Question about Oki Electric Industry Okidata MB 480 Multifunction ( fax copier scanner ) BW LED copying (up to) 2 Laser Printer
I am using a OKI 480 printer, i have just changed the toner and now it tells me that "Power on/off check sensor lock key. Scanner sensor locked. Press left key. what should i do?
  • javier munoz Dec 14, 2011
    I am having same problem. Did you resolve this?
  • 97 Answers
SOURCE: toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Posted on Dec 07, 2008
SOURCE: oki c3400 toner sensor error
I found the solution here.
http://www.c3400.co.uk/index.asp?menumode=0&content=sensorerror
A plastic thing was closing the sensor window. Open the window and you will solve the problem.
Gouval.
Posted on Jan 26, 2009
leroyal
  • 2120 Answers
SOURCE: OKI 3300 Image Drum Problem
Did you remove the plastic tape from the new cartridge?
Posted on Feb 16, 2009
SOURCE: OKI C3400 printer keeps saying
Okay, I had the same problem with my C3300. I phoned the people i purchased from and this is what fixed it for me:
looking directly at the printer:
-open printer
-remove drum in question (the drum is what houses the toner cartridge) in my printer it is black.
-look on the right side of the drum & there is a little (approx 5mm x 5mm) hole that has a little panel that opens- push this up to open it.
-replace drum close the top and try printing.
I had to do this 2 times before it worked, but it worked.
Posted on Apr 16, 2009
  • 13 Answers
SOURCE: I have a new OKI B410d printer which is givng
It is more than likely that you have an incompatible toner fitted to the drum unit. Either a generic cartridge or b430 or b440 cartridge which is not compatible with b410's. Beyond that it may be a faulty drum unit. Hope this helps.
Posted on Sep 14, 2009
Where is the sensor lock switch?
The scanner lock is situated at the left side of the flat bed scanner. switch it to UNLOCK.
Sep 04, 2014 | Oki Brand Oki MB480 MFP Multifunction...
543K Toner Sensor Error
Check toner lock lever is in position - Seek attention of service person if restarting the printer does not correct the problem. See our How to Guide
Aug 12, 2008 | OKI C5800Ldn Led Printer
OKI mono printer mod B431d
The locking lever may have dislodged (was not properly locked down).
Check the locking lever and firmly lock it down.
Mar 24, 2012 | Oki Electric Industry B431d Printer
Se puede resetear el contador de los tambores de la oki c3400n
Trata esto:
When installing the C3400n printer, or when replacing the toner cartridge, be sure to fully insert the toner cartridge into the image drum, and make sure the blue lever is pushed ALL THE WAY toward the back of the printer (fully locked position). If it is not fully closed (locked), a "toner sensor" or "toner empty" message may result. Note: (Picture at bottom shows incorrect position of locked toner cartridge that may result in either of these messages).
Installation Procedure of Image Drum and Toner Cartridge:
          0.408?openelement&fieldelemformat=gif
    >> Insure the toner is fully locked, see photo below showing the correct and incorrect positions of the locked toner cartridge.
CORRECT (Fully rotated to lock position)
    91.28a2?openelement&fieldelemformat=gif
INCORRECT (Not fully rotated to lock position)
179.32a2?openelement&fieldelemformat=gif
Dec 01, 2010 | OKI C3400n Laser Printer
Toner sensor error
take out the magenta cartridge. and make sure the edges are clean. There are little metal pieces on the sides where the sensor reads the cartridge. Also, make sure the "lock" on the cartridge is locked.
Jul 22, 2010 | OKI C9300 Led Printer
I have attempted to install 3 different black toner cartridges in my OKI c3400. I keep getting an error: "Toner cartridge lock lever is improper, drum missing, or toner sensor error. OFFLINE." I first...
Mar 16, 2010 | OKI C3400n Laser Printer
540 : y toner sensor error
Hi moneybaggz52:
Here is your problem.
Symptom:
When setting up a brand new C5100n or C5300n out of box, a toner sensor error is encountered.
The printer can display any one of the following errors:
543K: TONER SENSOR ERROR
540Y: TONER SENSOR ERROR
541M: TONER SENSOR ERROR
542C: TONER SENSOR ERROR
Cause:
This generally can be caused by two things.
1. The toner cartridge lock lever is not in the correct position.
2. The Transfer Belt lock levers are not in the correct position.
Resolution:
Check the appropriate toner cartridge lock lever (Shown below) and make sure that it is in the correct position.
0.110?openelement&fieldelemformat=gif 2.1ac?openelement&fieldelemformat=gif
CORRECT POSTITION INCORRECT POSITION
Check both transfer belt lock levers (Shown below) to ensure that they are in the correct position.
5.2eea?openelement&fieldelemformat=gif
CORRECT POSITION
10.4086?openelement&fieldelemformat=gif
INCORRECT POSITION
Hopes this helps
May 24, 2009 | OKI C5500n Laser Printer
Okie C5400 giving 162: Fatal Error
This is a Toner Sensor Error, Color:Cyan
and can be corrected by checking that the Cyan toner lock lever is correctly in position.
Mar 19, 2009 | OKI C5400n Led Printer
Toner Error
Check to make sure that the sensors are clean and play around with the lock arms. Reset the machine and also download the utility from the oki service website to get exact error message. http://www.okic3400.co.uk/library/downloads/utilities/c3300c3400smv1115.exe
Jan 27, 2009 | OKI C3400n Laser Printer
Oki 3300
When installing the C3300 printer, or when replacing the toner cartridge, be sure to fully insert the toner cartridge into the image drum, and make sure the blue lever is pushed ALL THE WAY toward the back of the printer (fully locked position). If it is not fully closed (locked), a "toner sensor" or "toner empty" message may result.
Mar 28, 2008 | OKI C5200n Laser Printer
Oki Electric Industry Okidata MB 480  Multifunction ( fax  copier   scanner )  BW  LED  copying (up to) 2 Laser Printer Logo
418 people viewed this question
Top Oki Electric Industry Office Equipment & Supplies Experts
Fix It Fast...
Fix It Fast...
Don  Farrell
Don Farrell
Victorman
Victorman
Are you an Oki Electric Industry Office Equipment and Supply Expert? Answer questions, earn points and help others
