Question about Compex MicroHub 8 Networking Hub
What is its voltage is it 12v or 6v - Compex MicroHub 8 Networking Hub
    Sergeant:
  • 296 Answers
10volts.
Posted on Mar 24, 2011
Hi, I have a mission cop 2,000,000 and I lost the charger, can I use a 12v 500mA as a replacement? Note that the battery is a 6v
Hi Ebrahim
Defiantly not you cannot use a 12v supply on a 6v battery in the worse scenario you could blow up the battery by putting to much voltage into it, you will need to find a 6v charger hope this helps
Dec 17, 2014 | Toys
Have lost the battery charger to my grandaughters 6v trimoto samurai bike, currently being sold by Toys'r'Us. Can you please tell me where l can get a replacement?
Hello there
I think you will find the chargers for these trimotos are ' injusa 6 volt chargers'
Well it just so happens there is one for sale here, You may have to change the connector but its only two wires and low voltage.
http://www.ebay.co.uk/itm/Injusa-6v-battery-charger-/311105396806?pt=UK_Toys_Games_Outdoor_Toys_Bikes_Ride_Ons_LE&hash=item486f53a046
Sep 24, 2014 | PRIMOS HUNTING CALLS Primos 6V & 12V...
How can i check a generator on a 67 shovel to see if it's charging properly?
Use a multimeter to measure battery voltage before and after starting. If 6V the battery voltage should rise to around 6.9V after starting, and if 12V the battery voltage should rise to around 13.8V after starting. If less than about 6.5V / 13V, the generator's not charging well enough. If less than about 6V / 12V, or if the battery voltage never rises at all, or frankly falls, after starting, then the generator's not charging at all.
Jul 23, 2014 | Cycle Electric Generator Dgv-2569 12v...
1990 Dodge Ramcharger won't start. Battery output 12v, voltage across coil terminals 6v, voltage output at coil port to coil wire 6v, voltage of coil wire output to distributor 6v. Engine will c
There should be a small white ceramic block on the firewall - this component cuts the battery voltage from 12 to 9 volts for the coil and ignition system. It has 4 wires and is called a ballast resistor.
You may need a book with the wiring diagram to be able to test it. You should have battery voltage going in and something like 9 volts coming out.
You can also run a wire with a fuse from the battery to the positive side of the coil to check the system. Disconnect the factory wire from the coil first.
Jan 27, 2013 | Cars & Trucks
G6A-8E Water Heater will not start.
x8h3rkvosvawaaaaabjru5erkjggga=
You may need new circuit board, call mfg they may offer more help in determining if a new board is needed.
Good luck
Oct 28, 2017 | Atwood LP Gas Water Heater 6 Gallon 96121...
We have bought a battery charger HB 1206S DC6V - 12V 6AMP, but it does not state what is the state of charge do the lightes go out when it has reached changed state or light up please help
Product Detail Model No.: HB-1206S
The item is used for charging 6V-12V lead-acid batteries
Max Charging Current: 6A
AC Power Input: 64W
Output: 6/12V DC 3. 52A
Batteries Capacities: 15AHR-80AHR
Unit Packing: Colorful box
Dimension: 18cm x 10cm x 20cm
G. W. / N. W.: 1. 85KG/1. 75KG
Certifications: GS, CE, BS, ROHS, SAA
Main functions:
(1) The HB-1206S battery charger has the features of convenient operations, reliable safety and high performance.
(2) During charging, if turn up overload, the battery charger will keep itself at normal current and normal voltage with its self-automatic protecting function.
(3) If being short circuit, the battery charger will switch off itself, and turn normal after one or two minutes.
(4) The output current of the battery charger is very stationary, so it can protect the battery charger very well. It only costs 3 or 4 hours to fully charge the batteries.
(5) Indication of charging: the battery charger has 6 pilot lamps. The more pilot lamps shining, the less electric quantity is. The charging process finishes when all the pilot lamps go out.
(6) The battery charger can be switched between 6V and 12V, so it can charge for 6V and 12V accumulators. You can select 6V or 12V according to your own needs.
(7)The operations are very convenient: Put the red clip to the positive pole of the accumulator which indicated "+", and put the black clip to the negative pole of the accumulator which indicated "-", then plug in power source, the accumulator will be charged.
Aug 02, 2011 | GPS
Is the electrical system 6V or 12V?
Look at battery is it 12v or 6v.Most likly it is 12v.
Feb 05, 2011 | 2007 Harley Davidson XL 883 Sportster
How do open the unit to install batteries
It doesn't need batteries. It is operated by the voltage in the circuit you're testing. No indication means no voltage (or at least less than 5 volts) is present.
Mar 18, 2010 | Gardner Bender 6V/12V CIRCUIT TESTER
Transformer main coil shorted.
You have to do the math according to the circuit path, and all components in between. Break out the voltage meter.
Sep 26, 2007 | Aiwa PX-E860 Turntable
Compex MicroHub 8 Networking Hub Logo
115 people viewed this question
Top Compex Computers & Internet Experts
Michael Galve
Michael Galve
Rose li
Rose li
Are you a Compex Computer and Internet Expert? Answer questions, earn points and help others
