Disconnecting the stereo in a Nissan Almera typically involves the following steps:
Turn off the car engine and remove the key from the ignition to ensure your safety.
Locate the stereo unit in your Nissan Almera. It's usually located in the center console of the car's dashboard.
Use a flat-head screwdriver or a panel removal tool to gently pry off the plastic cover or trim that surrounds the stereo unit.
Once the cover is removed, you should see the stereo unit's wiring harness, which will be plugged into the back of the stereo. Gently unplug the harness by pressing on the release tab or lever and pulling the connector out of the socket.
Once you have disconnected the wiring harness, you should be able to remove the stereo unit from the dashboard.
If you want to completely remove the stereo from your car, you may need to remove any screws or bolts that are holding it in place. However, in some cases, the stereo may simply slide out of the dashboard once the wiring harness is disconnected.
Once you have removed the stereo unit, you can reinstall the plastic cover or trim that you removed in step 3.
It's important to note that if you're not comfortable working with car electronics, or if you're unsure about any of the steps involved in disconnecting your stereo, it's best to consult a professional mechanic or car audio installer for assistance.
1. Remove stereo from I/P
2. Disassemble stereo to gain access to CD drive, then remove stuck CD (without damaging player)
3. Reassemble stereo
4. Reinstall stereo in I/P
5. Test operation
? 3:38
https://www.youtube.com/watch?v=REoTeVM2S-o
Jul 1, 2013 - Uploaded by Robert DIY
Dash trim removal: 5 minutes. This video will show you how toremove the dash trim piece on the Mazda ...
see this : God bless you
Review your car's owner's manual to see if it has any tips
on removing the current stereo. It may have a diagram of the wiring and
the area where the stereo is installed.
Disconnect the battery to avoid an electrical short while working with the wiring.
Use a screwdriver to remove the retaining screws holding in
your car stereo. Grab hold of the stereo and pull it toward you to
remove it from the dashboard.
Get a pair of DIN tools to slip on either side of the
stereo, if the stereo connects to the dash using spring clips and bolts.
These thin tools slide in easily, release the clips, and allow the
stereo to come out easily. You may need to remove dash panels when bolts
hold in the stereo. Take out the bolts and screws that hold the stereo
in, and then simply pull it out.
5
Look at the wires on the back of your car stereo. You should
see 2 wires attached to the stereo. A wiring clip protects the stereo
from vibrations and holds the wiring harness steady.
6
Pry the wires up from the stereo and loosen them using a
pulling/pushing motion. After working the wires back and forth, you
should be able to pull the wires straight out.
Before removing the stereo you need to ensure that the battery's grounding cable is disconnected from the negative lead. Most BMW models have the battery housed under the hood while others (a relative few) store the battery on the left side of the vehicle in the trunk. Use a 10 mm wrench to loosen the bolt holding the clamp of the grounding cable around the negative lead.
Use a trim pry tool to remove the vent housing above the stereo. The vents can be removed to allow access to the stereo or removed completely. Once the perimeter of the vent housing is loose from the dash, you can feed the wiring that connects to the hazard light button through the front of the vents. With the hazard switch pushed forward, simply disconnect the power supply to completely free the vent assembly.
The climate control group at the bottom of the stereo also needs to be removed to access the stereo. The climate control housing can be removed by hand. Grab the climate control at the bottom and the top. Pry from the bottom and remove. The climate controls do not need to be removed completely. When it is free from the dash there will be enough slack in the wiring to allow you to place it aside to access the stereo.
There are two screws that hold the factory stereo in its dock. Those screws, located on either side of the stereo facing upward, can be removed using Phillips-head screwdriver. Once the screws are removed, the deck slides forward to allow access to the wiring at the rear of the stereo. The wire groups at the rear need to be removed and can be done so in any order. The four wiring groups connect to the antenna, the amplifier, the speakers, and the power supply (the battery).
If you plan to install an aftermarket stereo, most will be compatible with BMW wiring. If not, you can connect the wiring groups to a wiring harness adapter before connecting to the new unit.
Review your car's owner's manual to see if it has any tips on removing
the current stereo. It may have a diagram of the wiring and the area
Use a screwdriver to remove the retaining screws holding in your car
stereo. Grab hold of the stereo and pull it toward you to remove it
from the dashboard.
Get a pair of DIN tools to slip on either side of the stereo, if the
stereo connects to the dash using spring clips and bolts. These thin
tools slide in easily, release the clips, and allow the stereo to come
out easily. You may need to remove dash panels when bolts hold in the
stereo. Take out the bolts and screws that hold the stereo in, and then
simply pull it out.
Look at the wires
on the back of your car stereo. You should see 2 wires attached to the
stereo. A wiring clip protects the stereo from vibrations and holds the
remove screws from dash face, remove dash face. two 10mm bolts hold stereo in place,remove bolts, gently pull stereo out. unplug stereo. install new stereo by reversing the directions
there are 2 screws down at climate controls remove them and whole panel pops off, stereo is held in with 4 screws facing you. but it looks bad with a generic stereo fitted nissan have a cd changer that fits in above the stereo where the cup holder is and hooks up to stereo and looks good, not overly flashy,
good luck
