Question about HP Deskjet F340 All-In-One Printer
I have never used the Photo ink Cartridge #58. It intal pic shows putting it where the black one goes-does this mean I would use the color and the photo one at the same time instead of the black one?
  • 604 Answers
No, put the ink in its proper place, the photo is just to show you how the ink cartridge is installed. often companies do this and even sometime show different models then what you purchased, they do it to save money, its all about the money these days.
Posted on Mar 24, 2011
  • 430 Answers
Yes correct.The photo cartridge has to be inserted, where you install black cartridge.The photo cartridge gives finishing touch to the photos which you print.The actual photo comes from the color cartridge only, but for lightness and darkness, the color(ink) from photo cartridge gets used.In photo cartridge there are three color ink, that are light pink, light blue and grayish black.In color cartridge there are three color ink, that are pink(magenta), yellow and cyan( blue).------------- This are the details.Thank you for using fixya.
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
I have new photo (58) and color (57) carts and when I print wallet size (9 pics per 8.5x11 photo paper) the first 3 print true color and the last 6 are blue. I have cleaned the rollers and still do not...
hello, you are using the photo color ink cart, have you tried running a cleaning cycle or test print, the reason why i ask, is that maybe 1 of the colors is not printing, the test pages would prove what color is missing, if black not printing, it would print possible blue, or no black at all. i know you have put in new inks, but since the volume of ink in these cartridges run out according to usage, one color might run out before the others, and since black and yellow are the most used colors, without them your prints will show color faults.
Oct 07, 2010 | HP PSC 1350v All-In-One InkJet Printer
Will 27 work on 4215
HP 27 cartridge is not compatable for this printer. Supported cartridges are :
Back : HP 56
Color : HP 57 , HP 28
Photo cart : HP 58
May 08, 2010 | HP Officejet 4215 All-in-One Color Photo...
HP7660 Photosmart Printer
It comes with HP #57 (C6657 A)—Tri-color print cartridge and HP #56 (C6656A)—Black print cartridge and the 56 must always be in there (the black one) but acceptable replacements for the color one are as follows: HP #58 (C6658A)—Photo print cartridge I suggest for the best photos use 58 and 56.
Feb 28, 2009 | HP PhotoSmart 7660 InkJet Printer
Pic`s wrong colors
you need to check
1) same color ink of the cartridge almost empty, change a new ink cartridge or refill the color ink (there is only one ink cartridge)
2) the cartridge ink channel dryer and constipated, take out the cartridge put the bottom surface touch down clean water (a little) 1 hr, then set back if the cartridge has enough ink.
Feb 05, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Cannot get ahp58 ink cartridge to fit a hp2410 printer,the box that it come in said it would fit; how do I get it to fit?
The #58 cartridge goes into the right side...remove the black cartridge and insert the #58 cartridge. This give the printer a wider range of colors when printing photo.
Nov 22, 2008 | HP Office Equipment & Supplies
How to change black color inkonHp2175all in one
Supported HP ink cartridge part numbers The HP PSC 2100, 2170, and 2200 all-in-one series products use the ink cartridges listed in the table below. The HP 58 tri-color photo ink cartridge replaces the black ink cartridge for six-ink photo printing. Ink cartridges Part number HP 56 black ink cartridge (19 ml) C6656A HP 57 tri-color ink cartridge (17 ml) C6657A HP 58 tri-color photo cartridge* (17 ml) C6658A HP 27 low capacity black ink cartridge (10 ml) C8727A HP 28 low capacity tri-color ink cartridge (8 ml) C8728A * Replaces the black ink cartridge for six ink photo printing and includes cartridge holder. Replacing the ink cartridges The power must be turned ON to the all-in-one or the print carriage will not come to the center.
  1. Locate and raise the print cartridge access door on the front of the unit, just above the output tray. The print cartridge carriage will move into the middle of the access area. Figure 1: Raising the front access door and the ink cartridge latches c00224418.jpg
  2. Press down lightly on the top of the ink cartridge latch of the ink cartridge to be replaced and then pull the lower section of the latch toward you to unlatch the ink cartridge.
