NEED INBUILT WEBCAMS SETTING MENU TO ADJUST LIGHT AND OTHER FEATURES
    Sergeant:
  • 296 Answers
There isn't one for your laptop. It would have to be software specific for whatever app you are using.
Posted on Mar 24, 2011
How do I change it from Chinese to english
If it is able it will be a setting in the menu---may need a translator or use something like babble fish to read the screen.
Dec 03, 2012 | ZEEPAD Brand 7inch 4gb Android 2.3 Tablet...
Our copier is copying in light shade. how to make it darker
To adjust the default lighter/darker setting
1. On the LaserJet 3015, press MENU/ENTER.
2. Use the < or the > button to select Copy setup, and then press MENU/ENTER.
3. Use the < or the > button to select Def. Light/Dark, and then press MENU/ENTER.
4. Use the < or the > button to adjust the setting. Move the slider to the left to make all of the
copies lighter than the original, or move the slider to the right to make all of the copies
darker than the original.
5. Press MENU/ENTER to save the selection.
Page 48 of the User Guide has instructions for adjusting the light/dark setting during a copy job.
Also see the Troubleshooting section of the User Guide for other possible reasons for light/faded copies.
If your copies continue to come out too light, you may need to clean the insert a new toner cartridge or change brands of toner. I tried several "generic" toner cartridges and refills, but my prints and copies were always faded or streaky. After going back to genuine HP cartridges, I haven't had any print quality problems.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
When i turn it on its extremely blurry and i tryed to fix it but dont know how
Logitech webcams use a combination of features to operate their cams
There may be a focus ring around the lens to sharpen the image
Also if you launch the webcam toolbar and start the webcam from the Quick Capture menu and transfer to the Settings menu you can adjust the focal length by using the zoom. You also have the options to adjust colour and contrast etc
You do have Microsoft DirectX installed to support the Logitech software ?
Aug 03, 2010 | Logitech Webcam
How to start webcam
now is this an inbuilt or an external, anyway, its easy, find the in the start menu, you should see the program file, kindly activate from there,
Mar 29, 2010 | Computers & Internet
The picture is too dark from logitec classic cam
hi i had the same problem with mine, this can be overcome by an external light source ie, a lamp or a brighter room light, make sure that it is not facing towards a window like having the window behind you as this will then set off the light reduction setting in the camera, but light coming from behind the camera is better...hope this helps
Feb 25, 2010 | Logitech QuickCam Express Web Camera
Print in light
1. Check TONER SAVE setting. If this setting is programmed "ON", all
printed documents will be light.
a. Press MENU/SET, 1 (General Setup), then 6 (Toner Save).
b. Press the top or bottom navigation key (keys located above and below
the MENU/SET key) until the display reads "Toner Save: OFF".
c. Press MENU/SET.
d. Press STOP/EXIT.
2. Check the PRINT DENSITY setting. This setting allows you to adjust
the print density from light to dark.
a. Press MENU/SET, 2 (Fax), 1 (Setup Receive), then 6 (Print Density).
b. Press the up navigation key (key above MENU/SET) to make print
darkeror the down navigation key (key below MENU/SET) to make print
lighter.
c. Press MENU/SET.
d. Press STOP/EXIT.
Oct 15, 2008 | Brother IntelliFAX 2800 Laser Fax
Webcams
Step 1: The "Tools" menu of Windows Live Messenger
1. Recover Windows Live Messenger in our software if you do not have it yet.
2. Start the installation of the software.
3. Once this is done, go to the Tools menu software.
In this menu, two links are important in order to properly configure your camera:"Setting audio and video" and "Parameters of the webcam."This is the first that we will discuss first and foremost, the second used primarily to adjust the parameters of the image in the secondary stage but we are dealing with. Launch therefore setup wizard and click on "Next".
Step 2: The setting of loudspeakers
1. Select your hardware in the menu.
2. Check the box if you use a helmet.
3. Test finally your sound output in order to adjust the volume.
It is possible that you find in the menu several choices. That means you have several elements in your computer capable of transmitting sound, a dedicated card and your motherboard, for example. In this case, make sure to select well the correct input, what you quickly verify the test by loudspeakers.
Step 3: At the turn of the microphone
1. Select your sound source.
2. Start talking to your microphone.
3. Observe the cursor, if it moves, your microphone is working.
Two remarks on the stage configuration. On the one hand, if your camera has no microphone, you must go through a device that you must annex plug into the pink on your sound card. On the other hand, if your mouse does not work, you may have selected the wrong input device sound. Take particular care in this setting and not leave this page only when the cursor s'agitera,
indicating that your voice is recognized by the software.
Step 4: Turning finally to the image
1. Specify this time the source of the video.
2. Observe the window of return: if your setup is satisfactory, your image should appear.
3. Adjust the frame rendering through the "Option" button.
Jul 19, 2008 | Philips SPC 900NC Webcam
Too dark
try printer driver settings, there should be a quality menu,
also there is a quality menu on printer menu
Sep 29, 2007 | Konica Minolta Magicolor 2530 DL Laser...
2 Ezonics web cams
Sorry, I cant help much, but this is how I fixed my webcam. Please rate me afterwards.
Aug 26, 2007 | Ezonics EZCam PRO Webcam
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
