Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA HDTV I saw some of you comments about the flyback transformer on the rca tv's. Mine doesn't turn on at all, the green light blinks and there is a funny noise. On one of your comments you asked about the noise when trying to turn it on.
  • jamiedingler Aug 16, 2008
    tv will not turn on. push the power button once, and it makes a high pitched noise three times about a second apart.
  • RCA Master
  • 8,617 Answers
You could very well have a defective flyback, as thats the item most prone for failure with that model. You can get a replacment flyback at the following link and they will sign you up for free online instant messaging while you do the replacement so they can take you through the entire process step by step. You need flyback 259296. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Aug 05, 2008
I have a RCA D52W20 52" HDTV Ready TV which I
Unplug High voltage lead from HV splitter. This is a red wire going from HV transformer to similar (white plastic) device located up front, between picture tubes. Disconnect the one which is coming in, by strong energetic pull down with pliers. Leave those which go to picture tubs in. Make sure that disconnected wire is far from other components or metal parts (high voltage - SEVERAL INCHES SPARK CAN OCCUR) Turn the unit on - if different than 3 blinks - the splitter is your problem.
Feb 03, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have hdtv rca d52w19 green power lights shows
Hello Chris this problem is coming from your high voltage circuit which consist of the flyback transformer and the horizontal output circuit, the most common problem when it is acting this way would be bad soldering on the flyback transformer or defective transformer but keep in mind it can also be caused by the horizontal circuit or a faulty lamp as well can cause this problem, what i would recommend is to have a tech come out to service your tv set this should not be an expensive repair since most of the time it is just bad soldering on the flyback thank you hope this helps.
Aug 27, 2009 | RCA D52W19 52" Rear Projection Television
My 52 inch rca tv power button blinks on and off
my rca tv will not power on power button blinks four times
Aug 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA tv will not stay on
Sounds like the flyback very famous for that model. You need Flyback 270125 you can get the new RCA flyback at the following link and they provide step by step detailed indtructions on how to do the repair. Heres the link to your flyback.
http://servicemanuals.vstore.ca/product_info.php/pName/270125/cName/flybacks
Jun 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52'' tv
check for vented caps or shorted flyback or tripler.
Aug 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HDTV WILL NOT COME ON LIGHT BLINKS 3X
Thats the error could for a bad flyback. You can get a replacement flyback at the following link with free tech support to take you through the steps to replace it. You need flyback number 259296.
Heres the link
Aug 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52" rca projection screen tv
If the light blinks 3 times its most likely the flyback. Your model uses flyback 259296 and you can get a replacement at the following link and they have free online instant messageing with a tech when you replace the flyback so they can take you step by step while you change it. Hers the link its flyback 259296.
Aug 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV went out
You need to replace the flyback transformer and horiz output transistor - I did mine for under $30 in parts....
Jul 28, 2008 | RCA F36650 36" TV
RCA D52W14 52" rear projection tv
3 blinks means the flyback needs replacing. very easy repair. You can get a flyback at the following link for under 50.00 with free shipping and free tech support so you can install it yourself. You need flyback 259296 here is the link.
Jun 28, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Wont turn on
I saw a reader on another site had same problem (and mine too). He replaced HO Transformer.
Nov 04, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
