My wm64 hotpoint washer wont spin how can i fix it
  • 430 Answers
There are few possibilities which can cause the no spin problem.The lid switch, agitator couple or motor coupler. First thing to be checked is lid switch.If the lid switch is short or not getting closed, then its the cause of no spin.Check the lid switch on the machine and see if it is broken or bent. The lid switch give the washer a signal that the machine is closed.If the lid switch checks out ok, then its agitator coupler or motor coupler issue.It is composed of 3 pieces and generally costs about $15-20 for the parts. Turn the washer on its side and look between the motor and the transmission. If you see small pieces of plastic and or rubber around the area then thats the problem for sure. --------------- Press the rinse/hold button to see if the machine is paused.
Pull the drain hose out and inspect it for blockages. Remove the drain hose from the machine and look through it.----------------------This are the details to be checked.Thank you for using fixya.
Posted on Mar 24, 2011
I am looking for an instruction manual for a Hotpoint Aquarius 1200 WM64 and I can not find one online to download. Can you help?
Hi.
Please click on the link below to open the owners manual for Hotpoint Aquarius 1200 VM64 in PDF format:
Hotmpoint WM64- Washing Machine
Regards.
Ginko
Sep 13, 2011 | Hotpoint Washing Machines
Hotpoint wm64 does not spin dry
Remove the top cover of washer and check the brushes in the motor, replace them if less than 3-5 mill left.
If brushes o/k then make sure belt is on, and make sure it is draining o/k.
Aug 16, 2010 | Washing Machines
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius wm64 loud banging noise when spinning with full load no noise when spinning empty i have found small pieces of plastic inside drum
Several possibilities here.
First and fore most is the drum support or main drum bearigs are failing., more likely to be drum support
The pieces of plastic you refer to are from inside the outer drum, because what is happening is the inner drum is catching the outer drum, and breaking the plastic inside.
You are going to have to strip it down to determine the exact cause, what I expect you will find is that the alloy 3 legged drom support has corroded away,a nd the drum has come loose.
Hope this helps you solve your problem
Nov 28, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
How to I remove the drum from a Hotpoint WM64 washing machine? I need to change the bearings.
Remove top cover and rear panel.
Remove belt and drum drive pulley.Remove clamp that secures door seal
Remove top control console panel.
Remove door lock.
Remove screws top and bottom holding front panel, remove front panel.
Remove spring clips holding plastic drum front, lift to one side plastic drum front cover.
Tap drum shaft to remove drum from container, remove bearings.
Thanks.
Sep 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WM64 keeps fusing and cutting out
it's possible that one of the carbon brushes have worn down to the bottom and it is sparking on the motor causing it to trip the fuse. It's just one possibility. Have you checked the carbon brushes are connected properly and that they have not 1) worn down and 2) that the wires are connected to them correctly.
Mar 12, 2009 | Hotpoint WMA64 Front Load Washer
Drum wont move
Check the motor and the belt on the back of the unit behind the rear plate. Make sure that the belt is attached and the motor is spinning. If this helped please rate. Thank you
Feb 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
My washer
It sounds like you have a faulty inlet valve or module. Hope this helps.
Oct 02, 2008 | Hotpoint Washing Machines
Hotpoint WM64 doesnt seem to be taking in enough water
Close your faucet valve & unscrew your hoses to check screens on hoses & machine. Clean out well. Refit, check for leaks. Water shd be in good pressure. If this is not the problem change your inlet valve, it is easily done. Suggestion: use powders for front loaders.
May 08, 2008 | Hotpoint WMA32 Front Load Washer
My hotpoint wm64 is making a lot of noise on spin
Can someone help me please, I have a Hotpoint WM 64 from last week it gives prob. Works well but when you choose a prog it starts well but during last half (as it reaches the green line which i think it means rinse) it stops then i have to kind of go for an other wash to get the cloths rinse well. Anyone have any idea what is going wrong with the machine..?
Apr 25, 2008 | Washing Machines
Washing Machines Logo
278 people viewed this question
Top Washing Machines Experts
