Question about Texas Instruments TI-84 Plus Calculator
When i put in a solution i get this err :syntax
  • mattp222 Mar 25, 2011
    What is the problem you put in to the calculator and how does it look before you hit enter?
  • 26 Answers
This typically means that something you're inputted didn't follow what the calculator expected for a given input. This can happen if you put something in like "6++5" -- the calculator doesn't expect another function sign after "+", it expects something that has numerical value like a variable or an actual number! You can fix this by hitting [2] on the error screen, which will take you to the place where the calculator stumbled on the problem. From there, you can doublecheck what you typed in and try it again.
Posted on Apr 11, 2011
ERROR SYNTAX
Error Syntax mean that the structure of the entry is incorrect. For example, x+-y (x plus minus y) is invalid; whereas, x+ (-y) (x plus negative y) is correct.
Apr 01, 2013 | Texas Instruments TI-89 Calculator
Err syntax pops up when trying to graph
You have a syntax error in the function you're trying to graph. Could you post the function in question?
Jan 17, 2013 | Texas Instruments TI-84 Plus Calculator
What is ERR:SYNTAX on ti-84 plus calculator
If you want to correct the error you will have to disclose what you were trying to calculate.
Anyway, each command has to be written in a specific way ( a specific sequence of symbols) to be understood by the calculator.
Foe example, if the command is sin(X) you cannot write it as sin() X or X sin. You must respect the way a command is to be entered, otherwise you get rubbish or a SYNTAX ERROR message.
Usually the calculator will ask you GO TO or QUIT. If you choose GO TO the cursor will jump to the place where the error occurred and you may be able to correct the syntax.
Apr 14, 2011 | Texas Instruments TI-84 Plus Calculator
When i did y= and put in -x+3 for Y1 and (x-1) divided by -3 and hit graph, it says ERR:SYNTAX please help. im trying to solve linear systems by graphing.
Try rewriting your equations in the equivalent forms that follow.
Y1=3-X
Y2=(1-X)/3
If you do not get a syntax error it means that you were not using the correct minus sign.
If the - is the first symbol after the equal sign you must use negation (-) or change sign key.
Similarly, after the division / key you must use the negation or change sign (-)
Oct 07, 2010 | Texas Instruments TI-84 Plus Silver...
How do I set it to factory default settings? When I want to graph or want to do a zoom fit I get a ERR:SYNTAX 1:quit
Seems unlikely that you get a syntax error for both graphing and Zooming. Probably the error is in the function you are trying to graph.
To reset the RAM,
Press [2nd]MEM][7:Reset][1:All Ram][2:Reset] [ENTER]
Calculator answers with Ram Cleared.
Press [CLEAR] button to erase the above message.
Once Ram is cleared, open the [Y=] function editor and at the Y1= line, enter [X,T, theta, n] key or [ALPHA][X], to draw the simple function Y1=X.
If that works, that means your calculator is OK.
Jan 19, 2010 | Texas Instruments TI-83 Plus Calculator
I bought a used TI83 for my Teacher Certification Exam. I am unable to follow the very first problem of the Instruction Manual. I went as far a step # 5. On step # 6 I could not get -.666666667 as one...
An error in syntax in a software usually refers to in input error.
You may be you may be skipping step or using the wrong input term, or key.
It does not refer to the problem,but the input processes
.Hope this helps.
Nov 03, 2009 | Computers & Internet
ERR:SYNTAX
try to change the mode to function otherwise im stumped
Feb 04, 2009 | Texas Instruments TI-84 Plus Calculator
ERR: SYNTAX
Ok i had the same problem- If i remember correctly my "window" was messed up. Check it out... If not i always pull the "take batteries out while on" trick which resets the ram.
Sep 01, 2008 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Calculator Logo
35 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
