I just used my Compaq laptop computer (Presario Cq40 108TU) this morning for 2 hours. This afternoon when I was about to use it, it turned on then while starting up it suddenly turned off. I tried again to turn it on, started up but does not boot or reach Windows as is turn off again. The unit becomes very hot only after 10 minutes.
    Sergeant:
  • 296 Answers
Overheated the CPU and/or GPU.
If it's the CPU, then buy thermal paste and use it. If that doesn't work, buy a new processor.
If it's the GPU, you will need to buy a new motherboard.
Posted on Mar 24, 2011
  • 32,281 Answers
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
I want to turn off the touchpad
HP and Compaq Presario laptop computers are made by the same company, so the hardware on certain models of each brand might be nearly identical. Many newer laptops, for example, use identical technology to control the touchpad, which in turn controls your mouse cursor. If you want to disable this touchpad use the software already installed on your PC.
Click "Start." Click "Control Panel." Click "Mouse." Click the "Device Settings" tab. Click on the listing for the HP touchpad to highlight it. Click the "Disable" button to disable the HP touchpad on your Compaq Presario laptop computer.
HP compaq service manual
http://www.hp.com/ctg/Manual/c00246219.pdf
Feb 24, 2013 | HP 15.6" Compaq Presario CQ58-A10NR Laptop...
My HP Compaq Presario CQ50-130US PC Notebook won't turn on. It just flashes on the front where the lightning bolt symbol is. It was running fine an hour ago.
Two probable problems the screen or the motherboard, if you have some technical skills you can open the laptop and figure out where the problem is using a multimeter. If you are not very good with computers the best thing you can do is to take it to the service center.
Aug 30, 2011 | HP Compaq Presario CQ50-130US Notebook
My computer was fine this morning and this afternoon it will no longer turn on. The power light(white) is on, on the side but that is the only thing when plugged it. Nothing else will respond.
Are you able to feel the heat coming up from the system after its turned on?
If yes, there may be problem with the display.
If not, the might be the problem or the underlying hardware would have been faulted.
Please get assistance from the Compaq team on this.
Jun 17, 2011 | Compaq Presario CQ60-212US Notebook
Good afternoon i have a compaq presario CQ61. the problem is when i turn it on the wireless network takes to much time to get ready. before i mean one year it was working good. tanx shah from Italy
I would suggest going to the HP site and see if there are any updated network drivers available. Also, has anything changed regarding the wireless router or access point? Are there other people using the access point? Has the router been moved so that there is something interfering with the signal?
These are a couple of things to check.
May 31, 2011 | Compaq Presario Notebook
Good morning,I want a help to download xp compaq presario sr 5030nx Drivers . thankyou so much
You can download the drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model computer/laptop and the XP orVista Windows version of the drivers you require and install them. Click onthis link to download the drivers: -
www.compaq.com/country/cpq_support.html
Feb 06, 2011 | HP Compaq Presario SR5030NX (RX896AA) PC...
Compaq R3000 laptop screen went black
Give this a try -
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
Let me know if it doesnt work.
Jan 20, 2009 | Compaq Presario 2190US Notebook
Compaq notebook won't boot up
Hi
When you boot the computer back up go into Safe Mode and check to see if you can roll the computer back to the point before you installed the software.
If so this should work. If it works then run a virus scan, a defrag of the hard drive and cleans the temp files.
OR
You can do a diagnostic startup and uninstall Onecare. So once that it is uninstall ed it should be smooth sailing.
Here is a link for some startup / diagnostic software you could try after booting.
I hope this helps
/Shawn
May 19, 2008 | HP Compaq Presario V2000 Notebook
Power turns off itself then sometimes won't turn back on for sometime
have you tried your power options, you might have it set up wrong
Apr 29, 2008 | HP Compaq Presario V2000 Notebook
Open Questions:
Cloud Backup For Small Business 'Dataalign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Cloud Backup For Small Business technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Online Backup Pricing is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Server Cloud Backup Solution up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
Jun 19, 2018 | Quantum Computers & Internet
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
