Question about AEG 23 in. Favorit 50750Vi Built-in Dishwasher
My dishwasher AEG 47030 has a error code i60. The problem is in overheating. it turns always on and doesnt stop, so after running aprox. 30-40 min any programm stops with error code i60. need a good advice for fix that. respectfully Yuri
SOURCE:
SOURCE: how do i fix error code 30?
I did like it was suggested and it functioned! Can't believe it. Actually I tipped the machine over, but not till the end (very slightly). It was a bit water on the ground. I removed it and put the machine upright. Thanks a lot!
Posted on Dec 31, 2007
SOURCE: Dishwasher fail on C3 (leak prevention system)
http://www.kunnig-elektro.de/reparatur/spuelen/aeg/zulauf2.html
in German ... anyway a couple of pictures :)
Posted on Feb 18, 2008
heralddriver
SOURCE: DISHWASHER AEG 80860
Just fixed a similar problem on an AEG F3A by following other advice on this site. Simply tip the machine forwards on to its door (best empty it of crockery first!!!).and then put it upright again when water has stopped dripping out of it. You wil get quite a bit of water on your floor which I reduced by pumping the water out of the salt resevoir first - but if you don't have a pump just have several towels handy
Posted on Oct 25, 2008
SOURCE: AEG Dishwasher FAVORIT 3A Error Message C3
If you open a sidepanel and look at the bottom of the machine you see a brown device with a piece of white foam,this is the leak prevention system.
Push foam down and the error code should be cleared.
Make sure you there's no water left on the bottom of machine
Posted on Mar 05, 2009
BIKER T
  • 909 Answers
SOURCE: AEG Favorit dishwasher AAA shows Error code 10
Normally if washer doesnt complete cycle, its because the element has tripped the over temp.th/stat.(underneath), or is faulty. otherwise 1 of the 2 boards are faulty. Often the board at the bottom front left.(behind the kick panel.)is the issue. Roaches seem to accumulate on the bottom board and disrupt the circuit. If you have a mechanical timer, wiggle it side to side and note if there is a difference.
Posted on Sep 16, 2009
I have a JOHN LEWIS slimline dishwasher JLDWW906. It is showing error i60 which is not in the manual water pressure is fine as is drainage. Can anyone help?
Hello, Isa -
I suggest you contact the John Lewis company directly and ask what the i60 error code means for your model of dishwasher.
This is the link to the Contact Us page for the John Lewis company:
https://www.johnlewis.com/customer-services/essential-information
Best wishes.
Mar 07, 2018 | John Dishwashers
How do I fix error .60?
The temperature must increase by a certain amount at each step.
If there is no temperature increase, the electronics will generate "Heating Time Out" or fault code i60.
In this case program will continue to the end without heating and the washing result will probably be unsatisfactory.
Could be: Heating element faulty; intervention of safety
thermostats (open); faulty wiring; NTC sensor (poor
thermal contact); insufficient water circulating in the
tub; washing faulty pump (impeller stripped); circuit
board faulty.
Dado
Sep 08, 2015 | AEG Dishwashers
What means error .60?
board faulty.
Dado
Type 60870 not heating water!Have a wiring giagram for trouble shooting?
Could be: faulty power board (completly or only relay for heating element), faulty wiring between heating element and power board, faulty heating element (interruption, short circuit or current leakage,on some heaters faulty thermal protection).
Depending on the model, the display shows the i60 fault code or the LED end of the program will flash 6 times (only model without display).
Dado
Mar 17, 2015 | AEG 24 in. Favorit 60870M Free-standing...
I have a AEG Favorit 65011 VI (dishwasher) which stops in the middle of a programm an shows error ",60" that is not mentioned in the Users Manual. Can you please help me?
If there is no temperature increase during three minutes, the electronics will generate "Heating Time Out" or fault code i60.
board faulty.
Dado
Mar 10, 2015 | AEG Dishwashers
I have an aeg dishwasher showing error code 49 what is this and how do I fix it
Error code E49, generally speaking, at AEG dishwasher does not exist.
Dado
Jan 05, 2015 | AEG Dishwashers
I have an AEG F55002ViOP dishwasher. It's making a strange grinding sound and showing error code 30. Can anyone advise how to solve this please.
Error "i30" means that water remains in base because leakage or overflow. In this case, in order to prevent flooding, drain pump running continuously.
When we talk about AEG dishwasher, drain pump works even the power is turned off (must be connected to the wall outlet, otherwise anti-flooding system will not work).
The noise what you heard during operation indicates that something is blocking the drain pump.
Remedy: you should first remove the water from the bottom of the dishwasher and determine leakage then check why the drain pump makes noise.
If you work around the dishwasher, you always take care that appliance must be disconnected from the power supply.
Good luck.
Dado
Oct 11, 2014 | AEG Dishwashers
What would make my dishlex dishwasher display the error code i60?It runs the wash cycle and stops.
Heating time out. Usually is heting element defective or relay on main board.
Dado
Sep 03, 2014 | Electrolux Dishwashers
AEG 23 in. Favorit 50750Vi Built-in Dishwasher Logo
2,558 people viewed this question
Top AEG Dishwashers Experts
Paul Carew
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
