coffee pot and after 6 months it strted to act up. I would have it plugged in and it wouldnt brew the coffee. you could not push the blue lit button because it would never...
i hear ya but it sounds like you need to send it back its so new you could get a new one just like it wait a week and return the old ,if you dont have a warranty or receipt for the other dont get cheated
Jan 23, 2011 | Microwave Ovens
Inserted K cup and closed machine. Says Brewing but coffee machine only dispenses a few tablespoons of water...tried turning machine off and off, but same amount of water is dispensed each time, no matter...
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Jan 01, 2011 | Microwave Ovens
Our Magimix 11400 (less than 2 years old) heats normally, the vapour nozzle fonctions too, but our problem : when the coffee selection switch is put on the motors starts up, seems to fonction properly but...
Hello Pat, You have a common occurring problem. Your tubing in clotted. The least expensive solution is to use regular vinegar instead of water for several cycles, no coffee grounds. The clot will dissolve and water flow will return to normal. Cycle just water until no taste or smell of vinegar is present. Have some HOT COFFEE.
Oct 12, 2010 | Microwave Ovens
How much vinergar do put in a 12 cup coffee maker when cleaning it
Howdy, 1 part vinegar to 3 parts water. Pretend you are making a pot of coffee. It is recommended to do this every 2 months or so, more oftenif you have really hard water.
Regards,
Farmerbear at FixYa.com
Sep 11, 2010 | Microwave Ovens
2 months old. bought brand new. and just stopped
These things will happen. You are aware that these appliances have a 12 month warranty so return it to where you purchased it from.
Feb 17, 2010 | Microwave Ovens
Microwave Ovens Logo
53 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
