Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Temperature control Could you tell me where to set the temperature on Whirlpool Refrigerator Model ET1CHMXKQ03? I can't find one. Does it not have one? Thanks.
    Scholar:
  • 97 Answers
Hiya
the thermostat should be inside the fridge compartment usually near the light.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 03, 2008
Whirlpool refrigerator is freezing foods . need to reset temperature to default settings. how do I do it
If the temperature control is a knob turn it to a warmer number. If it's a digital control try a warmer setting. It's possible the digital control board has failed.
Nov 19, 2017 | Whirlpool Refrigerators
Whirlpool model ed2vhgxmt00 quit cooling
Helo sir
  • Check the temperature setting
  • Make certain there is a three inch space outside of the refrigerator between the walls and the back and sides and at least a one inch gap above, to allow for air flow
  • Clean the condensor coils
  • Unplug the refrigerator, wait two hours and plug it in. If you hear it running, a problem is causing the compressor to overheat
  • Test the temperature control
  • Test the evaporator fan
  • Test the defrost timer
  • Test the compressor relay
  • Test the overload protector
  • Test the compressor motor
  • thank u
    Jul 15, 2008 | Whirlpool Refrigerators
    My refrigerator is not cold my freezer is cold
    Good Morning Friend, this is Z. Thank you for your inquiry!
    Often when the temperature in the freezer compartment is cold but not cooling in the refrigerator section, it is because the temperature control is set too cold/high or the damper door is not closing. Turn the control to a warmer setting and please allow the temperature of your refrigerator to stabilize within 24 hours. If it does not, then more than likely the control is not telling the damper when to close and/or your refrigerator might possibly have a faulty thermistor or temperature control. I would personally contact a professional to accurately diagnose your appliance to determine the root cause to reduce the risk of unnecessary parts.
    Jul 14, 2014 | Frigidaire Refrigerators
    Refrigerator not as cool as usual?
    try setting it for a lower temperature if it does not cool more then suggest you call a repair service locally
    Dec 13, 2017 | Refrigerators
    Why is my Fridgidare side-by-side freezer working but my refrigerator side not cooling?
    Hi Friend, this is Z. Thank you for your question!
    If the temperature in the freezer compartment of your Frigidaire refrigerator is cooling but the refrigerator side is not, it may possibly be because the temperature control is set too cold/high in the freezer section or the damper door is not closing. Turn the control to a warmer setting and allow several hours for the temperature to stabilize. If the temperature does not stabilize within 24 hours, then more than likely the control is not telling the damper when to close and/or your refrigerator might possibly have a faulty thermistor or temperature control. I would personally contact a professional to accurately diagnose your refrigerator to determine the root cause to reduce the risk of unnecessary parts.
    May 21, 2014 | Frigidaire Refrigerators
    Hello, We have a Whirlpool Gold bottom freezer
    I don't know about Whirlpool refrigerator freezers, but my Amana has a temperature control in the freezer that regulates the overall cooling, and then the control in the refrigerator compartment controls how much of the total cooling is sent to the refrigerator section. My advice would be to lower the temperature setting of the freezer, and see if the temperature lowers in the refrigerator as well. Also, you can go to the Whirlpool website and they can help you further.
    Aug 02, 2013 | Refrigerators
    It is a french door, items in the fridge part are freezing, what should temperature in freezer and fridge be?
    The factory presets your temperatures to the MID / MID setting of 0? for the freezer and 37? for the refrigerator. Refrigerator adjustment range is -15? to +15? in the freezer and 33? to 47? in the refrigerator. Depending on ambient temperatures the temperatures will be + or - 6? the set point. Whenever you make a temperature adjustment, you need to wait 24 hours to notice any temperature difference.
    To adjust your temperatures: Adjust controls according to your Use and Care guide. Start out by making sure your settings are at the factory setting of MID / MID. Make only one adjustment: Adjust one control and wait 24 hours before making another adjustment.
    To measure temperatures: If you try to measure temperatures, it is important to follow these directions: Fresh Food Section: Put thermometer in a glass of water. Check the temperature during the first door opening after a long (8+hours) non-usage period (such as overnight or when you arrive home from work). Frozen Food Section: Put thermometer between two bags of vegetables. Check the temperature during the first door opening after a long (8+hours) non-usage period (such as overnight or when you arrive home from work).
    For more information it may be helpful to look at http://www.whirlpool.com/ or contact your local whirlpool support number
    May 17, 2011 | Whirlpool Refrigerators
    Whirlpool Model ED5SHAXML12 is freezing food in refrigerator even when dial is at off. Happened from one day to the next.
    At the refrig controls , the freezer control , controls how much air goes into the refrigerator section . Open the refrig door , and up at the top left , put your hand over the damper (air vent) . Turn the freezer control from high to low , and feel the difference in the air flow . If you turn your freezer control to a lower setting , less cold air will enter the refrig . Think of it as : the freezer control adjusts the temperature , and the refrig control , tells how long to run the compressor . In actuality , this is how it works . However , with the dial (refrigerator thermostat) in the off position and refrig still running , this indicates a bad thermostat . Pt # 2198202 .
    Sep 09, 2009 | Whirlpool Refrigerators
    WHIRLPOOL CONTROL PANEL
    Hi. Your temperature control board display is bad. You may also have a power convertor board located next to the compressor. Normally you would replace the temperature control board first. I have a temperature control board listed on Ebay as item number 250211412492. Good luck, Mack
    Dec 31, 2007 | Whirlpool GS6SHEXNL Side by Side...
    Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
    138 people viewed this question
    Top Whirlpool Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Dan Webster
    Dan Webster
    Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
