Question about Pioneer Audio Players & Recorders
I own an Pioneer CD tuner XC-L11 with a stereo power amplifier M-L11. Recently it won't switch on with the standby button flashing red. After consistent attempts to put it on, it works but when put off and leave for a period of time the standby button begin to flash again. Could you help me to fix this problem? Thanks, Jeffrey.
  • Jeffrey Odigie Mar 24, 2011
    Thanks so much for the solution proffer. I like to point out here that it is not the light on the amp that blinks but the power light on the CD tuner XC-L11. Please, help!
    Thanks.
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
The service manual is available for free after you register here...
http://www.hifiengine.com/manuals/pioneer/m-l11.shtml
Posted on Mar 24, 2011
  • David Dunn
    David Dunn Mar 24, 2011
    My mistake: I found the Service Manual and this Service Aid looking thing...
    PIONEER PRODUCT TYPE: AUDIO MODEL: XC-L11
    REPORTED SYMPTOM: CUTS OUT TO STANDBY IMMEDIATELY AT POWER ON (IN PROTECTION MODE).
    CURE: REPLACE C5610, C5611 AND C5612 ON THE FLAC (DISPLAY SUPPLY)
    Service manual...
    http://www.kallhovde.com/pioneer/tricomp...
I need to connect a pioneer amp m-L11 to a pioneer cd player xc L11 - which leads do I need?
It is verry simple to do (Karen) All you need is a (Audio) Patch cord, To connect it up to your amp.
Nov 05, 2012 | Pioneer Audio Players & Recorders
I'm trying to connect my LED samsung tv to my pioneer amp M-L11 using the digital audio output. Can you tell me please if my stereo system should be able to be support my tv so that i am able to h
Pioneer Amp input is analog. if there is a headphones out
( no model for Samsung LED TV) , connect it , not using your
Fisual Digital Opitcal Toslink Cable.
If you really need to use the TV digital out you may need a Digital
to Analog converter , to be connected on Pioneer XC L11 Aux Input .
Optical is Out only for that model.
Sep 26, 2012 | Audio Players & Recorders
My pioneer radio wont stay tuned in
You need a 12 volt battery connection at the stereo.
Aug 11, 2012 | Pioneer Deh-1420ub Car Stereo Cd Mp3 Wma...
Pioneer XC-IS22CD 100w CD/Tape/Radio Stereo what is the size of this
dear sir this is it all
Dimensions (W x H x D) 215 x 372 x 274 mm (S-IS22 speakers)
Dimensions (W x H x D) 160 x 300 x 237 mm (M-IS22 Amplifier)
Dimensions (W x H x D) 204 x 300 x 237 mm (XC-IS22CD head unit)
just tell me if i was helpfull
Aug 12, 2011 | Pioneer IS-22CD CD Shelf System
How to set the clock on Pioneer car stereo Super Tuner 3D
ok what u do is turn radio off hit clock so that it displays the time then hold audio button in until clock starts flashing then use your arrow ****. not your vol. ****.
Mar 04, 2009 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
I own an Pioneer CD tuner XC-L11 with a stereo power amplifier M-L11. Recently it won't switch on with the standby button flashing red. Nothing happens after that and the system doesn't work. Could you...
On the first board (where the power enters) there is a tall 3 pronged switch, if you turn the board over and solder a piece of wire to the 2 outside prongs, you will find that the Amp works normally apart from that the display reads Cd closed when in Cd mode.
Aug 28, 2008 | Pioneer Audio Players & Recorders
Stereo CD player/tuner XC-L11 not working at all
Just fixed mine - replaced 35v 47uf electrolytic capacitor in awu7837 module (inside shield case) - this module connects to display unit. see www.circuitsonline.net/forum/view/14478 for more info and diagram Cost - 16 pence from Maplin p/n se47m35 kq68y
Regards, Dave
Jun 21, 2008 | Audio Players & Recorders
Teac A-H300 Amplifier
I found the problem....one thread of one of my speaker cables was touching the backboard of the amp and shorting out - problem solved!
Mar 30, 2008 | Teac A-H300 Amplifier
Pioneer Model Is21 stereo
Switch speaker wires if sound switches then amp probably has a final amp ic.output problem. Try balance control and tape dubbing or loudness buttons to see if any are dirty.
May have to get repairs at a shop if the amp is worth saving.
Good Luck
BIG RED
Nov 02, 2007 | Audio Players & Recorders
933 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
