Question about Dell Latitude D600 Notebook
D600 not charging
I have had the problem of orange battery light flashing 4 times then geeen which from your site i have stopped by running battery completly out of charge. But now when i switch on i get a message saying unknown adapter and adapter isnt charging battery. The computer still works ok on adapter. If i press test button on battery i get all the lights to light up. Please can you help
  • 52 Answers
May need adapter replacment-check to see if under warranty-may be covered
Posted on Aug 03, 2008
Battery indicator flashing red when running on battery or on main supply and battery is 75% charged
When your battery indicator is flashing Red, it usually means that the charger is defective.
Dell also had a recall on some of its batteries. To see if you qualify for a free replacement click here: http://www.dellbatteryprogram.com/
If you want to reset your battery utility follow these steps:
1. Let the battery run completely dead. (Make sure all your work is saved)
2. Fully charge battery (You may still have flashing lights but if you turn your computer on and enter BIOS you can see the charge level)
3. Once again run battery dead.
4. Remove battery and wait 5-10 minutes.
5. Replace battery and use in normal operation.
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks!
Feb 03, 2010 | Dell Latitude D600 Notebook
Battery on d600 flashes orange 4 times then green once whilst trying to charge
I am having the same problem is it possible to operate the laptop without the battery in place? Can't seem to find an answer to this, my charging light blinks a few times and then the laptop shuts off, any help would be appreciated
Dec 27, 2009 | Dell Latitude D600 Notebook
My Dell laptop's battery charging circuit faulty.
try to remove your batt and check if laptop works fine with ac adapter alone.
if yes then put batt in then check how much charge you have if you have about 10% then update the bios immediately.
if fails then have the batt replaced.
Oct 12, 2009 | Dell Latitude D600 Notebook
My battery light flashes green and orange whether its charging or unplugged? is there a problem?
Flashing green and orange: battery is too hot to charge
if it flashes orange 4 times it means a defective battery
check the system setup (usually by hitting something like F2 or DEL when the laptop first powers on). there should be an option in there to "re-learn or "refresh" the battery. it will send it through a few charge/discharge cycles and then if the battery isn't toast it should work thereafter
Jul 07, 2009 | Dell Latitude D600 Notebook
Dell latitude D600 battery charge light flashing
Go to support.dell.com and download the latest bios firmware to update it. If it still does not work then most likely it is already a hardware issue so you need to contact dell support for the hardware issue.
Jun 03, 2009 | Dell Latitude D600 Notebook
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
May 29, 2009 | Dell Latitude D600 Notebook
Dell battery problem
Hi Roy,
Dell, apparently have had some problems with their batteries, as they called back some, including yours.
Goto Dells homepage here and goto -> a bit down this page -> Step 1: Is your battery model affected?
Hope your battery is among these, as you will be able to get a new one.
regards
/Teis
Dec 17, 2008 | Dell Latitude D600 Notebook
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 09, 2008 | Dell Inspiron E1705 Notebook
Orange and green light flash
The flashing battery light is an indication that the system is attempting to charge the battery. The orange light indicates a problem charging one of the battery cells. This usually means that the battery either needs to be recalibrated or replaced. To recalibrate the battery just use the system until the battery is dead, then recharge and repeat the process twice, after which time the battery should be recalibrated. If this doesn’t fix the flashing orange light then the battery may need to be replaced.
hope this helps
Jan 07, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
148 people viewed this question
Alun Cox
