Question about HP ProLiant ML370 G4 Server
Hi , i've HP ML370 G4 server , after power failure , the server can't boot . i try to reinstall memory & remove all parts & fix it agian but the problem still there , then after about 1 hours it's working . after 4 days i want to move the server , then i shutdown it , but when i try to connect it the same problem came again , i want to inform you the every LED on the motherboard is green & every thing seems to work well
    Novelist:
    Scholar:
  • 86 Answers
It may be that the lithium battery is dead; usually a CR2032 button battery. Signs of CMOS Battery Failure Dom Tech Computer Blog
Go into the BIOS settings during initial power on boot up, often F10 or F2 are common. Check the date and time, if they are off, you should be able to temporarily boot by setting the date and time but you'll have to do it every time you boot. If the date and time is off, and you set the correct date and time and it still doesn't boot, you'll want to make sure it's booting to the correct drive.
When it doesn't boot, does it give you any error?
Posted on Jul 04, 2017
sksree406
  • 61 Answers
SOURCE: hp proliant ml370 g4 rebooting problem
Try to boot from smart start and do offlinr diagnostics.have you purchased second cpu seperately? Check the CPU compatibilities.
Posted on Oct 25, 2008
  • 17 Answers
SOURCE: HP Proliant ML370 Server: Led shows red light
Your server definetly has issue booting first of all this is a little old server model so first open and blow air from a blower (&not use vaccum cleaner)
since problem could be anything frm a struck cpu fan or anything
then poer donw theM/c and locate the RAM its a smal hardware in green color vertically fitted to the motherboard it will have locks at the both ends press them downwards the RAM will pop out then clean the side that was inside the motherboard with eraser and nothing else(it might damage the RAM) then fix it as it was aligning the notch it should work
If this does not work out then tell me exct LED and sybol near it
Bye for Now
Posted on Jan 24, 2009
SOURCE: Compaq ProLiant ML370 G3
How big if your environment? How many users? Do you have remote access needs? If your environment is under 75 users then you might want to consider moving to Windows Small Business Server. It's a great little package that includes Exchange with it. You can also get the premium edition which includes Sharepoint.
Don't forget licensing needs during this whole process too. You want to make sure you are covered properly with software licenses from Microsoft when making the migration.
The hardware specs seem adequate but it will depend on the amount of users in your environment and workload for it.
I've included three links to different options for migration:
This link is pretty good to explain using the Microsoft tool.
http://www.petri.co.il/active_directory_migration_tool_usage_w2k_windows_2003.htm
This link provides info on the swing migration which is a bit more popular in the small business arena. Works pretty good. I've done it a few times.
http://www.sbsmigration.com/pages/14/
This link is for Acronis products that allow for easy ghosting or copying of data from one server to another. The good thing about this tool is that your SIDs are kept the same. So I don't know if its a big deal (depends on your environment size) but it can be a pain to rejoin workstations to a domain if new servers are added without successfully moving necessary settings. I've used this tool a few times. It's quick and easy.
http://www.acronis.com/enterprise/products/ATISWin/
I look forward to hearing more from you. Please update me on the questions I asked and if I can help further I will be glad too. Don't forget to rate the solutions once we're done! Thanks.
Posted on Mar 31, 2009
geo_jonas
  • 555 Answers
SOURCE: Server crashed
need to have re installation of your Operating System
Posted on Jun 16, 2009
SOURCE: I have HP ML370 server,
Clear NVRAM with the help of Maintainance switch
Posted on Dec 01, 2011
Boot issue after inserting a quadro FX5800 display adapter
Go into BIOS and remove the Stop on Error on Boot selection.
May 08, 2014 | HP ProLiant ML370 G4 Server
0x0000001e (0xc0000005
Run Chkdsk / recreate Raid & reinstall OS
Oct 24, 2013 | HP ProLiant ML370 G4 Server
ML350 G3 S/board CPU Error Amber LeD + Internal Health Error
You will continue to get internal error until you add memory. It shouldn't even boot without RAM.
Feb 04, 2013 | HP ProLiant ML370 G4 Server
We have hp server ml370 when i restart the server its stopped on attempting boot from hard drive c and never continue
This is because either the image on the hard drive is bad (corrupted, missing boot sector, etc) or because the hard drive itself has some issue like corruption etc.
If this is a mirrored raid array (two drive mirroring each other) I would try to remove one of the drives and boot again. If that does not work reinsert and remove the other drive and try to boot.
regards,
Mike
Oct 21, 2012 | HP ProLiant ML370 G4 Server
ML3670 does not boot as it does not found an boot disk
Replace HDD (Red Flashing ).It seems you have unknowingly disturbed your Raid . If Possible take backup of your server.Reconfigure RAID and Freshly Install OS .
Apr 04, 2012 | HP ProLiant ML370 G4 Server
Hi guies the windows srever 2003 files in my hp ml370 is corrupt and i tried to fix the prblem by format one hard disk partition in my scasi disks array and installing win srv 2003 on it but whe i log on...
HP SmartStart CD x32
The utility to use to set up the ML370 g3 server is the SSCD (smart start cd) this is a guided installation cd that will help you set up the array, install drivers and diagnostic utilities and after that
will request the windows cd so that you can finish the installation.
instructions:
1. download SSCD from here
2. extract the zip file
3. burn the ISO image to a cd
4. boot the server to the cd
5. choose from the main menu the option "Deploy server"
6. follow the wizard
Oct 26, 2010 | HP Compaq ProLiant ML370 G3 Server
My HP Proliant ML370 G4 can not boot. 1 of the logical drive has a problem and in interim recovery mode. how come it can not boot? there is also an error saying the battery is unable to charge. cache...
dear erwin,
as per your writing the server raid has broken .. its may be a problem with a hard disk , first you have to check the hard disk state . to do that you should enter into raid bios . don't try to something on that , just see the status of logical drive then which are the disks includes on that raid
in you post also it may give the details of failed disk ids
then you may have problem with your batt. unit , for that please do the above steps first then back with that...
Aug 10, 2010 | HP ProLiant ML370 G4 Server
Hp proliant ml370 g4 rebooting problem
Jul 16, 2008 | HP ProLiant ML370 G4 Server
HP ProLiant ML370 G4 Server Logo
171 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
