Question about General Electric E1050TW Digital Camera
My GE camera displays "LENS
    Brigadier General:
  • 3,006 Answers
Your camera almost certainly has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the GE service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera, or at least are able to use the information to help decide whether to buy another camera. If you do decide that you have to throw your camera away then don't forget to remove the memory card as it can be used in other devices. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome.
Posted on Mar 24, 2011
Camera displaying error message
Have you tried cleaning the lens contacts, both on the back of the lens and in the mount on the camera body?
Jan 14, 2013 | Cameras
GE j1455 Digital camera
Go to this website and try the solutions:
Nov 02, 2011 | GE J1455 Digital Camera
Ge c1033 digital camera having problem as when power on camera its lens on and off and shows error "lens Obstruction restart camera" please help me resolve it.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Sep 21, 2011 | GE E1030 Digital Camera
I have a Canon PowerShot A430 camera. When I turn it on, the lens doesn't open and it shuts off. The message on the screen says " Lens error, restart camera." Please advise. Thanks
The Lens Error is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
You can reset the Camera back to factory default by performing the following steps:
Press the power button.
Press and hold the MENU button for more than 5 seconds. Default Settings will get displayed.
Use the arrow buttons to select OK and press the FUNC./SET button. This will reset all the settings back to factory deafult.
This should resolve the issue. If the issue persists, service may be required.
Thanks for contacting FixYa
Aug 10, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
Display shows "Zoom Error".
In this link can find details about everything you can try to fix it without sending it to a repair shop: Fixing-lens-error-on-digital-camera
Hope helps (remember to rate and comment this answer).
Mar 31, 2011 | Fuji FinePix S304 Digital Camera
Canon A630 lens error and black photos
hi u need to get the lens repaired the railing in the lessystem is no correct so pleas dont try to doit or push in .... it will be permanent damage ....get to the shot5 the camera is not broken need small fix....
Aug 30, 2009 | Canon PowerShot A630 Digital Camera
Lens error keeps coming up and the lens won't go in...it is a GE A730.....can anyone tell me how to fix this......
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 30, 2009 | GE A730 Digital Camera
Digital Camera
The following blog outlines some repair options for a lens error:
Dec 25, 2007 | Cameras
General Electric E1050TW Digital Camera Logo
53 people viewed this question
Top General Electric Cameras Experts
Tom Chichester
Tony Parsons
Tony Parsons
Are you a General Electric Camera Expert? Answer questions, earn points and help others
