Since my granddaughter pulled a paper out as it was printing on my HP1200, the paper keeps jamming. Is it an easy fix for me to do?
  • 32,281 Answers
There most likely still some torn pieces of paper in the printer. Try removing the paper trays and if you can move the rollers you may be able to see the paper pieces.
Posted on Mar 24, 2011
Fix paper feeder that keeps jamming. How to clear jam and fix on-going jamming problem
What thickness of paper are you using? Also is the paper new/fresh or are you re-using paper that has gone through the printer already?
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
I have a Lexmark X5690 printer which is under the 3 year guarantee. My granddaughter used it whilst she was staying here to check on FaceBook and when I wanted to print afterwards it wouldn't print, the...
easy one,first make sure the feed tray sits in properly inside the printer.
then lift the lid on the printer and turn the rollars to make sure you cna pull out the paper thats bunched up in the printer
it this fails
its a broken sensors and you can take it back to the store you purchased it form to swap out for a better model
Mar 07, 2011 | Lexmark Office Equipment & Supplies
I have a brother mfc 7420 and every time I print it tells me paper jam, I pull the paper tray out fix the paper push start it tells me paper then I have to pull out the cartridge and pull out the paper...
Sounds like there is something in the paper track that's causing this to jam. Its not always easy to get small particles cleared just by removing the jammed paper.
This may not help everyone that I send it to, but it is worth a try.
I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press
the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer.
The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Sep 20, 2010 | Brother MFC 7420 All-In-One Laser Printer
My paper keeps going in crooked and jams
Hi, at the following link you will find some easy to follow steps on how to prevent this type of problems. Also make sure there is nothing blocking the path of the paper when the printer is trying to feed it. Sometimes objects will fell inside the printer and block the paper path thus causing the paper to be pulled from one side and the other jamming.
http://bit.ly/duaUlt
Jan 31, 2010 | Lexmark X5470 All-In-One InkJet Printer
Paper keeps getting stuck
see if the paper sensor are jam or if the machine have paper jam.
Jun 18, 2009 | Canon Office Equipment & Supplies
Printer problem - will not print
I found a piece of paper jammed in the printer. Thanks!
Nov 21, 2008 | HP LaserJet 1200 Printer
Cannot print anything. Paper goes in halfway and then says 'paper jam'. Checked back - no jammed paper. Keeps on doing this. Have been in to cancel print but keeps saying paper jam. Have tried a print test...
Dear Customer,
you ahve to use batter quility papers for prints,
cause when paper fixed up your printer says its jammed but as realesed its says printing but when ALL THINGS DOIN VERY FAST JAMMING & PRINTING ITS SEEMS LIKE PAPER JAMED ALSO SAW YOU AS PAPER JAMED,
so try to check your inner cartrige,ink & paper rolls,batter quility papers you ahve to use,
THNX
May 18, 2008 | HP Computers & Internet
Hp laSERJET 1200 PAPER JAM
If you cant get paper out from inside after removing cartridge then there is No easy fix, and the roller at rear is called a fuser, these parts dont come out easy,machine will need all covers removed, plugs disconnected and brackets removed, gears pulled off and fuser removed, maybe replaced if there is a reason why it wrapped around roller
Oct 18, 2007 | HP LaserJet 1200n Printer
Paper Jam
Probably some piece of paper stuck in the printer, try looking for small pieces of paper that might confuse the sensors.
May 19, 2006 | HP PSC 1610 All-In-One InkJet Printer
Computers & Internet Logo
27 people viewed this question
Alun Cox
David Payne
David Payne