  3. Grasping the sides of the ink cartridge, pull the cartridge toward you to remove it as shown in Figure 2. Figure 2: Removing the cartridge after raising the latch c00224419.jpg
  4. Remove the replacement cartridge from its packaging, and touching only the black plastic, gently remove any tape covering the nozzles. Do not touch the gold-colored contacts. Figure 3: Removing the protective tape c00224420.jpg
  5. Holding the ink cartridge with the printed label up, slide the cartridges one at a time into the print carriage as shown in Figure 4. The black ink cartridge (HP 56 or HP 27) goes on the right side (with the gray latch) and the tri-color cartridge (HP 57 or HP 28) goes on the left side (with the blue latch). If the optional photo cartridge (HP 58) is installed for six-ink photo printing, it is installed in place of the black ink cartridge. Figure 4: Inserting the cartridge c00224421.jpg
  6. Place your hand on the latch as shown in Figure 5, with the thumb pulling the end of the latch toward you. While holding the end of the latch out, press down on the top of the latch until it stops and then release the lower portion of the latch with your thumb so that it catches under the tabs. Do not force the latches into place or damage to the unit might occur. Close the all-in-one after latching the ink cartridges in place. Figure 5: Latching the ink cartridges in place c00224422.jpg
  7. Close the print cartridge access door.
  8. A message will appear in the front panel display requesting that the ink cartridges be aligned. Press ENTER on the front panel to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press ENTER to finish aligning the cartridges. Remove the page from the scanner glass when complete.
Storing the option photo printing cartridge while not in use The optional photo print cartridge (HP 58) that may be purchased separately for six-ink photo printing includes an ink cartridge protector. The protector is designed to keep the photo cartridge from drying out when it is not in use and for holding and protecting the black cartridge when the photo cartridge is in use.
  • To insert a cartridge into the protector, slide it into the protector at a slight angle until it snaps in place.
  • To remove a cartridge from the protector, push down and back on the top of the protector to release the cartridge and then slide the cartridge out of the protector.
Figure 6: Inserting and removing ink cartridges from the ink cartridge protector c00224423.jpg Fixing error messages that appear after changing a cartridge After inserting the cartridge, one of the following messages appears:
  • Check the black (or color) cartridge
  • Replace the black (or color) cartridge
  • The wrong black (or color) cartridge is installed
These messages indicate that the ink cartridge is not making good electrical contact, is bad, or is the wrong cartridge. Complete the following steps to diagnose and correct the condition:
  1. Open the front of the unit to access the print cartridges (as shown in Figure 1).
  2. Remove the ink cartridge indicated in the message and inspect it.
  3. Verify that it is the correct part number and if it is, reinsert it.
  4. Close the lid to see if the problem is corrected.
  5. If the message is still displayed after a few seconds, remove the ink cartridge again.
  6. Unplug the power cord from the back of the unit.
  7. Clean the electrical contacts on the ink cartridge with a soft clean cloth, slightly dampened (not wet) with clean water. Each contact is very small and shaped like a rounded square. Figure 7: Cleaning the cartridge contacts c00224424.jpg
  8. Inside the HP all-in-one product, clean the contacts in the print carriage (the cartridge holder) with a clean cotton swab slightly dampened with clean water. Allow them to dry for five minutes before reinserting the cartridge(s) and turning on the printer. Figure 8: Contacts to be cleaned c00224425.jpg
  9. If the problem remains, replace the ink cartridge.
  10. If the problem still exists after trying all of the steps above, contact HP for assistance.
Oct 13, 2008 | HP Office Equipment & Supplies
I have been given a psc 1310, without an instruction manual and without any ink cartridges.The diagram inside the machine shows 5 different numbered cartridges which the machine uses, 27,28,56,57 and 58. I...
Hello.
HP 27 - Black Ink (approx 220 pages)
HP 28 - Color Ink (approx 190 pages)
HP 56 - Black Ink (approx 450 pages)
HP 57 - Color Ink (approx 400 pages)
HP 58 - Photo Ink Cartridge (approx 140 4x6 photo prints)
Hope that helps!
Jun 07, 2008 | HP Office Equipment & Supplies
Photo ink 58 do i put it on the right side and what other ink cartridge do i need to use
Normally, you keep the regular tri-color cartridge in the place it already was.. You should be taking the black cartridge OUT and putting the 58 Photo cartridge in...
FYI.. the 58 photo cartridge provides you with LIGHT magenta, LIGHT Cyan and a PHOTO Black -- which are supposed to give you truer tones and 'half-tones' for shades and nuances in color (like different grades of blue in the sky). The Photo black helps the photo not look "green" on black areas when there is a reflection on the photo... (with regular ink, when you get a reflection off of the shiny paper you often see a green-ish like color and it looks rather odd... the photo black stops that.)
Maggie B
Feb 21, 2008 | Office Equipment & Supplies
Hp photosmart 7350
The 7550 takes three cartridges 56(black) 57(tri-color) and 58 (photo).
If you replace the 57 but the 58 is also empty and still in its slot - you get green tinted photos.
So, check to see if you have the 58 photo cartridge still installed, and if it is out of ink. If so - remove the 58 - the printer will then default to "reserve mode" and you'll get better color.
Dec 16, 2007 | HP PhotoSmart 7350 InkJet Printer
197 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
