F10 CODE ON MY HOTPOINT ULTIMA WMD 960 - Washing Machines
    Brigadier General:
  • 6,277 Answers
(I do not have the fault decode list for your particular model but try this)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 24, 2011
Testimonial: "IT WORKED THANK YOU SO MUCH"
How do you change the drum bearing on a hotpoint ultima wmd 960
thier r 2 bearrings and a seal its called a bearring kit not very easy if u havent done it b4.
Jan 20, 2015 | Hotpoint Washing Machines
I have a Hotpoint WMD 960 Ultima. When I remove the washing after a cycle, the clothes are covered in dirty marks. can you tell me if this is something you can advise me about?
Look within the drum and observe if there is any dirt on it. Also check the quality of water. Check if there is any dirt /grease from the drum bearings due to failure of the bearings/seals.
Finally have the machine cleaned using good detergent cleaner , please check the link below for some tips:
http://www.espares.co.uk/parts/cleaning-products/dishwasher-cleaning/p/1423
Jul 09, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wmd 960 ultima,when press start button nothing happens apart from the clock starts count down to end of wash
if water starts but drum dont move.............
check the rear belt....if that is on then the motor needs new brushes............
easy fix ........... about £12 diy
cheers
Mar 22, 2011 | Hotpoint Washing Machines
I have a Hotpoint Ultima WMD 960 and it is flashing up F:05 what could be the prob;em and how do i solve it?
Sounds like your water pressure switch is faulty. You can replace this easily by removing the top panel, the part is round and about 2-3 inches diameter, it has a thin pipe connected to it that goes to the tub and 2 or 3 wires plugged onto it. F5 means pressure switch jammed on full. Hope this helps
Mar 02, 2011 | Hotpoint Washing Machines
My Hotpoint Ultima WMD 960 displays "F04" on the display panel before the programme ends. Have cleaned the filter and it worked OK in spin mode and finished normally but now have put in a washing load, it...
Error code F04 means pressure switch jammed on empty.
Do the following.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside the hose.
Remove the hose on to the pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WF860 Front Load Washer
Our washing machine will not pump out and we have lost the manual
it should be at the back of the machine were the pipe for dirty water comes out there is a panel you can take off at the bottom of the machine when it is off you should see the moter and the pump were the pump is you and take off the black sump asmbaly and the filter should be there. hope this helps.
Mar 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt960
Full manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
Technical helpline will be able to tell you what F10 means
Apr 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
179 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
