Question about Refrigerators
HI I have a rangemaster sxs fridge freezer unit. The fridge part seems to be working satisfactory. The freezer seems to have a problem getting down to -18, it only gets down to -9. Tried altering the temperature to -16 and putting the fast freeze on and it got to temperature. I then turned the fast freeze off and left it over night; when i looked again in the morning the temperature was -9 again. Could this be just a problem with the stat or is it more likely to be the compressor?
SOURCE: Frigidaire frf170ff alarm keeps
We have same problem. Its stored in a intergal garage had it since Jan 08, no problem until now. The last 3-4 days its been beeping the alarm, temperature according to the display varies between -9c and 11c/ Despite doing the fast freeze over night temperature hardly improved at all around -1c. to 12c. Its quiet a cold night tonight 14c in garage yet temperature of freezer remains at -11c
Posted on Jun 27, 2009
SOURCE: The Fridge of my Rangemaster SXS Fridge Freezer is freezing up
my ice depenser is only making a couple of ice cubes the others are staying iin the ice cube tray
Posted on Dec 23, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Freezer won't maintain temperature any lower than 16-18
It appears that your refrigerator is missing defrost. It will be difficult for anyone to provide photos of your defrost heater. I recommend that you unplug long enough to allow defrost to begin manually so we can get freezer door open and remove frozen goods long enough to place somewhere safe until we examine the defrost heater and defrost thermostat. At this point the only pictures will be the ones you email me. This appears to be a new breed of Profile from GE. If you would like to attempt this please let me know. The defrost heater is part number WR50X10043 but that means nothing until we do some testing, Let me Know, Sea Breeze
Posted on Mar 23, 2010
SOURCE: rangemaster sxs u109100 fridge freezer temp in fridge +15
Hi - can't solve it but ours has started doing the same - ours will only work if the fridge temperature is selected to 9 C (press the button under ~Ref Temp until cycles round to 9C) then it controls to 9 - if the temperature is set to 5C then it seems to give up and goes back to 15 - don't know why but will investigate more
Posted on Apr 04, 2010
SOURCE: wate light onfront of rangemaster sxs fridgefreezer turned red
After you have changed the filter, select water then hold the select button down and it will go blue again.
Posted on Apr 11, 2011
How to remove doors from Range Master
A person looking to get in top shape must recognize that exercise and supplements are simply part of the total package. You must also give your body the nutrients it needs in order to stimulate muscle building. So if you are trying to discover in shape, then what creating foods should you be eating? You will love the answer because not only are these foods good; they are also most effective for you.
http://probiomaxmexico.com/biocore-muscle/
May 31, 2016 | Rangemaster RSXS661GB/C American Fridge...
Fridge not working
  • Are you getting power to the unit
  • do you see the light and fan working
  • do you hear the compressor running
  • how old is this unit.
Mar 03, 2015 | Rangemaster RSXS663CRC Cream 500 l Fridge...
Rangemaster fridge freezer not freezing temp 0.2 what should it be
could be condensation from a bad door seal? might also check the tempeture control thermostat
Feb 14, 2015 | Rangemaster RSXS663CRC Cream 500 l Fridge...
What temperature should you set a American style refrigerator
Turn OFF your fridge/freezer. Running the unit for an extended period of time will burn out the motor. You will need to get a technition in to check the thermostat operation.
Jul 15, 2014 | LG Lsc23924sw 33 23 Cu.ft. Sxs...
Whirlpool SXS.....1. compressor cooling fan quit so fridge and freezer stopped working. 2. replaced cooling fan and fridge and freezer working again. 3. Now the fridge and freezer works but runs nonst
Check to see if the sensor in the freezer compartment is encased in ice. If so, do a complete defrost and restart the unit. Another possibility is a bad thermostat and/or sensor.
Jul 25, 2012 | Whirlpool Refrigerators
Wate light onfront of rangemaster sxs fridgefreezer turned red
Jul 08, 2010 | GE PDS22LBN Bottom Freezer French Door...
Rangemaster sxs u109100 fridge freezer temp in fridge +15
Jan 17, 2010 | Refrigerators
You probably have one of the following problems: A failed defrost system, meaning the defrost timer and/or element has gone out and your evaporator coil is frozen over; you are low on freon and this too will cause your evap coil to freeze over until the freon drops so low all cooling stops; . Unless you have gauges, a licence to buy freon and service valves (or a buddy with such) you are limited to what you can do. Here is my advice:1. unplug the frig and let it defrose over night, or unplug the frig and empty the freezer to remove the back cover to look for ice, a frozen fan and if so get your hair dryer out and melt the ice so you can test the fan and the defrost element (you will need a volt/ohm meter to do the element check. You can do it.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 27, 2009 | Refrigerators
RANGEMASTER FRIDGE /FREEZER WATER FILTER WARNING LIGHT
Hi i have a rangemaster s x s fridge freezer and the ice maker has stopped and now the whole fridge freezer has stopped. its 2 years old and out of warrenty can anyone help please with a suggestions as to whats wrong.
Sep 18, 2009 | GE PDS22LBN Bottom Freezer French Door...
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
