Question about Philips A5.600 Computer Speakers
I've got a PC amplifier Philips A5.600 (4.1 surroud), but I'm lacking the remote controll as described in the manual. It's functioning all right, but all the advantages of the remote I'm missing. Is the amplifier correct working without it? How can I buy one?
  • Philips Master
  • 11,800 Answers
Yes, the amp will work just fine without it . Just that it will be a lot harder to control it, and only for the basic settings.
Unfortunately a direct replacement remote can be obtained only by ordering directly at them - very expensive, not worth the money. You should better get an universal remote - the ones from Philips or Logitech will work for sure.
Posted on Mar 24, 2011
Surroud sound wil work but and b speker doesnt
Surround sound and A/B speaker selection are two different functions as described in the instructions for your Pioneer receiver.
Apr 21, 2014 | Pioneer VSX-D411 Receiver
How to program my phillips remote
The setup proceedings to philips universal remote controls, are very difficult to describe with this window. If you wish to know more, either download the user manual to your remote control by internet, or check this link.
Feb 12, 2013 | Philips Magnavox Learning Universal Remote
Ingot my Philips remote programmed on my tv and DVD player. It works but when using DVD player the buttons don't function as its proper function. For example the play button puts the tv on mute,
It is a common problem with any universal remote controls. Try an other code for your device. Select one code which has maximum functionality. Than is the only thing have to do.
Sep 21, 2012 | Philips SRP4004 Remote Control
How to make my philips DVP3747 region free
Here is a hack that I've found to work on many Philips machines.
Turn on Player
Using Remote Control open the Disk Tray (and leave open)
Using Remote Control Press SetUp
Using Remote Control Scroll To Preference using Left / Right Arrow keys (Just Highlight it do NOT select it)
Using Remote Control Press 1 3 8 9 3 1
Region Menu Screen Should Appear
Using Remote Control Select Desired Region Using Up / Down Arrow Keys (0 [Zero] For Region Free)
Hope this helps.
Jun 18, 2011 | Televison & Video
Describe your kenwood manual "ka
Hi, Yes it is safe to leave this connection unhooked. The system control is what the stereo uses to remote control a cassette deck,cd,turntable etc... using the amplifier separately should be o.k. I hope this helps, good luck and thanks for choosing FixYa-Prodzilla
Apr 20, 2011 | Audio Players & Recorders
User manual /remote controll
You can download the manual for your tv if you use the link below it will take you to a site called diplodocs.com i have set the link up to take you to the right download page for your tv. If you click on the PDF file titled 'Download the complete user guide (2521 ko)' before it will allow you to download the manual it will ask you to rate your tv, it's easy to do and only takes a few seconds and it's also safe to do so. Once you have done that the 'download manual' box will activate, click on it you will then get a standard box open up with the options to 'open, 'save' cancel' you can choose which one you would like to do, if you save it then at least you will have a copy of the manual on your computer.
A universal remote control should be able to do the same functions as the original as you are able on some remotes to use their macro function to setup particular keys or a learning type of remote that will set itself up. Whether or not you would be happy with that is a seperate issue but if you do decide to go down that route then I would suggest to get the functionality you require you would want to buy a mid to higher end priced universal remote control made by either Philips or one for all. A direct Philips replacement remote control RC2015/01 which is listed as being the original remote is available to buy online, a quick look on one site was asking 44 US dollars.
Hope this helped,
James
May 01, 2010 | Philips 60P8341 60" Rear Projection...
How do I set up onefor all remote
i had a one-for-all remote lacking instructions. their web site had the information for my model. have a look:
http://www.oneforall.com/
it is probably best to just enter your remote's model number in the search box on the top right.. you should be able to get a pdf of the manual from there with the procedures and device codes for programming..
Nov 01, 2009 | Philips Magnavox Learning Universal Remote
Yamaha 5960
Does your reciever use a remote control?
If so, you should be aware that on many recievers and surround amplifiers some of the functions may only be accessible via the remote control (the best way to learn about it is to consult the user manual).
I have a Pioneer VSA-730 surround amplifier and the only way i can change the mix levels for surround/sub/center speakers is by a remote control. My friend had the same problem and, after reading the manual, he discovered that he actually needs to use the remote control to access all functions of the amplifier.
Good luck and best regards
3rq8 (Triarcuate)
Jul 15, 2009 | Yamaha HTR-5960 Receiver
I bought a 6 function universal remote
hello heres a link http://www.urc.philips.com/ you find your remote from the drop down menus and youll find manual and code list for your remote on here if you found this info handy please rate me thanx for using fixya
Jan 26, 2009 | Philips Universal PH301S Remote Control
Component codes missing for universal remote
See if the remote has a learning function but you must have the original remote for this and new batteries installed..
Try these codes may help
004,009,027,029,030,076,106,127,130,165,182,183
249,251,255,278,308,309,310,313,316
363,
418,447,555,584
671,716,717,718.741,748,749,750,754,755,756
These are not just random numbers I,ve made up they have come out of a book I,ve got that explains how these codes are generated and these are the best match...Good luck and I hope they work for you..
Jan 02, 2008 | Philips PM435S Remote Control
Philips A5.600 Computer Speakers Logo
180 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
