Question about Keurig Platinum B70 Coffee Maker
My keurig is not a year old yet, but I have had problems with it acting like it is going to brew a cup and then nothing comes out. I have descaled and cleaned the pin, still nothing. Now it tells me to descale, but it won't brew. Very frustrating for the amount of money I spent on the machine!
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Apr 02, 2011
The machine will not pump water to make cup of coffee. Cleaned needle area, powered on and off, nothing. The descale light has never come on in 3 years we have had machine. Can't even attempt to descale...
Step 1: Lift up the water reservoir and drop it back into place. There is a magnet that has to be in the right position and putting the reservoir back into place causes it to go back where it should be. This method has worked for me.
Step 3: It could be that your Keurig's water line is clogged. To flush out debris, run water through your brewer a few times without a K-Cup. I'd recommend this step if your Keurig is brewing some coffee, just not a full cup.
Step 4: Try turning the power on and off or try unplugging (for a long stretch if you can). When you turn the Keurig back on, be sure to give it plenty of warm-up time. This has also worked for me.
Step 5: It may be time to descale. Most models will give you a message when it's time to have the mineral deposits cleaned. Go here for instructions
Step 6: Turn off your brewer and use an unfolded paperclip to clean out the holes in the top needle.
Step 7: If you've given your Keurig a good spanking and it still won't behave, contact Keurig (866-901-BREW) for help.
Oct 04, 2013 | Keurig B60 Coffee Maker
Ccoffe maker won't brew. Says it is Brewing but nothing. Only about 6 months old was descaled earlier this week.
heatman101
Aug 27, 2011 | Keurig B70 Coffee Maker
It says it's brewing - - But It is Not???
If it won't pump water through, how are you going to run a descale? Also this model is supposed to tell you if scaling is an issue. We called Keurig, they said, we will send you a new one.
Mar 21, 2010 | Keurig Platinum B70 Coffee Maker
From slow to no drip brewing....no descale issues....clogged?
clean the needles and if that dont work call keurig and get a replacement
Sep 20, 2009 | Keurig B60 Coffee Maker
Slow coffee stream and smaller brew size with B70
I had the same problem, contacted Keurig and they suggested the descale procedure, which did nothing. The brew size was very small, the display would not let me select the size, and water was being pushed back into the reservoir. I was able to resolve the problem however.
First I went through a gallon of white vinegar, without results. Then I did the following:
Went to Walmart and bought "Brew Rite". Tried 8 cup mixture (8 cups of water, two tablespoons of mix), did not work. Being persistant, put in another 8 cups, and when the reservoir was empty of the solution let sit 2 hours while unplugged and then put in clear water. By the time I got half way through with the clear water, the device started working properly, no problems since. This may work for you...
May 29, 2009 | Keurig B70 Coffee Maker
Keurig B40
If the machine is new, call keurig.. There telephone number is on the web site. They are warrented for 1 year.
Aug 16, 2008 | Keurig Elite B40 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
195 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
