Question about Caterpillar Shelk Shoes for Men
I am feeling it tight what is the solution - Caterpillar Shelk Shoes for Men
My steering feels tight
Hello, Check your power steering fluid to make sure you aren't low. This could be the reason it feels tight.
Nov 01, 2017 | Cars & Trucks
How can i open my old samsonite briefcase combination unknown
1. Pull the sliding side latch to the side,
as you would if you were opening the briefcase normally. Holding the latch in position, lightly roll your fingers
down over each numbered wheel to identify which one is the tightest. The tightest wheel will give the least when
you gently tug on it with your fingertip.
2. Set the tightest wheel to "0." Check the tightness of the other two wheels; if they still feel loose, click the zeroed lock to "1" and feel the other two wheels again. Keep going in this fashion until one of the other two wheels feels tight. When one of the other wheels becomes tight, the first wheel is set at the correct number.
3. Move on to the second tightened wheel, continuing to hold the side latch in place. Set it at "0" and check the final loose wheel. Keep adjusting the second wheel, as you did with the first until the third wheel feels tight.
4. Set the final wheel at "0" and adjust it until the briefcase's top latches pop open. Make sure the sliding side latch is still being held in place.
5. Reset the combination to numbers you'll remember in the future. Write them down and store them in a safe place, just in case.
Jan 06, 2017 | Luggage & Travel
When changing the front brake pads is it suppose to feel tight
is what supposed to feel tight ?
.... remove old pads , clean calipers , push back pistons ... add anti seize to backs of pads ... reinstall , check brake fluid is at correct level , go for a ride , ... get up to about 50 kph , then apply brakes in a progressive manner to bed brake pads in , do it 5 times , to make sure ...
May 22, 2014 | 2005 Honda CB 750
It feels like the gears are binding up but the belts are not tight?
When's the last time it had a professional cleaning and lubrication? My guess is the lubricants have solidified. Or you may have a warped or wobbly or missing tooth in a gear or three.
Mar 17, 2014 | Singer CG500 Mechanical Sewing Machine
The top tension is very tight
check that there are no pieces of cotton or other matters stuck. Turn the tension to its most loose position and by hand move a string of cotton through the tension slot. If it feels tight, remove any foreign matters and then slowly tighten it again to suit your needs..
Jan 12, 2014 | PfaFF Creative 7570
Steering problems in 91 ford festiva.
Sounds like lower control arm is lose. Either ball joint or tierod end are bad or not tight. Check nut for tightness. If tight jack front of car up and shake tire up down left right. That will show you whats lose
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Jan 23, 2013 | Ford Festiva Cars & Trucks
Hi I just bought a 1990 susuki vitara, the power steering is very tight. after driving for a while it came back to normal but pulled to the left. using it the next day it was tight again. When it is tight...
Flush and replace pas fluid to verify fault. It could be in the steering rack.
If no improvement, try disconnecting steering rack from hubs and turn by hand to see if you can feel tightness. Check hubs for freeplay whilste undone.
Jan 11, 2018 | Suzuki Vitara Cars & Trucks
The heater in my 1990 olds wont heat up we checked the fluids they are fine and we put in a new thermostat. the heater just blows cold air
Here's a couple of other things to check;
Make sure heater control valve is working - feel the heater hoses w/heater on. Both hoses should feel warm/hot. Test or replace your radiator cap - it may fit tight but they do lose their ability to hold adequate pressure. Make sure fan belt is tight and not glazed - loose or glazed belts will slip through waterpump pulley not spinning waterpump at correct rpms
Jan 04, 2011 | 1990 Oldsmobile Cutlass Calais
2003 VW Polo TDI 5speed - Sloppy gear lever/shift
It should feel pretty tight, but germans (vw audi bmw porsche mb) put a lot of rubber bits in the linkage and when the rubber wears out, there is more play.
If you want to fix it yourself,  check with the folks at blauparts.com for parts and advise on this.  They have OEM VW and Audi parts and they run a first rate repair shop also.  They will be able to tell you what rubber shift linkage parts are available AND how hard they are to replace.
germanautoparts.com is good for parts also
Dealship is usually most expensive for OEM parts.
Good luck,  when you get the rubber stuff replaced, it should feel nice and tight
Oct 16, 2008 | 2001 Volkswagen Golf
Caterpillar Shelk Shoes for Men Logo
29 people viewed this question
Top Caterpillar Clothing Accessories Experts
Da Doc
ray gallant
Bill Boyd
Are you a Caterpillar Clothing Accessory Expert? Answer questions, earn points and help others
