I was watching TV and recording on a Panasonic HD and the TV just turned off. When I tried turning it back on, the red button on the TV just flashes.
  • 822 Answers
Needs new caps on the power board............
cheers
Posted on Mar 24, 2011
Panasonic tx-48cx400b TV turns off when I connect my Ps4 through hdmi cable. Can anyone help?
Panasonic TX-48CX400B 4K UHD 48 Inch TV (2015 Model ...
www.amazon.co.uk > ... > TVs
Amazon.com, Inc.Buy Panasonic TX-48CX400B 4K UHD 48 Inch TV (2015 Model) at Amazon UK. ...PRO GOLD RED HDMI v2.0/1.4a HDMI Cable 3D 2160p PS4 SKY HD 4K Ultra HD ...This tv offers excellent picture quality through HD sources and Netflix HD and ... TVand PC are both connected to my network switch with Ethernet cables).
for LED TV VIERA TX-48CX400B - Panasonic
www.panasonic.com/uk/.../viera-televisions/.../tx-48cx400b.ht...
PanasonicExplore the Panasonic TX-48CX400B - LED - Uncompromising 4K picture quality is yours with this 4K Ultra HD LED TV featuring an HDMI 2.0 terminal. ... Many describe the 4K effect as feeling more like looking through a window than watching ... Simplyhook up your various devices - such as a Blu-ray recorder or the latest ...Missing: turns ‎ps4
Panasonic VIERA TX48CX400B ' 48 inch 4K Ultra HD 3D ...
Dec 26, 2015 | Panasonic Televison & Video
I have a Panasonic Tx l37S10B tv set, & a PanasonicDVD recorder,DMR-EX768EB. To ensure I receive true HD i have bought a Humax Fox T2 hd Digital receiver. I use these items to receive & record HD...
You didn't fully expain how each device is connected to the others. I don't think you have this set up correctly. Your DVD cannot record in HD so there is no point sending an HD signal to it - it can't process it. This is how I would set it up:
1. Install a 2-way splitter on the input cable
2. Connect output 1 from the splitter to the Humax receiver
3. Connect the Humax receiver to the TV with an HDMI cable
4. Connect output 2 from the splitter to the DVD
5. Connect the DVD to the TV with SCART cable.
This will enable you to watch HDTV via the digital receiver and also provide an input from source (dish/cable) to your DVD player so that you can record.
If you've already set it up this way then it should work. I suspect you've connected the Humax to the DVD and TV and also the DVD to the TV.
Please try this setup and post back if you need further assistance.
Nov 04, 2010 | Panasonic Televison & Video
TV won't stay on
You will have to call an Authorized Panasonic Servicer. Any modules bought from them requires an authorization. Since your not a service center, it's going to be almost impossible for you to do anything. Play it safe and have it looked at.
Aug 20, 2009 | Panasonic TH-50PX75U Plasma HDTV
Can I watch tv with the timer on the dvd recorder turned on?
Hook up the cable wire that comes directly from the wall to the dvd recorder's in connection, then get a 3 ft cable cord and connect from the out of the dvd recorder to the in on the tv. You should be able to set the dvd recorder channel and timer and leave it off. you then should be able to have your tv on and watch any station but to watch the tv with dvd recorder on, your tv should be set to either channel 3 or 4 depending on the switch on back of dvd recorder. I hope this solves your problem. Foxpaw13
Jun 15, 2009 | Panasonic DMR-EZ37VS
Unable to record show on the DVR
Try a hard reboot. Hold the power button on the box till it turns itself off. It will turn itself back on. After restarting try to record live tv. If you can't watch recorded shows either your harddrive may be fried. After thought, a $20 tv tuner card from e-bay for your computer, you could record them to your desktop.
Mar 11, 2009 | Televison & Video
Remote control code
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Panasonic Code: 0051
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Feb 15, 2009 | Panasonic TH-42PZ80B 42 in. HD-Ready...
Panasonic PT-53TWD63, TV will not turn on, Red power light blinks
It is most deffinately a convergence chip issue. The die for no reason. They can be bought online for around $10 dollars and anyone with experience with soldering can replace them pretty easily. I have done it.
Feb 03, 2009 | Panasonic PT-53TWD63 53" Rear Projection...
Direct tv hdbox & Plasma TV & DVD SSound system & DVD recorder
Need to make sure you have the red,white,and yellow rca connection cables ran from the samsung dvd player to the red,white,yellow input on the back of the dvd recorder. Once you do that make sure you put your dvd recorder on line 1 input. If you look closely on the back of your recorder it should say line 1 input. If your recorder isn't on that input you can put the recorder on line 1 input by using dvd recorder remote and pushing the input button. Make sure you don't push the tv input button the dvd recorder remote there should be a seperate input button or a way to toggle the inputs on the recorder. Once you verify all that turn on your tv and go to the input on your tv that you watch the dvd recorder on and you should see what your recording on the tv.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 20, 2008 | RCA RTD155 System
Suddenly cannot record DVD after years
Apologies for the delay in response. Your concern was just brought to my attention.
To your recording, based on your second posting (and would appreciate corrective information where applicable), your system is:
  • Cable provider > Cable Decoder Box > Panasonic DMR-E75V > TV (equipment setup)
  • single coaxial cable > yellow, red & white > yellow, red & white (wiring setup).
With your indulgence, a couple clarifying questions:
  • to watch the Panasonic when you play DVDs, to what channel or source or setting must the TV be set to?
  • to record a TV program/channel, to what channel or source or setting must the Panasonic be set to?
  • what is the brand and model of your Cable Decoder Box?
Initially, pls try:
  • play any known good DVD disc/movie. power on the TV and set to watch said movie;
  • without changing anything on the TV, STOP the playing of the DVD;
  • try changing channel on your Cable Decoder Box's remote;
  • pls post back result(s); or
  • do the above steps again but before changing the channels on the decoder box's remote;
  • try changing/cycling through the different input/source of the Panasonic DVD;
  • again post back result(s).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | Panasonic DMR-E75V DVD Player/VCR
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
