Question about AEG 23 in. Favorit 44070Vi Built-in Dishwasher
I have a AEG favorit 44070 vi i ahd a problem with it not heating up and i replaced the heating element and it was filling up ok, then i had a small leak. It operated the anti flood switch, i have tilted the machine and drained all the water out. When i switch the maching on it will not fill up and the drain valve is operating Any tips
  • 1462 Answers
SOURCE: aeg favorite 645
to check the antiflood, remove the bottom front panel and the bottom tray is exposed. if there is water in the tray, this will actuate the antiflood switch. just mop out the water and the machine will run. turn off from mains when you do this.
however, this will not give a hum. the antiflood switch just turns on the drain pump.
if no water found then get back to me
Posted on Oct 02, 2008
SOURCE: Need to know how to re-set the anti-flood device
I managed to clean the filter inside the dishwasher and drain a little residual water. I then re-plugged in the appliance and the anti-flood device seemed to reset and I have n't had any problems since.
Posted on Jan 19, 2009
joe_lishman
  • 192 Answers
SOURCE: aeg favorit 86070 vi fully integrated dishwasher
This is typical of the anti-flood circuit that opperates once it detects water on the base of the machiene and is a polystireen float that activates a micro switch. This puts the machiene in pump out mode only. You need to determine if the water at the base of machiene is caused by a small leak or is it a customer spillage. Clearing the water (tip to side) or dry with paper towel and inspect for leaks. Rectify the leak and this should solve the problem.
Posted on Jan 19, 2010
joe_lishman
  • 192 Answers
SOURCE: Favorit 43070 vi leak
I assume that this leak is from the flat tank on the side of the machiene. Any water leak to the bottom of the machiene puts the washer in ANTI FLOOD mode with the pump out motor activated. You can remove the flat tank by disconnecting the hoses to it and pulling it upwards. If you find a small leak just run it over with a hot soldering iron to melt closed the small leak. Also note that this tank has a small outlet pipe that deliberatly discharges water to the anti flood device (polystireen float / micro switch at the base of washer) in case of a fault (blocked pipe / leak etc).
SOURCE: AEG OKO-FAVORIT 50800
C3 error means that there is water at the bottom of the dishwasher. Unplug the dishwasher, slide it forwards and push it back. So it stands on the 2 back knobs. Do this atleast at a anle of 45 degrees. You will see water flowing at the floor.
If this happens often you have a leak somewhere. Time to cal the technician then.
Posted on Sep 11, 2010
I have a AEG Favorit 65011 VI dishwasher which stops in the middle of a programm an shows error ,60 that is not mentioned in the Users Manual. Can you please help me?
Fault in heating phase. Could be:
Heating element, wiring between heating element and power board,
power board (usually relay). Sometimes can help to resoldering (cold solder joint) or replaced relay on power board.
Dado
Mar 10, 2015 | AEG Dishwashers
I have a AEG Favorit 65011 VI (dishwasher) which stops in the middle of a programm an shows error ",60" that is not mentioned in the Users Manual. Can you please help me?
The temperature must increase by a certain amount at each step.
If there is no temperature increase during three minutes, the electronics will generate "Heating Time Out" or fault code i60.
In this case program will continue to the end without heating and the washing result will probably be unsatisfactory.
Could be: Heating element faulty; intervention of safety
thermostats (open); faulty wiring; NTC sensor (poor
thermal contact); insufficient water circulating in the
tub; washing faulty pump (impeller stripped); circuit
board faulty.
Dado
AEG Favorit Integrated Dishwasher failing to heat the water. has the element gone? and how do you get at it?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Mar 23, 2011 | AEG 23 in. Favorit 50750Vi Built-in...
The dishwasher will not heat up what could be the problem
heatman101
Nov 23, 2010 | AEG 24 in. Favorit 40850 Free-standing...
AEG Electrolux FAV80870 dishwasher does not dry. After the cleaning the interior is not warm at all like before. Please can you suggest what could be wrong. Appliance is 3 years old. Thanks for the help.
heatman101
Jul 28, 2010 | AEG 23 in. Favorit 88070IM Built-in...
AEG Favorit 40650 water heater not working. How do I check if it is the heater element failure or the printed circuit board control unit
Check the element by using an Ohm meter. You should get an ohm reading if the element is OK. If the element is open circuit you would get an infinity reading. Just note that "newer" machines do not use the traditional heating elements but do have a (Inductive heater) coupled in line with the hose feeding the top spray arm of the washer. This unit must be cheched by a dealer as a DIY will have dificullty checking it.
Oct 21, 2009 | AEG 24 in. Favorit 40650 Free-Standing...
AEG Favorit 50730 Dishwasher
The dishwasers have heat (inductive) elements in line with the top sprayer hose and is about +/- 15 cm long and has an electrical push on clip at the side of the device.
Oct 26, 2007 | AEG 24 in. Favorit 50730W Free-standing...
AEG dishwasher not heating
Had simlar problem. It was the Program module. If yo open the program module you may see a burn track. Resoldering also ddid teh thrick
Aug 19, 2007 | AEG 23 in. Favorit 86070Vi Built-In...
Open Questions:
See all AEG 23 in. Favorit 44070Vi Built-in Dishwasher Questions
AEG 23 in. Favorit 44070Vi Built-in Dishwasher Logo
187 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
