Question about Boss BR-600 Digital Recording Studio
My Boss BR-1180 was working fine but said NO CD DRIVE so I replaced the cd drive and as soon as I did I turned it on it reads BOSS BR11-80 and the HD ACCESS light stays lit but nothing else happens. Did I need to do more than just slot the cd drive in and could I have damaged the hard drive by just changing the cd drive?
  • 561 Answers
Hdd should not be damaged, if your hd and cd are on same ide cable it might be taking the cd as master and not the hd, ensure the jumper on the back of the new cd drive is set in the same position as the old one was, as test remove cd and boot system, hd should act again as usual. this will show that there is a ide conflict.
my assumption is that your cd jumper should be set to slave or cable select position.
you may have to try each until you find the position that works.
I hope this was useful.
regards Martin.
Posted on Mar 24, 2011
I'm trying to burn a song to a CD-R using a Boss BR 1180 but every time it completes, there's no song on the CD. I record, bounce, record on 9/10, then try to write to CD and it never works.
"it never works"... this is NOT enough information for us. You are not telling us how the CD is tested. If you are testing it in a boombox type player, that is not a test. First thing is to look at the bottom of the CD to see if you can detect written tracks... with right lighting you can tell if it has been burned. REMEMBER that CD's, unlike phonograph records, are written from the middle outward. Many consumer players have trouble playing CD's that are written but not "finalized". If you CAN see written area (compare to unburned CD) then likely the burning is taking place, and the problem is the format is either not complete or incompatible with your player. Try reading the disk in your computer. Also you might want to visit the forums for the Boss/Roland workstations at VSPLANET.com.
Aug 19, 2011 | Boss Micro BR Digital Recorder
I am getting "CD Write Error" on my BR-1180 when attempting to burn a track. It is sporadic; sometimes I get a burn, but lately it has increased and I have now gone through 15 cd's and getting this...
MICHAEL SCOTT: YOU PASSED ALONG SOME GREAT INFORMATION BUT IT ONLY GETS ME HALFWAY THERE...
I HAVE ALL THE NECESSARY CABLES HOOKED UP. DO YOU HAVE TO RECORD MY SONG FROM THE 1180 TO AUDACITY OR WHAT?...THIS IS ALL NEW TO ME AND IT MAY WORK BUT TELL ME HOW TO RECORD FROM THE 1180 TO AUDACITY.
THANKS...GEORGE SLADEK
Aug 18, 2010 | Boss Micro BR Digital Recorder
What do I need to burn a cd from my pc with the br 1180
This Is real simple grab a cable that goes from rca jacks to a headphone jack then plug the rca jacks into the br-1180's audio out jack and then plug the other end into your computers mic port.
Download Audacity From www.Audacity.com and then use it to capture you audio and then you can burn that when complete.
Its real simple I do it all the time even though I have the br-1180cd the cd burner burns real quiet so I don't use it. The cable can be bought at radio shack, best buy, wal-mart and I have even seen them at 99 cent only stores.
If you have more question let me know This Is my main unit so I know a lot about it.
Sincerely,
Michael Scott
Apr 29, 2009 | Boss Micro BR Digital Recorder
No CD writer for Boss BR-1180
Hey mike yeah you can hook a regular cdr drive to the ribbon but the problem is if its not a slim it most likely wont fit inside the unit. Also the built in c.d r is way over rated mine has it and I still bounce it all onto my computer and then burn it from there. The one on the br-1180cd burns very quiet.
Apr 23, 2009 | Boss Micro BR Digital Recorder
Boss 1180 Hard Drive Error
Im Sure You Solved This Problem But For Other User Yes There Is A Way To Save Your Data If Your Hard Drive Is Still Operable. You Can Put Your Boss Hard Drive Into Your Computer And Copy Its Contents To Your Computers Hard Drive. Some Say That If The Hard Drive Is Not Operating You Can Put It In A Ziplock And Then Stick It In The Freezer For An Hour Then Attempt To Retrieve Your Info. Remember Always Back Up Your Data On Hard Drive Recorders As They Are Not Fail Safe.
Apr 13, 2009 | Boss Micro BR Digital Recorder
Is the Boss Dr-5 compatable with the Boss BR-1180 mini studio?
Midi doesn't actually "make sound". If your trying to record the patterns you made on the DR-5 to the recorder you need to use an audio output(I don't remember if they are RCA or 1/4" on the DR-5.) The midi output would be used to"trigger sounds" in another device that has sounds built in, or you could also trigger sounds in a program that supports midi input.
Mar 03, 2009 | Boss Micro BR Digital Recorder
Boss br-8 digital recorder wont load up. powers up but no program
This Sounds Very Bad Do You Have Experience With Taking Apart Computers? If So You May Want To Open Up Your Br-1180 And Remove The Hard Drive And Put It In Your Computer And Copy All The Data Off Of It. I Also Would Recommend Calling Roland They Are The Most Helpful People In The World.
www.Myspace.com/CrossRoadsToNowhere2007
Dec 28, 2008 | Boss Micro BR Digital Recorder
I can record anything to a cd with my boss 1180 br it always say
Im Guessing Your Trying To Burn It Off Before Mastering It Which Means All The Tracks Between 1 And 10. First You Click Audio Cd Write/Play Then Select Disc At Once And Then It Should Guide You From There. I Hope This Helps
Dec 24, 2008 | Boss Micro BR Digital Recorder
MY Boss br 1180 ,disk error
before you go out and buy a new hd try intializing your system.
unfortunaly you will lose all saved info, but you will either way. this test may save you some money.
with your 1180 in the off position press and hold the track 5 button below the fader and the redo/undo button that is just to the left of the rotarty knob and below the power button. while holding these two buttons press the power button and continue to hold the track 5 button and the undo redo buttons untill the test menu is showing. its takes about 15- 30 sec. in the test menu rotate the value knob till you see 23 initialize HDD and press ok. this process may take up to 30 mins. if this doesnt fixya then contact roland for a replacement.
Dec 06, 2008 | Boss Micro BR Digital Recorder
Boss BR-600 Digital Recording Studio Logo
221 people viewed this question
Top Boss Music Experts
Michial Gueffroy
shaun taylor
drivealot
Are you a Boss Music Expert? Answer questions, earn points and help others
