Question about Dyson Memory CRO1 Front Load Washer
The front door of my washing macine is broken, can i get and fit a new one myself
  • 822 Answers
Yes........but dear from dyson................check online for other sellers......
cheers
Posted on Mar 24, 2011
Creda iwd12 - how to remove the front
Its very simple to do when you fit them daily but first time is very difficult
Nov 03, 2012 | Creda IWD12 Front Load Washer / Dryer
My washer door is broke a small pin in door is broke
If the pin is broken merely insert a new pin or screw that fits. If the plastic housing is broken you will need to replace the door.
Sep 07, 2010 | Haier XQG50-11 Front Load Washer / Dryer
Washing macine won't drain.
Door switch problem. The switch is either cracked or broken and not registering as closed. If the unit is most likely also not spinning too.
If the unit DOES in fact spin, then the hose is kinked or clogged. But i believe it isn't spinning too.
Replace the door switch.
Mar 14, 2010 | Whirlpool Washing Machines
Wma44 hotpoint washer. Did a wash as normal and
Sometimes a weak or broken spring in the door handle can be the cause of the problem, but you would have to take the door apart to check this.
If you have already fitted a new door lock, then chances are it is the control board, but I would check the door handle first.
Jan 30, 2010 | Hotpoint WMA44 Front Load Washer
Door wil close but not lock - no 'click' - flashing door light stays on
You probably need to fit a new door handle spring, as it is more than likely broken.
This is quite a common problem.
Dec 29, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Door wont stay closed
Either the door catch or spring is broken, or the door lock is not working
The parts are fairly easy to fit,once you have determined what part or parts you require.
Hope this helps.
Dec 15, 2009 | Zanussi F1045W Front Load Washer
I put some washing in my samsung J845 front loader the door will not lock before the washing can be done. my husband brought a new door latch due to the other one been burnt out and he put it back on the...
Just bang the door again until the error goes away. The door is not lined up and won't latch properly. At least that is what ours does. I usually slam the door on my machine.
Sep 29, 2009 | Samsung Washing Machines
Hi, the handle has broken off my Indesit WA 125 Front Load Washer. I cannot open the door to get my clothes out, any suggestions? Also, would it be possible to buy a door (part of the plastic on the door...
I don't know where you live but in St. Paul and most other cities, there are appliace parts distributers, adn they sell to the public. If you can figure out how to get what is left of the handle off of the machine, you can probably put a new one on.
Sep 05, 2008 | Indesit Washing Machines
I need to fit a new door seal
easy fix love what you need to do is un-plug the washer now tak the 2screws from the back of the washer that holds the top(lid) in place now open the door and around the edge of the door seal there will be a spring wire pull this out so you can unattach the door seal totally from the washer front the seal will still be attached to the inner drum though now stand up and look down through the top of the washer down to the front were your door seal is still attached to the washer there will be another clamp with a screw on it undue the screw but you dont have to undue it totally though pull the clamp out through the front through the door seal now will come off the washer now just do these instructions backwards to re-fit the new door seal let me know how you go on or if you get into trouble doing the job peter
Jun 10, 2008 | Hotpoint Aquarius WD640 Front Load...
Dyson Memory CRO1 Front Load Washer Logo
125 people viewed this question
Top Dyson Washing Machines Experts
Starnley Johnwells
Starnley Johnwells
Gerry Harvey
Gerry Harvey
Are you a Dyson Washing Machine Expert? Answer questions, earn points and help others
