Question about Samsung Computers & Internet
This new drive will only mount on the computer which formatted it. Any other machine (Vista or Win7 64bit Enterprise) allocates a drive letter but only offers to format the disk. If you format it on another computer (quick or full format) then that PC takes over OK but again no other PC can mount it without asking for a re-format.
    Sergeant:
  • 296 Answers
Disable Bit-Locker encryption.
Posted on Mar 24, 2011
Reformatting HCS725032VLA380
Is it your primary hard drive ?
Reformat hard drive to NTFS Windows XP allows you to easily format the hard drives with its inbuilt utility. Formatting the hard drive would forever delete all the files stored on it. There are two ways in which you can format the hard disk partition - from My Computer and from DOS. You cannot have a NTFS partition with allocation unit s above 4096.
Click on "Start," and then click on "My Computer." Right-click on the disk partition to format and then click on "Format." Click on the "File System" drop down box and select "NTFS." Click on the "Allocation unit " drop down box and select an allocation . It is recommended that you select the "Default allocation " option. Click on the "Start" button. b> Format the Partition from DOS b> Click on "Start," and then click on "Run." Type "cmd" in the 'Run' dialog box and then press "Enter." Type "format drive_letter: /FS:NTFS" at the command prompt and then press "Enter." Replace the 'drive_letter' here with the letter of the drive that you want to format (for example, format e: /FS:NTFS). For help on advanced formatting options, type "format/?'more" at the command prompt and then press "Enter." Keep pressing "Enter" as you read on. Hope it helps
Jan 24, 2013 | Hitachi CinemaStar 7K500 HCS725032VLA380...
Tip
MICRO SD CARD WILL NOT FORMAT
If you cannot format an SD card on your PC or external device, retry choosing the exFAT format from the drop down menu (File system box) on windows, then format your SD card using this choice, then format again using fat32 format, this just worked for me and saved my SD card from the bin
1. Double-click My Computer, or Computer (for Vista and Win7)
2. Right-click the drive letter associated with your memory device, then select Format.
3.Select File system format drop down menu to be exfat.
4. Select quick format.
5. Select start.
6. When formatted, repeat steps 3 to 6, but this time select Fat32.
What is exFAT format?
exFat is short for Extended File Allocation Table. exFAT is a file system designed and used by flash drives.
exFAT is not used and was not designed for formatting hard drives. It is only recommended in flash memory storage and other external devices only.
on Nov 02, 2017 | Miscellaneous
I like to create a Partion on a window xp computer system but it seems difficult
Hi there, here are a few tips to aid you in partitioning your system:
1. Turn off your computer and install your new hard disk. It's unlikely that you have any unpartitioned space on which to create a new partition on the drive already in the machine, so you'll need to add a new drive. New drives typically don't come preformatted, so you'll need to create your own partitions and format them.
2. Start your computer and logon as an administrator. Click Start and then click the Run command. In the Open text box type: diskmgmt.msc and click OK.
3. A Wizard will appear when the Disk Management console opens. Go through the Wizard's steps and allow it to initialize the new disk, but do not allow the Wizard to convert the disk from basic to dynamic.
4. You will see, on the left side of the console, disk icons that represent "Disk 0?, "Disk 1," etc. Your new disk should be the one with the highest number. The size of the disk should be listed, and the word "Unallocated" should be just under the size. Right click where it shows the size of the disk and click the New Partition command.
5. Click Next on the New Partition Wizard Welcome page.
6. On the Select Partition Type page, click on both of the options and read the Descriptions. We'll assume here you're creating a primary partition. Select Primary partition and click Next.
7. On the Specify Partition Size page, type in the size of the partition. Depending on what you want to use the disk for, you might want to create more than one partition. Type in the size of the new partition in the Partition size in MB text box and click Next.
8. On the Assign Drive Letter or Path page, you can bind the partition to a drive letter or mount it in an empty NTFS folder. In this example, you'll do it the old fashioned way and assign the partition a new drive letter. Select the drive letter and click Next.
9. You need to format the partition to use it. Always use NTFS unless you need to allow other operating systems on the same machine to access the drive. You can use the defaults, or customize the Allocation unit size based on the types of applications you want to run on the disk. Click Next.
10. Click Finish.
Finally, you'll see the drive being formatted. You can use the partition after the formatting is complete. You don't even need to restart.
