Question about Horizon Fitness Horizon T101 9 Program Treadmill
Horizon fitness omega treadmill error code E1 - what does this mean??
2 Suggested Answers
SOURCE: I have a horizon fitness, Quantum II treadmill.
im having this problem too if some one could email me how to fix it @ djbense@hotmail.com
cheers
Posted on Feb 26, 2010
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
My Horizon fitnessT101 is brand new and i put it all together.Than i used the magnetic key and started it and the treadmill didn't start it just displayed E1 on the monitor.
Had same problem. I called horizon and after troubleshooting, they could not solve and replaced the entire circuit board. I was under warranty , so i was fortunate to not have to pay for one.
Sep 09, 2011 | Horizon Fitness Horizon T101 9 Program...
After 10 seconds running my horizon fitness (quantum ii) , it stop suddently with the E1 code error, what can 1 do to fix-it
The E1 error code is the reed switch signal is not making it to the motor controler. Or that the controler is bad.
Unplug the treadmill and hook it back up, remove the motor hood and check the motor controler for a red light, it should remian lit without flashing, showing the unit has power. When you press the speed buttons, the light should start flashing, then the drive motor should start driving the walk belt. Watch the red light to see if it stops flashing when the belt stops. It should. Does the treadmill read speed and distance before it quits? If so, it most likley is a heavy draw on the drive motor causing too much restistance, which shuts the controler down.
Hope this helps.
Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Dec 09, 2010 | Horizon Fitness Merit Fitness 725T...
After starting the treadmill 10 seconds later E1 apears on the display
Your problem is that a magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Sep 16, 2010 | Horizon Fitness Merit Fitness 725T...
My treadmill is showing an E1 error code, what does this mean?
Your problem might be that a magnet has fallen off. Here's an illustrated guide that should make fixing it child's play: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Jul 07, 2010 | RTO Lifespan TR1000TV - TR1000 With A TV...
Treadmill cuts out after 10 seconds and gives an E1 message.
Your problem might be that a magnet has fallen out of place. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Jan 23, 2010 | Horizon Exercise & Fitness
Error message E1
hi there we have an E1 error after 7 seconds of operation??
Apr 09, 2009 | Exercise & Fitness
Tredmill error code
Moat likely a problem with the motor control board. See treadmilldoctor.com
Apr 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Horizon Fitness Horizon T101 9 Program Treadmill Logo
776 people viewed this question
Top Horizon Fitness Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Craig Butler
Craig Butler
wtdash
Are you a Horizon Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
