Question about LG 42LC2D 42 in. LCD HDTV
Screen is green when watching dvd - LG 42LC2D 42 in. LCD HDTV
    Sergeant:
  • 339 Answers
Have you checked you leads are you using hdmi or scart? if its scart then the wires inside can short together and give a green screen
Hope this helps
John
Posted on Mar 24, 2011
Black vertical lines (watching DVD); blank but lit screen (watching TV)
After 10+ years of service, it is a likely candidate for replacement.
Mar 21, 2017 | Sony Grand WEGA KDF-42WE655 42" Rear...
Jensen DVD player (JDVD 4301) does not show picture when DvD is inserted. Message on screen "Warning Stop Watch Video" display on blue screen although I can hear the movie playing. Did I connect...
Jenson requires the green wire to be connected to the vehicle parking brake.(Safety feature) this green wire requires a negative switch to activate the screen.
Jul 29, 2011 | Car Audio & Video
I can not watch the videos and movies in my Kenwood KVT 617 DVD
hi there
on the back of this unit is a green brake wire you need to buy a 3 pined toggle switch ...........you need to take a small but mid size length speaker wire and attach to 12v (red wire) going into back of kenwood unit add another speaker wire to the ground wire (black wire) of kenwood unit... now on the 3 pined toggle switch add the power speaker wire to the toggle switch add the ground speaker wire to the toggle switch once this is done add the green wire to the last toggle switch pin........put the kenwood unit back in dash.......now turn the car and toggle switch on...........put in a DVD and if screen shows DVD all is done...... but if the screen does not show the DVD......just switch the green wire with the black wire on the toggle switch and now it should work
hope this helps
Mar 02, 2009 | Kenwood KVT-617DVD Car DVD Player
Green Screen instead of Blue
Check the picture settings on the tv, if that is not the problem, then check all of your connections (RGB cables+RW Audio) that is HD component, if you have both HDMI and HD component then try one of them, or it may be a switch in the back of the DVD player or TV
Jan 11, 2009 | Miller TELEVIDEO 995 TERMINAL W/ GREEN...
Panasonic Viera TH-37PX8B Green Screen When Turn On DVD Player
I had the same problem, after reading the forums and playing around for a while I cracked it. It was to do with the output from the DVD player, in the DVD player setup I changed the output from RGB to s-video and bingo! Hope that helps
Jun 10, 2008 | Televison & Video
Unable to watch DVD's on this TV
Your DVD player may be set up to put out a different mode. Are you using the component cables or s-video? If it's the component cables, make sure you're player is putting out 480p. Also, try it with another set to see of you can localize the problem.
Jan 02, 2008 | Philips 60PP9202 60" Rear Projection...
Insignia NS-7PDVD portable DVD player - no picture
The unit is failing and is not worth repairing. There is either a short in the wiring that leads to the screen, the inverter board os failing, or the decoder is failing. These are all hardware problems.
There are several tests to find where the problem may be, but the average consumer doesn't have the ability or access to parts to fix these issues.
Sep 22, 2007 | Insignia NS-7PDVD
HDMI input
The green screen is caused by light hitting the back of the tv. Either move the tv to a location where direct sunlight will not hit it or put up strong curtains. As for fixing the problem, do a search for JVC green screen reset on AVS Forum, its easy to do just dont have the info with me now. Keep in mind if direct sunlight hits the back of the tv it will do it again. I have put up some good curtians and ensure not to open them when watching the tv. Hope this helps. I am Hayward, have a nice day.
Aug 21, 2007 | JVC HD-56G886 56" Rear Projection HDTV
Green horizontal lines
Hi, I have a Philips 29PT9009/12 TV. Recently I have begun to see horizontal green lines on my tv, when either watching a dvd or watch tv. This has gotten worse and now the green lines are more visible and the background is now turned a shaded green. Please help me. Thanks in advance
Apr 30, 2007 | Philips 28PW6506 28" TV
LG 42LC2D 42 in. LCD HDTV Logo
76 people viewed this question
Computer Repairing
Computer Repairing
