Question about Intel D845GVSR Motherboard
How to solve jumper setting problem - Intel D845GVSR Motherboard
    President:
  • 2,992 Answers
You can download the product guide for your board from Intel here. It covers all the jumper settings and other details of the hardware.
Posted on Mar 24, 2011
  • 79 Answers
Follow this link to the Intel website where you can look at the documentation with all the settings in it
http://www.fixya.com/postanswer.aspx?thid=8752934&prdid=316277&ctgid=26&ref=unslt
I want to know the Jumper settings (Master and Slave) for IBM Travelstar 15 GB Hard drive. I would be glad and thankful if you will solve this problem for me. Ari Kiviharju
This solution will reference the picture below:
To configure the drive in Master mode, no jumper setting is used (Figure A1).
To configure the drive in Slave mode, the jumper must be placed over the two vertical pins on the far right (Figure A2).
To configure the drive in Cable Select mode, the jumper must be placed over the two pins in the bottom row (Figure A3)
If you find this solution helpful, please leave a positive rating!
Jun 20, 2011 | Computers & Internet
My bell rings when my neighbor pushes his button and vice versa how do you correct. Model SL-6166-RX-A purchased at home depot.
Take the back off the 'bell' and you will see two rows of gold colored pins running parallel to each other, eight pairs I think. Three of these pairs of pins will be covered by jumpers. Jumpers connect two pins together.
Pull any one of these jumpers off it's pins and move it to any other pair of pins.
Make note of which jumper (the pins are numbered) you moved and to which pins you moved it.
Now, take the cover off the 'button'. You will see an identical set of jumpers and pins to those in the 'bell'. Duplicate there, the change you made to the 'bells' jumpers.
Ghost rings solved!
Ok, ok, on the wild outside chance that the problem persists, just move another set of pins.
Remember, the jumper configuration in the 'bell' and 'button' ' must be identical.
Nov 04, 2009 | Desa International White Wireless Plug In...
Quantum Fireball lct 30gig not recognized in Dell Dimension 3000
Turns out this particular drive needs TWO jumpers on it, to set it to CS. I received it used with a single jumper in the Master position, but after checking the Maxtor/Quantum website, it listed the jumper positions and showed the second jumper. As soon as I installed the TWO jumpers in the correct position, the Dimension 3000 booted right up and let me reinstall Windows. I had scoured the internet for many hours looking for a solution, none solved it until I decided to check the manufacturers website. Always start there!- Solved!
May 18, 2009 | Quantum Fireball Lct20 (QML30000LD-A) 30...
How can i format my new harddrive?
You have to make sure the HD is properly formated and install the XP into it... you may want to read below link which i think might be helpful to solve you problem...
http://etech.maiila.com/boot-failure-system-halted
good luck...
Nov 04, 2008 | IBM ThinkPad T23 2647 Notebook
CMOS battery getting hot.. bad jumper setting... help!!
you can downlaod the manual which shows the jumper settings, plus diagnostic software and drivers for your board from the makers website at the address listed below.
http://support.asus.com/download/download_item.aspx?product=1&model=K8S-MX&SLanguage=en-us
Please rate this answer and good luck.
Oct 30, 2008 | ASUS K8S-MX Motherboard
Cd rom
Is this a new CD-ROM? Usually if the BIOS cannot see the drive it's a problem with the jumper setting on the back of the drive. Try setting the jumper to cable select. Let me know if that helps.
Jun 24, 2008 | Compaq Computers & Internet
Need jumper settings for a Maxtor model 94098u8 hard drive
Here are your jumper settings.If this solves your problem please rate as fixed. If tou need more help just add a comment and I'll be glad to help you further. Thanks.
Apr 25, 2008 | Computers & Internet
Need jumper settings for Maxtor 83500D4 hard drive.
Here are your Jumper settings. If this solves your problem please rate this as fixed. If you need further help just add a comment and I'll be glad to help you out. Thanks.991329a.gif
Apr 24, 2008 | Computers & Internet
MSI 845GE MAX L MOTHERBOARD JUMPER SETTINGS
Hello!
If the motherboard is new or you never set any jumper setting or you did not interfere any connection seeting their then you yo did not need jumper setting to seat the CPU.
The CPU you are going to use is very compatible in your mainboard so do not worry about the setting.
more about your setting click here for the usermanual of your board.
hope this help, melnavz
Feb 25, 2008 | MSI 845GE Max-L (MS-6580-060) Motherboard
Intel D845GVSR Motherboard Logo
305 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