Best of luck.
Jan 08, 2011 | Computers & Internet
My system is not seeing the SimpleTech HD after i used it to back up my system and then formatted my system
If you are running Vista, try these steps:
Connect the drive but do not Format the drive, right click 'my computer' then 'manage' go to 'storage/disk management' view the drives; your usb drive will not be allocated a drive letter. You can set one manually or leave it for about 2~5 minutes for one to be allocated auto. Each time you connect the drive you may have to do this.
If you weren't planning to reinstall an operating system from CD and then restore your data files, then what software did you use to "back up your system?" Did you clone the parition, or did you try to just copy all the files?
If the vista disk management solution didn't help, please repost with more information.
Oct 11, 2009 | SimpleTech Computers & Internet
My Book suddenly cannot access files, needs formating
If you are running Vista, You might be one of many people who are reporting an update that is causing some buggy behavior. Try this:
Oct 11, 2009 | Western Digital My Book Essential Edition...
Lacie Hard Drive not being recognized on computer
Oct 10, 2009 | LaCie F.A. Porsche (301177) Hard Drive
Not displaying Windows Explorer other than it exists as a drive.
Oct 09, 2009 | Western Digital My Book Essential Edition...
My external hard drive never shows up on my computer Vista OS
Please, try with some other computer, if it works there means problem with your usb driver.
If that is the case, u can reinstall it.
thanks.
Aug 04, 2009 | Computers & Internet
Computer does not recognize my book 160 gig
I am making some assumptions:
1) You've got the correct power adaptor and the MyBook has not been physically damaged (they are pretty rugged).
2) You are trying to connect it to a PC running XP or Vista.
So it's time to see what your PC sees: It may be that the PC knows there's 'something' connected via USB but it hasn't been mounted. One simple way to check this is to go to the lower right portion of your MenuBar and left click on the "Safely Remove Hardware" icon. In XP it looks like a small gray thing with a small green arrow. In Vista it looks like a little plug. If it shows that something is connected to your PC via a USB or firewire port, when you left click on the icon there is a small description along with a LETTER, i.e. your main hard drive is almost always C:, this will not show up when you click on the icon I'm talking about because your C: drive is always there, a part of your desktop, likewise your onboard CD or DVD drives, but when youplug in a thumb drive or an external hard drive like your My Book, it gets assigned its own letter E:, F:, etcetera. It might be that the desktop has used that drive in the past and gave it a letter identification, but in the time you didn't use it you used other drives, and they were given the same letter. Now that you've 'returned' the new external drive to the desktop, it is a bit confused. So, back to that little "Safely Remove Hardware" icon. If is 'sees' your hard drive and it is mounted, it will show up as a small line saying something like "USB mounted drive F:" If it 'sees' your hard drive and it is NOT mounted it will say "USB mounted drive" with NO letter. Now you should go onto your desktop and select in sequence:
Settings
Control Panel
Administrative Tools
Computer Management
Storage
Disk Management
When you get to Disk Management there should be a vertical array of horizontal bars, showing all your computer recognized memory.
WARNING: You can screw up your computer if you are careless, so pay attention to the messages the computer is giving you. You want to find your external drive. The computer should be able to see it as a connected 'something' but if there is confusion as to the identification of the drive, it will not have it allocated by letter. So look to see if your My Book shows up as 160GB of something. If it is not there, check your physical connections, power down the My Book, plug it into a different USB port, change out the USB cord (sometimes a USB 1.0 cord is accidentally used in a USB 2.0 port and it might be a problem). If the computer does see the MyBook as a drive but it doesn't have a letter, you can click on it and SELECT a letter. This might solve the problem right away, just make sure you pick a letter not being used by anything else. Resist any invitations to FORMAT. This will lose you all your data on the drive.
Dec 26, 2008 | Western Digital My Book Essential Edition...
Mc350=10000?
have you checked this site?
http://www.janome.co.jp/e1.htm
To write to the CF card, you need a card writer on your pc. If you still have problem accessing the CF card, it might be corrupted. Try to reformat the CF card with FAT16 file allocating tablet in the format option on the computer. If its not possible to format this, you probably need to get a new CF card.
Jan 29, 2008 | Janome Memory Craft 10000
Computers & Internet Logo
166 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
