Question about Shure MX412D / C Professional Microphone
Dear Sir, I have problem with no sound through MX418D/C. It seems that its preamp is not working. Other mike MX418 is working perfect on this position. Can I get preamp PCB? M.Q.Notta
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
Contact Shure for repalcdement parts or repair.
Posted on Jul 27, 2014
I also, have a shure microflex 150 condenser mic. We use it at the pulpit of our church for 2 years at least. The mic went dead. I replaced the 185 cartioide cartridge but the mic is still dead. D
It sounds like somebody turned off the phanton power on the mixer. Bring the main volume all the way down and turn it on, that should resolve the problem.
Nov 09, 2014 | Shure MX418/S Microflex 18" Gooseneck...
Shure MX418D cardioid mics
Contact Shure to have the mic repaired.
Jun 10, 2013 | Shure MX418 Microphone
Shure mx418 stopped working
There is no fuse. The capsule may be loose (on the end under the plastic wind screen). See is the phantom power is turned off on your mixer, if it is or is not working the mic will not work. Try a seperate connection, you may have a bad wire.
Feb 23, 2013 | Shure MX418 Microphone
Dear Sir, Can I use my marantz tower speakers
Yes, the impedance is perfectly acceptable, just that it wont be a perfect acoustical match.
Sep 04, 2010 | NAD C325BEE Amplifier
Microphone does not pick up any sound
Your mike requires a 48 volt phantom power supply which your preamp should be supplying. The most commonly overlooked problem is the cable. It must be wired for a balanced connection for phantom power to work correctly. 1=ground/shield, 2=hot(ve) and 3=cold(ve). None of these connections should be bridged to another and need to be kept separate to maintain a balanced connection. You will need to eliminate the preamp and mike cable as sources of the problem in order to determine if the mike is working correctly. You need to test this combination with a volt /ohm meter. If you don't know how to do this you should take it to the dealer you bought it from for testing or advice.
Oct 15, 2009 | M-Audio Luna Professional Microphone
No sound from a Shure MX412D/C
Sounds to me like you may be missing a phantom power supply. The 570S is a Dynamic mic. The MX412d/c is a Cardioid and requires a 11-52v supply over pins 2 & 3 in the mic cable. Phantom power is a feature of most professional mixing consoles(usually 48v). If you do not have a phantom power supply on your system- then you can purchase single battery powered units to insert in the link between sound console and Mic. For example: AKG B-18
Hope this helps.
Rus.
Feb 23, 2009 | Shure MX412D / C Professional Microphone
Shure microphone MX418 microflex condenser 150
The mic requires phantom power from the mixer. Contact the mixer manufacturer to find out how to turn on phantom power.
Feb 19, 2009 | Shure MX418 Microphone
No sound
Make sure speakers are hooked to proper connectors. Also check speaker switch "A"/ "B"/ "A+B" is positioned to correct speakers.
Also make sure mute switch is off
Apr 27, 2008 | Yamaha DSPE390 Amplifier
Shure MX412D / C Professional Microphone Logo
80 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
