Question about Samsung G2 Portable External HX-MU050DC/ GB2 Hard Drive
I've a Samsung G2 Portable HX-MU050DC/GW 500GB. - I was using it fine on PC1 when a Scan Disk Message Window (bad sector) popped out. I did a scan disk, nothing happened and continue copying and pasting files as usual. - Brought it to PC2 to copy files from Hdd to PC2 and error message came up. Them same Scan Disk Message Window popped out again and did scan disk again, but some files cannot be pasted into PC2. - Brought it to Mac1, doesn't even mount on Mac1. Even changed cable and it still cannot be detected. - Brought it to Mac2, doesn't mount as well. - Brought it to Mac 3, doesn't mount as well. - Brought it to PC 3 and right click on property, i can see number of files inside. System file : Raw, can't see how much space the data has taken up in the Hdd) I need to retrieve files from my Hdd as it is very important. please help!
  • 604 Answers
When you see "bad sector" you need to not only run scandisk, you need to tell it to "automatically repair bad sectors" if you didn't do this, then you have written to the bad sectors and that data can not be retrieved. As for the MAC issue, you didin't say what format your HDD was, if it was FAT32 it should mount on MAC, but not if it is NTSC as MAC can't read it. If I were you I would copy all the files from your HDD to a wiindows machine and then run scandisk again, only this time make sure to auto repair, these sectors will now be gone, and its not a great loss and does happen quite ofter unfortunately. The data you have written to the bad sectors "CAN NOT" be recovered, you might get part of it, but most likely not. Good Luck
Posted on Mar 24, 2011
I have a Samsung hard drive g2 500 gb that has been plugged into a mac and now will not open again on my pc. It opened folders initially on the mac, but now will not open on either. The blue light flashes...
Your data is likely still there. For help contact an online data recovery service such as http://FreeDataRecovery.us
They perform online data recovery over the internet and also offer do-it-yourself data recovery advice.
Oct 22, 2012 | Samsung G2 Portable External HX-MU050DC/...
Samsung g2 500GB can only load 25GB data
click start control panel administration tool computer management disk management right click on your drive select properties tools click check now click start two boxes automatically fix files and
scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now tart should schedule this task when restart
have no input while the chkdsk utility is in progress any input may damage this drive
hope this helps
Sep 26, 2012 | Samsung G2 Portable External HX-MU050DC/...
I have an external samsung disk and suddenly I cannot access to any of my folders. When I try opening any of them it throws an error stating that: E:/recycler/file.exe is missing. file.exe is indeed:...
Hello
Try to scan your external had disk with an updated anti virus it may possible attacked by a virus. Try to scan your hard drive using this software http://www.mediafire.com/file/do3330...aesetup2.5.zip install it and scan your PC it will automatically remove all the recycler.exe in your PC.bentech7.jpg
Jul 18, 2011 | Samsung G2 Portable External HX-MU064DC/...
I have a brand new samsung G2 500gb (MU050DC/GB) external harddrive and I want to use it to transfer between computers (work and home). My work laptop operates Win7 and recognises the drive. I have WinXP...
A computer that is running Windows XP cannot detect a USB flash drive, an Apple iPod, or an external hard disk drive
To fix this problem, delete the UpperFilters registry value and the LowerFilters registry value. These values may cause access problems. (from Microsoft website)
http://support.microsoft.com/kb/925196#letmefixit
Jul 11, 2011 | Samsung G2 Portable External HX-MU050DC/...
Hello, I formatted my external hard drive Samsung G2 HX-MU050DC and i lost the drivers. I can not find drivers. Can you help me please? Because i can no longer read the files that are on it. Thank you...
According to the microsoft site your external hard drive which is the Samsung G2 HX-MU050DC doesn't need any additional software it is automatically installed when connected..Maybe try to connect it to other USB port I preferred you connect it at the back of your CPU..If this doesn't work try to connect your external hard drive to other computer if it still doesn't work. sad to say but the problem is your external hard drive..
Jul 06, 2011 | Samsung G2 Portable External HX-MU050DC/...
Samsung g2 cannot dectect
Reboot your PC without the external hard drive first then pulg it in and it should reconize it. If nort then go to control panel and system and device and make sure the port is showing that it is connected and turn on. when you are at the device menu, disconnect and reconnect, that sometimes work to.
Jun 03, 2011 | Samsung G2 Portable External HX-MU050DC/...
Hi, recently i bought samsung G2 portable external hard drives (500GB). My problem is that, every time i connected the external to my laptop mostly it will appear either "scan and fix...
Well, the correct answer it continue without scanning. With respect to files that became hidden, you can set the options of Windows Explorer to show hidden files.
Jun 03, 2011 | Samsung G2 Portable External HX-MU064DC/...
I have a Samsung G2 500GB hard drive, and every time I plug it into a computer, it will say that the USB Device has malfunctioned and is not recognised. I have tried plugging it into different computers...
Sounds like a driver issue with your hard drive. If you have the software that came with the hard drive you may be able to reinstall the drivers. Or, alternatively, look up the hard drive online and download the drivers from Samsung's website.
Mar 11, 2011 | Samsung G2 Portable External HX-MU050DC/...
Samsung G2 Portable External HX-MU050DC/ GB2 Hard Drive Logo
902 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
