Question about TechFuel AC Adapter (ACNB90W1880) for Asus K70IJ Laptop
I have an Asus K70IJ notebook. The problem is that it does not power on even when the charger is plugged in. The charger light on the laptop does not come on. I have tried different chargers with the same results; no power. I appreciate your help.
    Sergeant:
  • 296 Answers
Sounds like the power receptor is broken off inside. If you plug in the charging cable on the back, and it's "wiggly", I would venture to say that you will have to get it re-soldered.
Soldering at a shop can cost as much as a used (working) motherboard.
Good luck.
Posted on Mar 24, 2011
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
My asus laptop green power light on even i shutdown my laptop
I you have the charger connected it just means its charging.
Jul 05, 2012 | ASUS (F5GL-X5F) PC Notebook
Basically when i charge my laptop it wont turn on and the lights dont flash either i have tried checking the charger on another eee pc 4g laptop and worked i also tried swapping batteries but still...
Hi
Try to remove the battery, hold on power button for about 50-60seconds, then plug-in the charger and turn the laptop ON, see what happens.
Then, un-plug the charger, an pluig-in the battery, try turn the laptop on.
Please tell us your results
Good Luck
May 15, 2011 | ASUS Eee 4G Notebook
My ASUS K70IJ webcam is upside down
http://vip.asus.com/forum/view.aspx?board_id=3&model=N51Vn&id=20091104215059890&page=1&SLanguage=en-us
Apr 18, 2011 | ASUS A8Jm Notebook
Plugged in but not chargin its a aus k50Ij laptop windows 7 what do i do?
firstly........
check whether the charger light is lighting or not..........
check the charger with another asus pc if available................
Feb 12, 2011 | ASUS K50IJ-C1 Notebook
I CONNECT THE CHARGER AND THE CHARGER DON'T CHARGE THE LAPTOP. NOW I I REMOVE THE LAPTOPS BATTERY AND PLUG IN THE CHARGER AND THE SAME THING HAPPENS THERE'S NO LIGHTS, NO POWER AND THE BATTERY IS DEAD....
There are 2 possible problems with your notebook.
1) Adaptor/Charger problem. (common)
2) Notebook power problem. (slight)
To check if there is a problem with your charger.
a) Plug in charger to any wall socket.
b) Get a small solid wire (prefferably insulated).
c) insert one end of the wire to the positive point of the adapter or the inner side of adapter.
d) scratch the outer side of the adapter using the other end of the wire to check for sparks. a spark is highly visible on a 12v power.
e) if no spark is created, then there could have been a problem with your charger.
Hope this helps.
Mar 23, 2010 | ASUS Eee 4G Notebook
Asus a6 notebook charging
If the notebook works while plugged in the it is the battery. If more than a couple years old then it may need to be replaced. First try recalibrating the battery. There maybe a utility in the BIOS, CMOS, System Setup or in the control panel to do this. If not, see if there is a utility to download from the manufacturer's site.
If the laptop does not work at all then it is probably the power jack on the motherboard. This would have to be fixed by swapping out the motherboard, replacing the jack on it or taking to a local technician.
Hope this helps!
Nov 28, 2007 | ASUS A6U Notebook
TechFuel AC Adapter (ACNB90W1880) for Asus K70IJ Laptop Logo
220 people viewed this question
Top TechFuel Computers & Internet Experts
rancotech
Shashi Bhushan
Level 1 Expert
Are you a TechFuel Computer and Internet Expert? Answer questions, earn points and help others
