Question about Beko Refrigerators
Just received a Beko Larder Fridge LA 620.Changed door from right opening to left opening.I am left with a small plastic cap which "fell out" when I removed the bottom left hinge bracket. Can't see where it fits on door swap over. Can you advise?
    Sergeant:
    Champion:
  • 207 Answers
The cap probably goes on the the hinge part, most likely on the top just for looks.
Posted on Mar 24, 2011
What is the plastic knob under the door hinge used for on kenmore model 7803 refrigerator?
Most modern fridges have these small plastic knobs [usually both top and bottom]. They are usually only COVERS for threaded mounting holes so that the fridge/freezer doors can be mounted for either left OR right opening ... ok They are generally around 1/2" [13mm] in diameter x 1/8" [3mm] in height.
They also help support the door [when it is closed] and prevent any "sagging" and/or mis-alignment or distortion of the fridge door which [these days] can be quite heavy when fully loaded.
Oct 20, 2014 | Kenmore Refrigerators
Failed auto defrost
Ray, you've added this question to a dishwasher thread. You would get better response on a fridge thread.
Jan 06, 2018 | Beko Dishwashers
How do you stop ice building inside, at the back of fridge model Beko LA87 Larder fridge
It can be 2 things. One is that the thermostat is broken but then it will also freeze your food. The other reason is that it has lost part of its gas charge due to a leak on the system causing the unit not to reach temperature thus not switching of on the thermostat and building ice inside. Normally it is not economically viable to fix the unit.
Oct 06, 2017 | Refrigerators
LA 620 LAP622 beko fridge
Use an ammeter to see if the motor current draw is within specs. If higher you may have some shorting of compressor windings and that will use up more juice and create more heat (and smell) and perhaps the clixon is shutting unit down till it cools off. And your condenser is squeaky clean, right?
Sep 06, 2017 | Refrigerators
Beko fridge freezer left door open all night in error
If the door was left open the fridge compressor would have run without a cut off and so would have resulted in an error. Please shut down the fridge fully remove power for about 6 hours and restart.
Nov 26, 2011 | Refrigerators
Hi, I have a BEKO TLDA662 Tall Larder Fridge and trying to get the drain tray out of back at bottom of fridge as it has starting smelling & want to clean. Instructions say "push lug down...
Let's make a guess that there is some sort of latch at the front of the tray that you push down with a screwdriver to release. They wouldn't have you use a screwdriver at the rear of the tray, or would they?. Use a flashlight to see if anything looks like a latch (or lug) at the front.
Apr 03, 2017 | Beko TLDA662
Help . Change doors from right to left opening
first remove the door from the fridge, remove the hardware connected to the fridge, on the opposite side should be rubber or plastic caps covering some bolt holes. remove caps and install top of hinge transfer everything you see on the left to the right
Oct 21, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
I want to switch the doors from left to the right side
Hi, The parts are interchangeable (hinges & handles)
You should have some small plastic plugs/caps that are covering the holes already drilled for the change. Once you remove the doors and then remove the plugs, just reinsert the plugs into the old holes and switch hinges and door handles to the opposite spots.
I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
May 26, 2009 | Frigidaire FRT17G4B Top Freezer...
Larder fridge running far too cold
I was told that it ispossible for a snall pin in the thermostat to stick and that vigorously turning the knob up ad down a few times might well unstick the pin
Tried it and it worked!
Jan 03, 2009 | Refrigerators
Fridaire model frt181l6d50
You'll need to remove the top hinge cover from whatever side it is on currently and then lift the door off the hings post ( set the door aside) .. then the top of the fridge will have small removable caps that hide the nuts for where you fasten the hinge to that side. Reinstall those caps to hide the holes in the top of the fridge where the hinge used to be. Next, you will have to transfer the handle on the door to the opposite side ( same process as the hinge) .. You wil find small plastic caps that hide the holes you'll be using to secure the handle to the opposite side,. use the same process for the freezer door too..This process only applies to top/bottom type freezers and not side by side. Hope that helps
Aug 03, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
187 people viewed this question
Top Beko Refrigerators Experts
AJMAL KHAN
ray gallant
Are you a Beko Refrigerator Expert? Answer questions, earn points and help others
