Question about Siemens Refrigerators
Hi, We have a problem with a Siemens fridge/freezer (K130M440Gb/01). The freezer seems fine but the fridge seems warm. Any help would be appreciated. Thanks, John
SOURCE: Samsung RCS21DCNS Side by Side
probly the evaporator coil in fridge all frozen up you need to pull all the back out inside the fridge section and defrost with air drier
Posted on Sep 21, 2007
Amigaman
  • 248 Answers
SOURCE: cold freezer warm fridge.
That sound was the evaporator fan motor in the freezer. This circulates the cold air from the freezer into the fresh food section. If this is not running you need to check for power to it. If the fan has power to it but not running, replace it. It should be located behind freezers back wall inside of freezer near top.
Posted on Oct 09, 2007
philbran
  • 242 Answers
SOURCE: Fridge on Fridge freezer not working
Ok there is a drain pan under the evap. coil under the fan that may be clogged and full of ice there is a 3/4" hole the water drains out of that needs cleared if there is a puddle of ice over it , the ice will also effect the airflow traveling down the duct to the fresh food section of the unit.
If there is no ice puddle at the bottom of the refrigerator then make sure the unit is cooling well by making sure it has been running for 10 min. or so and checking the coil in the freezer , it should have a small layer of frost on it showing its getting cold the whole way through it. Let me know how this works.
Phil
Posted on Jan 02, 2009
  • 31 Answers
SOURCE: KENMORE MODEL 596 BOTTOM FREEZER, FRIDGE NOT COOLING
The freezer will stay cold because a small amount of cold air will be forced through the frost but that will not be enough to make it up to the refrigerator portion. You can defrost the unit by removing the metal panel and allowing the frost to melt. Careful use of a hairdryer can speed up this process. This will likely be a temporary fix. The root cause of excessive frost can be caused by a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar bill at several points around the door, both on the freezer and refidgerator door. If you can pull the bill out with no resistance, the door is not making a good seal. Inspect the seal and make sure there isn't anything stopping the door from closing such as food, or a shelf not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The defrost system has three main parts, the defrost heater, thermostat, and timer. None of these parts are particularly expensive, or difficult to replace you feel comfortable with repairing it yourself. If you can troubleshoot this by manually starting the defrost cycle. Let me know if you would like this procedure.
Posted on Jan 07, 2009
  • 686 Answers
SOURCE: fridge is warm even when i adjust temp. control.freezer is good.
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
Posted on Feb 17, 2009
My freezer is freezing food fine but my refrigerator seems to be warm and not cooling like it should. The temp control has been adjusted to a higher setting but does not seem to help.
if your freezer is working your fridge is fine
Your problem probably started a couple weeks ago when the drain that allows defrosted ice (water) to drain into the drain pan at the base of your fridge became plugged for some reason. Then everytime the fridge went on defrost more water melted but did not drain which in turn froze. Now ice has built up and caused the air that flows into the fridge to be blocked, causing a warm fridge.... my advice is to leave fridge unplugged for 48 hrs to thaw it and find the cause of the water not to drain... could be a corn niblet or pea from the freezer... the tube should be visible from the inside or the back
Jul 21, 2011 | Amana ABB1927DE Bottom Freezer...
Freezer seems to be working fine,but the fridge part is warm
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 04, 2011 | Kenmore 64802 Top Freezer Refrigerator
Whirpool fridge is warm, freezer is working
Check the back wall of the freezer compartment for ice buildup. Sounds like you have a defrost issue.
Feb 22, 2009 | Whirlpool GB2SHDXP Bottom Freezer...
KGU 34641 GB TOP REFRIGERATOR
Hi,I believe you may have a blockage in the intake from the freezer to the fridge as cold air is blown up from the freezer to make the fridge coldhope this helps,mike,
Aug 10, 2008 | Bosch KGU34641 Bottom Freezer Refrigerator
Freezer okay, fridge warm
i suspect a faulty defrost heater/thermostat or defrost timer. any other questions you can e-mail me @ hvac.tech7872pr@gmail.com
Jun 15, 2008 | Refrigerators
Cold freezer warm fridge.
Oct 09, 2007 | Refrigerators
Refrigerators Logo
91 people viewed this question
Top Siemens Refrigerators Experts
marlin siecinski
Mai Lor
Are you a Siemens Refrigerator Expert? Answer questions, earn points and help others
